sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Camaro Fest VIII Discussions > 2011 Camaro5 Fest (II)
Old 03-06-2011, 07:08 PM   #15
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Originally Posted by csjcsj View Post
Camaro21 ran low low 12's all day long at the first fest and never wore a helmet! But go on motorcycle superstore.com and go in the closeouts! May can find one for $30 or $40! As long as u gotta head cover they want say anything!
Motorcycle helments rarely meet the SA requirements for Drag Racing or road racing. Entirely different helmet. Racing helmets are going to be a couple hundered to start. Great idea though.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 03-06-2011, 07:11 PM   #16
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Mine was $50 total.
Old 03-06-2011, 07:11 PM   #17
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Hopefully none of you guys will have a reason to actually put the helmets to a test.
But, I would not go for the cheapest model I could find, when it comes to protecting my melon.
Just my opinion
Fishdadddy is offline   Reply With Quote
Old 03-06-2011, 08:13 PM   #18
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Originally Posted by Milk 1027 View Post
I'm all stock. But it's required for the Pfadt track attack. So, I just got the cheapest one I could get. It just depends on what you are doing. You might not need one for the 1/4 mile.
I'm REALLY hoping to get a slot for Pfadt day... 1/4 is the one that makes Eme the most nervous, and also where stuff tends to get broken, so at most I'll probably only do one pass.
Old 03-06-2011, 08:25 PM   #19
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Here in commerce. Ga everyone with a street legal car wears a motorcycle helmet while racing! Don't think anyone wants to pY a couple hundred bucks for something used a few times a year, and they don't check them!
csjcsj is offline   Reply With Quote
Old 03-06-2011, 09:53 PM   #20
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
When we did the drag racing at Firebird during the Super Chevy Show last October, they required helmets for everyone regardless of how fast you ran and checked for SA 2005 or 2010 certification during tech inspection. I think it was the tracks rule.
So Cal Camaro is offline   Reply With Quote
Old 03-07-2011, 12:01 AM   #21
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
They were strict with the Dot3 sticker in autocross last year. If no sticker, no use helmet! Just fyi.
CruznSS is offline   Reply With Quote
Old 03-07-2011, 12:48 AM   #22
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Since no one will answer me in the Pfadt thread, is this ok?
Old 03-07-2011, 03:28 AM   #23
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I don't believe so... I think it has to have the year and or SNELL rating on it... the oldest it can be is snell 2000 or something close to that...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-07-2011, 06:31 AM   #24
2010 SS RS
2010 SS RS's Avatar
Bingo. Most tracks hae to follow NHRA or SCCA regulations due to their insurance. I know that here in Colorado they will check the interior of the helmet for the SA rating which is not in a motorcycle helmet. Here is the written requirements direct from Firebird.
10. Helmets: Drivers of all vehicles running 13.99 or quicker, and ALL convertibles regardless of E.T., must wear an SFI-approved helmet with a Snell rating of 2000 or newer. Passengers in convertibles running 14.00 and slower must also wear an approved helmet. (Note: DOT-only helmets are not permitted. SFI-approved helmets are not permitted if the Snell label inside the helmet is missing or illegible. In other words, a Snell-rating on the outside of the helmet is not good enough.)
As of February 1, 2006 all vehicles with an aftermarket power adder, (nitrous, turbocharger, or supercharger) running faster than 13.99 will be required to wear an SFI approved fire jacket
I did notice the web page was not updated since like 2007 and the nhra rule and the scca rule is a 10 year limit on rating so I am betting it will be a snell 2005 or 2010 rating to qualify.
http://www.firebirdraceway.com/web/streetdrags.html
Old 03-07-2011, 06:44 AM   #25
2010 SS RS
2010 SS RS's Avatar
I'm sure if you make a 10 sec pass a roll cage will be required... Trying to find out what those limits are..
...and at what time do you have to have a helmet? 13.5 or faster..
NHRA and it looks like Firebird follows their rules so
13.99 helmet required
11.49 rollbar required
powere adders helmet and jacket required
Old 03-07-2011, 08:16 PM   #26
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
THANKS.. exactly what I was looking for... and just wanted to make sure everyone is prepared...
They were not strict at all in GA, I was running high 12's w/ no helmet or jacket, but my guess is it will be by the book in AZ.
A lot of folks will have helmets but Jackets may be missed... Here's a link to a good one..
http://www.summitracing.com/parts/GFR-4381XLGBK/
Old 03-07-2011, 09:20 PM   #27
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
OK. But I'm talking about the Pfadt track day. They said, as long as it's Dot approved. Seriously, I just want someone to answer me, so I can send this back if it's the wrong one.
Old 03-07-2011, 09:27 PM   #28
mlee
www.CamaroFest.org
mlee's Avatar
Depends on who they is... Pretty sure the answer will need to come from Firebird.
Why buy it if you know it won't be good everywhere.
SFI 31.2/2005 is another rating tech looks for on the inside of the helmet.
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
Are all Honda drivers d***heads? 2Muchmark Off-topic Discussions 46 04-07-2010 08:02 PM
ambient lighting on drivers door is defective. edog Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 08-10-2009 07:07 PM
a picture says a million words, not any more nimnels Camaro Photos | Spyshots | Video | Media Gallery 47 05-11-2009 04:49 AM
