BeckyD @ James Martin Chevy
Old 02-27-2011, 11:13 AM   #1
b20
Drives: 2013 1LE RS 1SS
Stock cams for sale ls9 ls2 ls3
Ok
2 ls9 cam new in the box 150 each shipped to lower 48
3 ls2 cams used 30 each shipped to lower 48
2 ls3 cams used 30 each shipped to lower 48
If local drop the price 15 dollars
Thanks david
b20 is offline   Reply With Quote
Old 03-01-2011, 02:09 AM   #2
b20
Bump nobody
Old 03-02-2011, 09:57 PM   #3
b20
Bump
Old 03-04-2011, 06:58 PM   #4
b20
Nobody even wonts the ls9 cam
Old 03-07-2011, 01:25 PM   #5
DSX
Drives: 2006 Z06
You can get them brand new from gmpartsdirect.com for $110 shipped.
DSX is offline   Reply With Quote
Old 03-07-2011, 11:36 PM   #6
b20
They are not in stock
Gm miss priced them and are not shipping anymore
Old 03-08-2011, 09:51 PM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
What else do I need to do the swap? Special cam gear and what else?
-Mark.
Old 03-10-2011, 07:25 AM   #8
b20
-Mark.
Cam gear
Bolts for cam gear
Crank bolt
Anti freeze
Oil change
I do new thermostats when do cams and sometimes crank pullies to save labor down the road
Make a offer
Old 03-11-2011, 09:27 AM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Cam gear
Bolts for cam gear
Crank bolt
Anti freeze
Oil change
Make a offer
Thanks! - I already have the cam and gear kit on the way or I would jump on it.
-Mark.
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS 9 internals for LS3 so I can use the LS9 Superchager on the LS3 1985airborne Forced Induction - V8 5 08-09-2010 10:57 AM
Question about stock bottom end reliability (LS3) 99-LS1-SS Forced Induction - V8 10 04-28-2010 10:44 AM
Does anyone know any companies that stock the LS9 clutch that works for the LS3? Mindz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 04-19-2010 08:26 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
