Cold Air Inductions
Old 03-05-2011, 02:57 PM   #1
midlife
Drives: 2011 Camaro 2ss
ratios
Does any one know the gear ratios of the 6 speed manual transmission for the 2011 Camaro SS? The rear is 3.70 I believe. I wonder what 4:11s would do?
midlife is offline   Reply With Quote
Old 03-05-2011, 03:03 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The stock rear end in the M6 SS has 3.45. Give this article a read.
http://thehorsepowerjunkies.com/vehi...swappin-gears/
Old 05-15-2012, 10:30 PM   #3
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
This is a great write up, thank you!
butters is offline   Reply With Quote
Old 05-16-2012, 09:17 AM   #4
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
Gear ratios: M10
First: 3.010
Second: 2.070
Third: 1.430
Fourth: 1.000
Fifth: 0.840
Sixth: 0.570
Reverse: 3.280
Final Drive Ratio:
3.450 (rear axle ratio)
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 06-23-2012, 01:05 PM   #5
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Originally Posted by Apex Chase View Post
This means that for every rotation of the driveshaft the rear axles will rotate either 3.27 or 3.45 times.
You got that bass ackwards my friend.
willhe64 is offline   Reply With Quote
Old 09-29-2012, 09:53 PM   #6
dangjohnny
Drives: 2013 Evolution GSR
Yeah the driveshaft is spinning faster for every turn of the wheel not the other way around. 4.11 gears means the driveshaft turns 4.11 times to every wheel turn. That is where the torque comes from.
The first time I changed rear gears was in a 92 mustang gt, wow what an experience. Never realized how nasty axle grease was. The car felt completely different after the swap. Went from 2.73 to 3.73.
When I calibrated the mustangs speedometer I had to use a speedo gear that was on a linkage to the tranny. I am still trying to figure out how you electronically do it now to a 5th gen camaro. I guess you buy a tuner kit to calibrate it?
dangjohnny is offline   Reply With Quote
Old 12-22-2012, 10:04 AM   #7
TedW
TedW's Avatar
Drives: 2012 Camaro SS
Thx for info
TedW is offline   Reply With Quote
Old 12-22-2012, 11:29 AM   #8
NoPoney
NoPoney's Avatar
Drives: 2011 Camaro SS Convertible
Swappin' Gears
Added Dec 31, 2010, Under: Camaro
The V6 Camaros equipped with the manual transmission (M6) come with 3.45s and run 2120 RPM at 70 MPH. Swapping to the 3.55s provides an equivalent torque gain of approximately 5% or 14.6 ld.-ft. of torque at the rear wheels and will raise 70 MPH cruising RPM to 2180.
My understanding is that the M6 Camaro with V6 is a 3.27, not a 3.45. Would bumping to the 3.55 do much? How about a 3.73?
NoPoney is offline   Reply With Quote
Old 08-17-2013, 04:27 PM   #9
Gen-X45
Gen-X45's Avatar
Drives: 2017 2SS Camaro
Hey Chase, I'm still looking into the gear swap... I read the link you've posted here, then read your post as well. It is my understanding that the V6 M6 has the 3.27 gears as noted in the "linked" article. By adding the 3.55 gears from Richmond, we can expect torque gains of approximately 9% or 27.3 ld.-ft. of torque and will raise 70 MPH cruising RPM to 2167. This article is in contrast to what you've posted so I'm just trying to get some clarification. I agree, if the 2012 model year has 3.45's then it wouldn't be worth the dollars. If the 2012 model year has 3.27's it just might be time to switch them out. One more question, what are the speeds in first gear with the 3.55 before shifting into second, normal street driving. I've had my car for just over a year now, if I'm running 3.45's I'd be surprised because I can't be beyond 20 mph before having to shift.
Gen-X45 is offline   Reply With Quote
Camaro SS LS3 gear ratios. JEFF2010SSMANUAL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 23 06-25-2015 10:45 AM
LT & LS different gear ratios? RubyCamaro 5th Gen Camaro SS LS LT General Discussions 8 07-31-2013 05:01 PM
Gear ratios kaspa3535 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 50 10-11-2011 06:45 AM
94 v6 & 92 V6 axle ratios twigworker 4th Generation Camaros 2 07-15-2010 02:45 PM
Difference in gear ratios Camaro vs Vette JerseyMonte V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 09-24-2009 05:49 PM
