HeadlightArmor
Old 02-10-2009, 07:28 PM   #1
CDBiker220
Drives: 98 camaro z28
GXP Dyno and Weight results..interesting
Hey, decided to check out the G8 boards. Was interesting to see the GXP rated at 415hp put down 370hp to the wheels..sounds pretty good. Also the weight is supposed to be 4000+...came in at 3992 with 85lbs of gas in it. So looks like the GXP's might be closer to 3900lbs dry. They might be a better comparison to the camaro than previously thought.
Dyno pics
http://www.g8board.com/forums/showth...228#post164228
Weight pics
http://www.g8board.com/forums/showthread.php?t=10703
CDBiker220 is offline   Reply With Quote
Old 02-10-2009, 07:38 PM   #2
383ss
Drives: 1985 IROC, 2011 Camaro
interesting weight info
the smartest person on Camaro5! Thanks for enlightening us!
Originally Posted by hsdguru View Post
31000 for ss1 no options and who in the hell would buy a SS1 V6 for kids SS1 for girls LS3 the only way to go G8 Gxp 200lbs more my bad so lets think here 200lb more 27 less hp so 5 tenths slower now 373 gear now mabe 3tenths slower 4 door car sad so so sad
383ss is offline   Reply With Quote
Old 02-10-2009, 08:04 PM   #3
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
at your sig... I remember that EPIC FAIL of a thread!!
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 02-10-2009, 08:47 PM   #4
Silver Streak
Silver Streak's Avatar
Drives: 2008 Cobalt SS/TC
Send a message via AIM to Silver Streak Send a message via MSN to Silver Streak
What does GM say the GXP weighs, and what do they say the Camaro weighs? I would think that they did not weigh the cars differently, so I would think if they show a weight difference, there is a weight difference. Can't say for fact, but it seems to make sense to me, and cars are like snowflakes when it comes to dynos. Same car, factory set-ups and you might get quite a difference in hp. Like I said I am no expert. I have seen from experience 2 cars same factory yrs and models pull a difference of 30 hp and 20 ft-lbs of torque. Just a thought. Great hp numbers anyways, don't know bout the weight thing for sure though.
Silver Streak is offline   Reply With Quote
Old 02-10-2009, 09:01 PM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Dyno pics
Weight pics
so only 11% loss of power?
I think you mean epic fail of a poster.
Old 02-10-2009, 09:09 PM   #6
kdbolt70
kdbolt70's Avatar
Drives: 2010 Camaro 2SS/RS
I posted this here: http://www.camaro5.com/forums/showthread.php?t=13027 a few days ago. But yes, its still quite impressive what the LS3 can accomplish. What do you think, 380rwhp for the SS M6?
2SS/RS Victory Red M6 w/ Black Rallys #3305
Muffler Delete, Lloyd "SS" Floormats, K&N Aircharger, Skip Shift Eliminator, Blacked Bowties
kdbolt70 is offline   Reply With Quote
Old 02-10-2009, 09:43 PM   #7
CDBiker220
from what ive seen with the vettes, ranging from 375-390whp, i think 380whp is a realistic estimate for the camaro. Also in that dyno thread, note the tuner said timing was at only 15.5 degrees in the GXP whereas it was at 22 in the stock vette LS3's they dyno'ed....that they tuned to 25 degrees. I have a feeling the camaro timing lies somewhere inbetween those two. Seams that the differences in horsepower in the LS3's are all in the tune.
Old 02-10-2009, 09:49 PM   #8
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
If the 11% loss at the wheel stays true we are seeing 379HP at the wheel.
Old 02-10-2009, 10:03 PM   #9
CDBiker220
Also i just wanted to note that he also mentioned his car is a sunroof car, so it has added weight there too, still coming in at 3909 with an empty tank, one without a sunroof might be closer to 3880. The official dry weight of this car is 4050. Someone mentioned that the camaro is likely weight the same way. Maybe it will come in at a lower actual weight too.
Old 02-11-2009, 01:24 AM   #10
gunslinger
Drives: 1998 Z28 M6
I think we will see about the same 370 at the wheels because the GXP has the same IRS and Trans that we will be getting.
How big are the wheels on the GXP? Heavier wheels really do make a difference on the dyno and on the streets.
And that weight is pretty close to the SS weight which is discouraging because the GXP is a FOUR door car and ours is a coupe!!!!
EDIT: That is about 70 more RWHP than the 4th Gen Camaros with about 450 more pounds. With the common 100lbs=10 RWHP conversion, the SS should be about 25 RWHP faster than a LS1 Camaro, or about the same as a 4th Gen with a set of Long Tube headers and lid, which usually results in a car that runs mid to mid-low 12's in the quarter mile.
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 02-11-2009, 06:59 AM   #11
spd98
Drives: had a goat
There is nothing to indicate that the Camaro should put more to the wheels. Same drivetrain so it should be in roughly the same area. Keep in mind the vett will always put more power to the wheel's. The torque tube and rear end are more effecient than the zeta system.
spd98 is offline   Reply With Quote
Old 02-11-2009, 09:48 AM   #12
CDBiker220
The GXP is rated at 415hp whereas our camaro is rated at 426. Probably all in the tuning...but still..that gives a good reason why it probably will put atleast alittle more to the wheels with the same tranny and IRS. Also if the GXP is lighter than the official spec than who's to say the camaro wont be lighter than the official spec?
Old 02-11-2009, 10:32 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Great numbers, IMO. I can't help but wonder if GM is underrating the LS3 or if that powertrain and IRS that efficient. Either way, our SS is going to rock!!! Great find. I go there to snipe information too, LOL!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-11-2009, 12:10 PM   #14
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
Glad im not the only one that goes there to find out info. I was over there looking at the CAI that will be coming from Vararam for the G8 GT. Hoping there is one for the Camaro soon after release.
Hesh is offline   Reply With Quote
