| Camaro Z/28 Forum - Z/28 Specific Topics Discussions related to the 5th gen Camaro Z/28 model |
Thread Tools |
#51 | |
I used to be Dragoneye...
The CTS is getting bigger. The CTS will be on a long-wheelbase version of the Alpha chassis. The CTS will still harbor a 'V' series model... ...therefore the CTS will still need a lot of freakin' power to keep it competitive. The ZR1 Corvette will also continue in the next generation... I think the chances of a forced-induction, moderate-to-high displacement Gen V smallblock is high, because the need for that sort of power will be there. And if they felt like it...I think they could justify using this theoretical engine in a smaller 6thgen Camaro for a ZL1-on-steroids.
#52 |
It Will Be Mine
Drives: A 2014 Z28 or a C7? Join Date: Jun 2009
Go simple.
forged wheels = less weight manual seats = less weight 2 piece rotors 6/4 pistons calipers = less weight coilovers/performance suspension (Pedders/Pfadt) = less weight electric steering = less weight LS7 = more power 3.73 gearing = more performance This is very doable. Maybe lose 150 lbs. off a 1SS (Huh, Number 3) 4.0 0-60 12.0 1/4 mile 110' 60-0 1.0 G 75.0 Slalom $42,000. Any comments Number 3? I respect your thoughts!
#53 |
I read those and smiled a little....only because the ZL1 will likely do as good or better...and come with all the trimmings inside.
#54 | |
Hail to the King baby!
Drives: '11 Cruze Turbo & '13 Audi S4 Join Date: Dec 2008
Manual seats for sure, but only a few pounds. I know my Sky has power height on the driver side, but manual for all others. So that can work. I will let Pedders or Pfadt comment on this. My first instinct is they actually weigh a bit more. But that is a factless observation. I haven't seen the EPS mass. ZL1 has EPS, SS doesn't so if it weighs less it's good. Plus better FE. LS7 is for sure more power and awesomeness. But just big bucks due to the manual build in Wixom. I'd hope for a nice LS3 bump. Problem there is you now make the LS7 obsolete. Why pay big bucks for 505 when you can get 450+ for much less. Gearing something that I think could add an immediate benefit. Honestly not sure why we haven't tapped into this. I like your numbers, which would require the LS7. I think your cost is ok, but not with the LS7 which is the contradiction. But for me, here is what I would do to drop the weight and still have a car pleasant to drive every day. Start with a 1SS Eliminate all engine covers and plastic in the engine compartment. If it isn't moving fuel or coolant..............gone. Manual seats. No fog lamps. No LS filler. Just a simple fascia. No mail slot. No floor mats. (optional on 1SS anyway??) No trunk trim, no flat load floor, no spare, no inflator. Just a can of fix a flat. No folding rear seat. Yes, I want a rear seat or I'd just buy a Corvette. But I don't need latches and pull strap to fold it down on very rare occasions. I'd remove some but not all NVH treatments. Lighter dash matt, reduced mastic materials on the body. Eliminate the push/push fuel door and add the finger cup back in. This eliminates the push pin mechanism. Smaller bare bones console. Simple arm rest in between the seats. No power passenger side rear view mirror. Go to a 15 gallon fuel tank. Saves full tank of fuel mass and also just a smaller, lighter tank. Thinner glass for windshield, doors, back light and quarter glass. That might, and I'm guessing save 50 pounds, not counting the reduction of 3 gallons of gas (an extra 20 pounds) Adds: Carbon fiber hood Titanium exhaust (C5 Z06) Glass Matt battery (bad for performance, but good for mass) Magnesium front cradle (C6 Z06) Low mass race wheels (C5 had titanium but wouldn't go quite that far) Again, guessing a bit, you might save another 100 pounds. So total reduced weight 150 pounds over a 1SS. If at all possible, get the Wixom LS3 (reported to make more power) and add tweak it where possible. Only asking for 450 at the crank. Now add the suspension improvements from the ZL1 minus MR shocks. Widen the front tires to help understeer. Now you have a slightly lighter, slightly more powerful and slightly better handling car. That will likely not get your 0 - 60 in 4.0 seconds or 12 second 1/4, but might make the rest of your numbers.
#55 | |
Hell yeah I'm Guilty.....
#56 | |
ZL1 177 Pilot
Drives: 2012 ZL1, 1973 Z-28 Join Date: Oct 2010
#57 | |||||||||||
Drives: '11 Mustang GT Premium Join Date: Oct 2010
Fuel tank: Good idea, research the typical classes that this type of vehicle would run in and find the duration of each race... Adjust the fuel tank accordingly, if its a 1 or 2 hour race, they are going to have to use a fuel cell anyway and relocate the fuel door for pit stops. Quote:
#58 |
With 275/40 (or 35's)-19's you can run a 19x9" wheel all around. Weight savings, using a casted/flow formed wheel over the stock casted 20's could save you almost 10lbs in the wheels alone. The weight from the tires, front to rear, wouldn't increase weight at all.. In fact, depending on the tire (PS2, P-Zero are the lightest) you could acually save a pound or two in rubber per wheel... Its the sidewall that adds weight more that tread.. You could come out with weight savings of 40+lbs in wheels and tires. If the weight of the vehicle drops below 3800lbs, look into a 14" front, 13" rear disc (maybe smaller).. weight saved again...
#59 | |
Use the Force
Look at the LS7 engine. A powerful hand built 7 liter big block with no home other than the Z06 that will most likely get replaced with a smaller engine in the next Corvette generation. Everyone would like an LS7 for the coming Z28 track star but in reality there is really not much of a chance of that happening simply because of the engine cost. The current Corvette race cars with their direct injection engines make great HP and the billion dollars that GM spent to upgrade their engine plants show the most likely path that GM will take in the future.
Walk softly, carry a light saber and drive a ZL1!
#60 | |
Use the Force
#61 | |
![]() Drives: 97Z,02TA Join Date: Mar 2011
I dont see why not. I realize its more expensive, but this also isnt a "plain" SS so to speak. For one it takes no more space than the LS3, except for the dry sump tank. And to the untrained eye it looks identical. Also, GM as it, why not use it? Its just another weapon in the arsenal. If Ford wants to step it up, I say we one-up them. Who says we cant have the best of both worlds? Displacement and DI. |
#62 |
LS7 is not a big block.
#63 |
C5 Member #227
Drives: Camaros Join Date: Sep 2006
A few random thoughts.
1. The SSX is a rough draft of what GM envisions the Z/28 to be. 2. If GM didn't intend to build a Z/28 in addition to the ZL1, the ZL1 would have been named Z/28. 3. Number 3 mentions that a tweaked LS3 (that's what they show to be in the SSX by the way) would render the LS7 obsolete. As far as I've heard the LS7 is being discontinued to begin with so that's not a big deal. 4. Number 3 mentions WAY too many real world options for us not to believe the GM engineers have not spent time developing a Z/28 if only in CAD. 5. If GM had not filed for bankruptcy as a result of the financial meltdown we would already have a Z/28. 6. If we don't see a Z/28 as a road worthy production intent vehicle on the 5th gen platform, we will definitely see one in the next gen. 7. Having a Z/28 fit in between the SS and ZL1 makes perfect sense. The Camaro sells in much higher volumes than the Corvette and the Corvette is available in the following trims, LT, Grand Sport, Z06 and ZR1. I really wanted to buy a 2010 Camaro but it didn't work out for a daily driver (I have a wife and three kids). I did however do the next best thing to help see future generations and trim levels of Camaros. I bought a 2010 Malibu. The better GM does as a corporation, the more we will see from them. :flag2:
#64 | |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
As long as we are speculating about what could be a Z28... On Leno's Garage his video says the Z28 will be a twin turbo direct injection six. http://www.jaylenosgarage.com/extras...aro-sema-2009/ Would there be a weight reduction with the Leno setup?
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#65 | |
Use the Force
#66 | |
Just remember back to when they transfered over to the LS-series engines...today's story started with a naturally-aspirated, 350hp 5.7L V8....
#67 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Off Into The Sunset Join Date: Mar 2008
I think GM will lower the displacement, add direct injection and other (VVT) items to make the same power.
Turbos fail. Look at the EcoLoser Taurus SHO. Same power as a V8!! Yeah, and the same freaking fuel mileage, with no OMG low-end torque. They are thinking about using AFM across the board, but they better refine it a lot, because it's an intrusive POS now. |
#68 | |
True and I think GM would be better off coming out with a different car, I mean having 2-3 different camaros I dont know guess its cheaper for them. But Camaro isnt mustang where it can release 50 million different brands.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
#69 | |
Use the Force
#70 | |
![]() Consider, though...when hp rises...TTV6s don't offer very much at all over a DI V8. |
#71 |
Although I honestly admire the evolution of the TT V6's, I just can't see a TT V6 being the track option for a Camaro Z28. The only two TT's that would even be considered is the 3.0 and the 3.6, it is proven that the 3.6 can make 425hp but it wasn't made public if the setup could pass emissions. The TT 3.0 is being produced to compete with at least 350hp but as of now only produces 270 hp and 213 lb-ft.
The weight of a VVT, DOHC V6 twin turbo with exchanger/intercooler and plumbing could very likely push 400+lbs. Even if the 3.0 uses the more compact valley turbo setup, it will still weigh a decent amount. It is said that the TT 3.6 could produce fuel efficiency numbers equal to a 3.6 V6 but again, this engine as far as I know is uncertified. The 3.0 is currently being designed with performance, fuel efficiency, emission requirements and could possibly be much lighter than the 3.6. Although, the 3.0 will not perform as the 3.6 does, as it could be around 360hp but really fall behind on torque due to smaller bore/stroke. However, unless they are offered against a new Gen5 V8, the cost of a V8 that already exist will be much, much lower. Regrettably, there is simply no room for a TT V6 as an entry level engine or a high performance option as long as the standard N/A V8 is around. There is a remedy for that though. The Gen5 V8 (or V8's) will feature an engine block with a "raised" cam. The camshaft will set higher in the block, farther away from the crank and allow for the pushrods to enter the head casting at a greater angle. This aggressive pushrod angle will flatten the pushrod movement to more of a left to right operation instead of the traditional up-down at a "V" angle. This will increase valve train speed and also eliminate the pushrods operation through the intake port as pushrods have always naturally done. The LS3 heads offset the pushrods further into the head casting and away from the intake port to increase airflow but doing so, it placed the pushrod guides in the direct path of direct injection. This new Gen5 will obviously host DI, increasing fuel economy, efficiency, eliminate valve train parasitic losses, increase valve train speed increasing maximum RPMs and increase horsepower, torque at a flatter power curve with better CO2 emission output. This can all be accomplished simultaneously while reducing the displacement if only by a fraction of a litre. Larger displacement will become more and more obsolete as standard V8's become super efficient and with efficiency naturally comes power. If a standard NA V8 could produce 440hp, get 28mpg, have a 7000rpm redline and weigh just as the current V8's do then a TT V6 could definitely become a bargain performance option, especially when the majority of aftermarket money is in forced induction. A high volume TT V6 could broaden GMPP's aftermarket stance because a 350hp, 32mpg package would be highly marketable. Surely a FI, fully forged Gen5 would find its way into a bragger model in limited numbers if needs be. The Ecotec I4 (maybe for extreme sales volume) could also bolster the aftermarket along with the TT V6 as it would inherently be lighter than the TT V6 and could manage 300hp at 3400lbs and still attract the masses with a 36mpg.. all for the base MSRP of what a V6 Camaro offers now. The NA Gen5 would be reserved for the Z28, offered along with the SS (TT V6, You say Super Sport, I say Standard Sport) equaling it in weight but producing numbers far higher than the SS with the exception of MPG's. |
#72 |
I'd agree with most of what you said, Pill.
I think your fuel economy assumptions are a little aggressive/hopeful, and none of us know if GM's been working on a performance-oriented 3.6L TT V6 in the basement (I'll bet my ZL1 they do...)... Still, good overview! The best thing about the Gen V V8...is that although you'll probably see its application shrink slightly thanks to better V6s and increasing fuel economy/emissions standards...it'll hardly disappear. Trucks are a very big part of GM's portfolio. As is the Corvette, and Camaro. So long as those three factors exist -- there will be a Small Block Chevy available to be shoehorned into any vehicle they think appropriate. |
#73 | |
Not sure if the engines are certified with A/C running or not but just think... EAC could see a small gain like the EPAS in both power and MPG's while not in use and no penalty for full blast ... Hell, if it wasn't costing me power and fuel, I would pump cold air right into the intake from the A/C... Now that's CAI!!! Gotta stop... gettin off topic... Edit: Those are highway guesstimations... Last edited by thePill; 03-06-2011 at 12:43 AM. |
#74 | |
But I love the optimism ![]() What you haven't covered is a more aggressive FE oriented calibration. Early torque converter lock up, much more aggressive decel fuel cut off. Earlier shifting. For the most part that is already done, but you could go further. But if you simply calibrate the car to "force" FE, then you will PO customers. Refer to the original Lambda launch if you have any doubts on this. You always have to consider that you have to have a car that is drivable and delivers on the performance expectations of the customer. Why would you buy an SS if it really wasn't that much more of a performance car over the super impressive V6? Now if you can get all of todays performance and improve FE (EPS does that) that's awesome. It's just hard to do. As for electric A/C, run the numbers and see how much electric power would be required, how much bigger a battery you might need and how much bigger an alternator would be required. In the end, EPS is a benefit over Hydraulic. And BMW (maybe you didn't know this) doesn't allow the alternator to charge the battery until absolutely necessary to legally game the EPA Cycle. So engine load can be and is often a big deal. But electric A/C needs power as well and it's not free. So from a cost benefit, mass benefit, is it still a viable solution? The Volt has a huge battery to store this energy. And using the electric heat or A/C has an effect on the range and it can be a big effect depending on if it's very hot or very cold. And yes, air conditioning is considered in the EPA Schedule. http://www.fueleconomy.gov/feg/fe_test_schedules.shtml Now if you truly want to focus on the highway number, then you have to focus on aerodynamics. That plays one of the if not the biggest part in highway FE. So you can do things like the Cruze ECO for aero (underbody shielding, radiator close out, lightweighting (another famous Camaro5 topic) and gearing to achieve about a 10% or so improvment. Those that I know and trust have driven the ECO and are quite happy with the drivability. The slightly lower mass offsets the gearing changes and makes a very pleasant car. All this using the same 1.4T engine. So you could do some things here as well, but in the end it's CdA, not Cd. And the Camaro is simply a big car. Low rolling resistance tires help too, but that's a direct trade off of handling and braking.
#75 | |
Moderator, USN
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | Yesterday 09:32 AM |
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
| The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 106 | 10-19-2009 06:08 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
