JUICEDMOTORSPORTS
Old 03-05-2011, 08:29 PM   #1
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
BMR adjustable sway bars stiffness setting question
I'm installing BMR adjustable sways and my question is does anyone know what holes are for what settings? I want to set it for full stiff. Also, does anyone know the torque spec for the engine mount nuts underneath the frame? BMR suggests raising the engine 2" which is GREAT advise! Made the front sway removal and install a breeze! Thanks!
BMRGuy, I sent you a PM!
Old 03-05-2011, 08:43 PM   #2
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
Full stiff...Going to track the car..?
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 03-05-2011, 08:52 PM   #3
ssmike
Missing Big Red
ssmike's Avatar
Maybe an autocross, not sure yet. BMR and Apex Chase recommended setting them full stiff to try first. If too stiff for the street I can always set it to medium. Problem is the BMR instructions don't show which hole is for what setting!
Old 03-05-2011, 09:01 PM   #4
RAYSRT8
RAYSRT8's Avatar
Drives: 2011 Challenger SRT8 6.4L 392 Hemi
I just installed several BMR items and BMR is lacking on install instructions. They need to really step it up in that area.
To answer your question the stiffest setting is the last hole closest to the bar.
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back
Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474
RAYSRT8 is offline   Reply With Quote
Old 03-05-2011, 09:03 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Ray2SS View Post
To answer you question the stiffest setting is the last hole closest to the bar.
Beat me to it. I would suggest starting at the center hole and adjusting from there.
Old 03-05-2011, 09:09 PM   #6
ssmike
Missing Big Red
ssmike's Avatar
Is that true for both front and rear? And your correct about the instructions, they leave you guessing a bit! On the website it gives the stiffness for each hole by number but the sway bar itself is not numbered!??
Old 03-05-2011, 09:11 PM   #7
RAYSRT8
RAYSRT8's Avatar
That is correct anytime you move to the holes closer to the bar the stiffer it gets.
Hope this helps!
Old 03-05-2011, 09:13 PM   #8
Apex Motorsports
It is the same, front and rear.
Hope this helps!
Damn, beat me again!
Old 03-05-2011, 09:15 PM   #9
RAYSRT8
RAYSRT8's Avatar
Old 03-05-2011, 09:18 PM   #10
ssmike
Missing Big Red
ssmike's Avatar
You guys are great! Thanks for the help! Today I installed the BMR front & rear sways, rear trailing arms, rear endlinks, and front radius rod inserts. Just gotta finish the front end links and tighten it all down tomorrow!
Old 03-05-2011, 09:20 PM   #11
ssmike
Missing Big Red
ssmike's Avatar
Do you guys know what the torque spec is for the engine mount nuts?
Old 03-05-2011, 09:21 PM   #12
RAYSRT8
RAYSRT8's Avatar
The only bad part with their end;inks is they are a little noisy over some bumps... Just make sure that you get the torqued to specs.
Old 03-05-2011, 09:25 PM   #13
ssmike
Missing Big Red
ssmike's Avatar
Yea, that's what I've heard! Problem is getting a torque wrench on the lower nuts on the rear ones. I got the top ones to 25 lb/ft ok. Fronts I'll do tomorrow!
Old 03-05-2011, 09:43 PM   #14
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Rear bar set on full stiff and front on softest setting.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
New lsr performance adjustable sway bars. Best deal hands down. 2quick Suspension / Chassis / Brakes 88 08-18-2010 07:30 AM
MTI sway bars flht99b Suspension / Brakes / Chassis 10 03-29-2010 04:33 PM
Pfadt or Eibach DTS2SS Suspension / Brakes / Chassis 9 01-22-2010 01:07 PM
sway bars question shad2009 Suspension / Brakes / Chassis 6 12-14-2009 08:42 PM
