Old 03-05-2011, 01:36 AM   #15
CyberPredator
50 Shades of Prey
Drives: TT/SS
yes I was referring to dual springs. Good luck with everything. I hope she gets tip top shape soon.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 03-05-2011, 09:39 AM   #16
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Originally Posted by Jason 98 TA View Post
Hope the valve isn't bent! That's exactly the reason we like to see customers buy our double spring kit instead of single springs. If a single spring fails there's nothing to keep the valve up :( :(
The good news is if you have to swap valves in theheads it just gives you a reason to do cnc ported heads!!
You use dual springs with your VVT setup ?
What would I pickup RWHP wise from a set of heads? I'm cammed, supercharged and running meth.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 03-05-2011, 09:55 AM   #17
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
i would if those are PAC springs? 1518 or 1218?
94guy is offline   Reply With Quote
Old 03-05-2011, 10:19 AM   #18
lexlueger
lexlueger's Avatar
I don't believe the ones included in the Mast cam kit are PAC's...The PAC 1518 were recommended as replacements for the Mast springs.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 03-05-2011, 11:25 AM   #19
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Look a bit like Comp's beehive springs. I know Comp had that spring breakage issue on thier beehives a couple of years back but if we are still seeing problems....
I would trust PAC's beehive springs. That is what I have in my 302 now.
-Mark.
Old 03-05-2011, 07:23 PM   #20
lexlueger
lexlueger's Avatar
-Mark.
Thanks! I'll go with the PAC
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 03-05-2011, 08:06 PM   #21
Slowhawk
Drives: 1999 Trans Am
Just make sure you cam isn't retarding too much to cause P/V contact.
Valve springs can/do break. I've found the single springs weaken faster than the duals when the cars are stored for long periods of time.
Slowhawk is offline   Reply With Quote
Old 03-05-2011, 08:19 PM   #22
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Beehives wont handle the valve load required to control a cammed car under boost. They just wont. Put in some quality duals, and call it a day
Ovenmitt is offline   Reply With Quote
Old 03-05-2011, 09:37 PM   #23
lexlueger
lexlueger's Avatar
I have never heard that before... maybe one of shops/tuners can chime in on that. Also I'm not sure if I can run duals with a VVT setup.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 03-06-2011, 01:58 AM   #24
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
not true at all , pac makes some very good single springs, i have been using them for years in my builds.
Old 03-07-2011, 05:56 PM   #25
lexlueger
lexlueger's Avatar
Latest news..Valve guide is also cracked. Pistons dinged up and the valve and pushrod are obviously history. Do I repair the valve guide and do forged pistons, rods and some pac springs? or just say F*** it and go aftermarket heads and forged bottom end*crank and all*. The later requires me to sell a kidney:(
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 03-07-2011, 06:09 PM   #26
Slim2SS
Black Thunder
Drives: 2010 Camaro 2SS/RS
I feel your pain, I had to make the same decision when I lost the #7 piston in my car. I did sell my kidney and went with a full forged build. The biggest thing that really surprised me is that they found my crank was also cracked when they took the engine apart. Had I not done the full build and just replaced the bad parts I would have never known the crank was cracked untill it finally would have let loose!!
JRE 416 9:1 Forged Stroker Package
Edlebrock E-Force Super Charger
JRE Blower Cam package
Cooling Mist Water/Meth
3.25 blower pulley
FAST 65 lb. hr. injectors
JRE Edelbrock fuel system upgrade
GM ZR-1 Clutch
Roto Fab CAI
Kooks Headers Jet Hot Coated
Kooks High Flow Cats
3" Magnaflow Stainless Steel Exhaust
Barton Short Throw Shifter
JRE Dyno Tune
Slim2SS is offline   Reply With Quote
Old 03-07-2011, 07:15 PM   #27
lexlueger
lexlueger's Avatar
Wow! I hope mine is in better shape. If I may,how much did the stroker run? PM if you want.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 03-08-2011, 03:23 AM   #28
Ovenmitt
Vastly irrelevant to the issue.
All "NEW" Custom Billet Valve Covers for the Camaro Offered Bruce at Billet Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 37 09-27-2010 12:01 PM
Discussion of suspension tuning methodologies Tankrust Wheels and Tires Talk Sponsored by The Tire Rack 10 08-04-2009 07:39 PM
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 11:54 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
