HeadlightArmor
Old 03-04-2011, 01:32 PM   #1
performance red line
performance red line's Avatar
Drives: buick grand national
g8 and camaro ss it is the same shock ?
hi , a freind told me the g8 2008 and the camaro ss got the same shock . it is true
can we use a set of coil over from a camaro to instal into a g8 or or a camaro into a g8 .
sorry for the stupid question but we dont have a lot of g8 in canada.
thanks
yellow baby 2SSRS and 8.90 sec v-6 buick grand national full weight car
performance red line is offline   Reply With Quote
Old 03-04-2011, 03:18 PM   #2
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
The steering knuckle in the Camaro is larger that the G8, so no they won't work. Your friend could get a set of G8 GXP shocks which are FE3, like the Camaro SS, and they'll fit. Also, the Camaro has a different upper strut mount.
Jaysin is offline   Reply With Quote
Old 03-04-2011, 03:31 PM   #3
Iansane
Drives: 325is
G8 rear shock length (eye to pin) 437.9mm
G8 rear shock eye bolt M12
Camaro rear shock length (eye to pin) 414.1mm
camaro rear shock eye bolt M14
G8 Front spindle bolt spacing 58mm
G8 spindle tab spacing 25.6mm
G8 upper mount diameter 102mm
Camaro front spindle bolt spacing 85.5mm
Camaro front spindle tab spacing 30.6mm
Camaro upper mount diameter 122mm
Not sure on the damping difference
Iansane is offline   Reply With Quote
Old 03-04-2011, 03:50 PM   #4
ok wow big differance , what he buy is a set of coil over hsd full ajustable and hsd told them thay need to modified a bushing but thay don't tell witch one :( thanks for the help
Old 03-04-2011, 09:25 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The front strut mount is completely different from the G8 to the Camaro too.
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
