JDP Motorsports
Old 03-08-2011, 05:51 PM   #15
Ramsey
Ramsey
Ramsey's Avatar
Drives: 2011 1LT IOM
that second link closed out when it opened, norton detected malware in it.
Ramsey is offline   Reply With Quote
Old 03-08-2011, 07:13 PM   #16
SlyJester7
SoCal HT5 *COTW 8/26/13*
SlyJester7's Avatar
Drives: 2013 SS/RS LS3
I wish i had the time to tackle something like this.. . My camaro is begging me for a twin turbo set up.
SlyJester7 is offline   Reply With Quote
Old 03-08-2011, 07:57 PM   #17
xpanda305x
Banned
Drives: Dark Knight
ya looking at twins...ima just looking for a single turbo :(
xpanda305x is offline   Reply With Quote
Old 03-08-2011, 08:53 PM   #18
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
I would love to see a front mounted single! Be the first panda!
Pt_killa is offline   Reply With Quote
Old 03-08-2011, 10:32 PM   #19
xpanda305x
Banned
Drives: Dark Knight
ima have to talk to SC
Old 03-09-2011, 01:48 PM   #20
Pt_killa
Pt_killa's Avatar
Found out that there were two kinks in my drain line and my check valves were not sealed properly causing the oil to backup and shoot out the turbos and spray my engine with oil from the feed side. Next time I am just going to pump the oil thruough the oil pan drain to simplify everything and have been known to work well on twin systems using the pump I have. Also, my turbos both had minimal "shaft play" but found out from a specialist that the amount play is normal for a functioning turbo. However, I already put everything back to stock so I won't have anymore updates on this project until the summertime at least.
Old 03-10-2011, 08:43 AM   #21
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Sounds like some good news on the turbos. I know it's a pain to keep taking them on and off, so I don't blame you for taking a break. I'm being forced to do the same right now just because of demands at work. Can't wait to see your update in a few months.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 03-10-2011, 02:42 PM   #22
Pt_killa
Pt_killa's Avatar
I feel you on that one, If I had a shop with a lift things would be very different right now. Getting on the floor and jacking the car up to check each issue got tiring really fast even when I had help. When will you be able to continue troubleshooting your setup? It would be cool to see your setup running perfect before ISP releases their kit.
If I happen upon another powerdyne for cheap I'll use my old brackets and try to finish the SC kit. It was much easier to troubleshoot the SC because everything's in the engine bay and can revert back to stock in less than an hour.
Old 03-10-2011, 07:12 PM   #23
GretchenGotGrowl
Should pick up the part Sat. and i hope to install Sun.
Old 03-15-2011, 04:38 PM   #24
Pt_killa
Pt_killa's Avatar
Hey Gretchen, did you ever get to install the parts?
Old 03-15-2011, 07:54 PM   #25
GretchenGotGrowl
Nope. Been working 7 days a week. Guy that built it said if I can get the car to him he'll do the work, so I may just do that. He's the guy that's going to build the skid plate so it'll be going in his shop at some point anyways.
Old 03-16-2011, 10:30 PM   #26
Pt_killa
Pt_killa's Avatar
That sounds good gretchen let us know how it goes! I just picked up a reverse rotation procharger p600b so I might be back supercharged again soon!
Old 03-21-2011, 09:52 AM   #27
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
do you have any pics of the build when you were doing the supercharger set-up?
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 03-21-2011, 02:21 PM   #28
Pt_killa
Pt_killa's Avatar
My old thread has one pic in it http://www.camaro5.com/forums/showthread.php?t=116284.
With the procharger, the blower pulley will face towards the back of the car and I can use the stock belt system. From there I have two options, if I use a smaller pulley I can just buy a longer belt but will have to bleed off the extra boost and pin the crank. If I use the correctly sized larger pulley, I will have to use a 2-sided 6rib belt and replace the tensioner to a grooved pulley but have the right boost level and not have to pin the crank (even though I will pin eventually). decisions!
I have one more pic of my finished setup with the powerdyne but it is in my old phone. I will post it as soon as I can extract it.
Turbo Technology / Granatelli Motor Sports Twin Turbo Kits Granatelli Forced Induction 109 09-04-2011 12:56 AM
Hellion Twin Turbo L99 Install Photos + Results + Reviews AdamCzap Forced Induction - V8 24 10-04-2010 11:19 AM
2010 Nickey Super Camaro Twin Turbo edition. NicKey 5th Gen Camaro SS LS LT General Discussions 134 07-03-2010 09:29 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
