Rick@Livernois
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Rockies / Midwest > Local Marketplace
Old 03-04-2011, 10:10 PM   #1
Genevieve
Drives: 2SS/RS
FS: BMR Lowering Springs
Long story, but the short version is I ordered a set of BMR springs and ended up with two sets, and yes I paid for both sets. So being that I only need one set of Springs I looked into returing the second set. With me paying shipping and restocking fees I figured someone local would like to gain from my loss. They are unopened in the box. The kit is the SP019 kit which is a 1" drop in all 4 corners. The link to more details....
http://www.bmrsuspension.com/index.c...&productid=836
And if you need any help installing, seeing that I just went through it, I am more than willing to help.
Asking 230 for the set.
Thanks,
Genevieve is offline   Reply With Quote
Old 03-07-2011, 09:07 AM   #2
IPAINTBRIDGES31
2ss Black on Black M6
IPAINTBRIDGES31's Avatar
Drives: 2012 CTS V Sedan
Genevieve have you installed springs on your car yet? I was just wondering what you thought about the feel of the car now. I have a set and I am on the fence about installing them. I love the look of the car lowered but I am not to keen on the cars ride being overly harsh.
IPAINTBRIDGES31 is offline   Reply With Quote
Old 03-07-2011, 09:21 AM   #3
IROCanSS
Drives: 89 IROC 350
It's a great ride PAINT. I have lowering springs and sways. Throw them bad boys on!
Old 03-07-2011, 09:59 AM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I have the BMR 1" drop springs on all 4 corners. In normal driving and normal size bumps I and my wife do not perceive any increased harshness. I guess it is possible to hit a large enough bump that would allow the struts and shocks to hit the bump stops with the 1" drop springs before the same bump would with the stock ride height springs. I haven't run into that at least not yet. Also, although the springs are rated at 1" drop, my particular car ( and I suspect most others ) saw a drop of ~ 1 1/8" all around after everything settled. The BMR springs are top notch and the improvement and handling as well as looks are hard to beat.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 03-07-2011, 12:34 PM   #5
Genevieve
Drives: 2SS/RS
as already stated normal driving and normal bumps, no difference, car feels great, on the way to CBI there were some spots that you could feel the stiffer springs but nothing I would describe as harsh or regret from doing the new springs. Its at CBI now getting the new Bushing put in, I am sure we can work something out so you can feel the springs yourself.
Old 03-11-2011, 07:13 PM   #6
Genevieve
Drives: 2SS/RS
Sold!
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 05:17 PM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
