BeckyD @ James Martin Chevy
Old 03-20-2011, 08:07 PM   #29
The Stig
knows 2 facts about ducks
The Stig's Avatar
OK so I started today planning on painting my door panels and dash trim. Following one of the DIY I was able to get my door panels off in just under an hour. Here are a couple shots of Kaylee with her panels off.
So after I got all of these panels off I went to unscrew the door inserts. Well it turns out that only 3 screws hold the inserts in place, but about two dozen melted plastic studs.
Needless to say I was pretty PO'd with the situation. But I figured that while I had the door panels off I could do a mod that I had put on the back burner about a year ago. I used some AAC ABL colored LED strips and tied the wiring into the ambient lighting. So while I didn't get to paint, the day wasn't a total loss.
Day 2 of my modding marathon is almost over. Depending on how things play out tomorrow I may be painting my wheels, but Just need to see if I have the time to do it all.
Click to view my build thread
Old 03-20-2011, 08:18 PM   #30
MANAWAR
MANAWAR's Avatar
Drives: 2010 Black Camaro 2SS/RS
Nice looking Camaro......
Philadelphia Phillies Fan
GPC
MANAWAR is offline   Reply With Quote
Old 03-21-2011, 09:26 AM   #31
10spokess
Wild and Cammed
Drives: 2002 Camaro SS
so you wont be painting the door pannels now?
10spokess is offline   Reply With Quote
Old 03-21-2011, 10:09 AM   #32
The Stig
The Stig's Avatar
Not unless I can figure out a way to take them off without breaking them.
Old 03-21-2011, 04:45 PM   #33
The Stig
The Stig's Avatar
UPDATE:
So I did some hunting and I found a DIY by BumbleBeeSS2009. Here is the link. Post number 2 - 6 about cover how to deal with the plastic rivets problem that I encountered yesterday. So, I'll be stopping by home depot a little later tonight to pick up some of the screws I need for the swap and tomorrow I will be painting
My finding this goes to show, for whatever mod you want to do odds are someone else has already done it and posted a DIY and/or instructions on how to do so.
Old 03-21-2011, 10:30 PM   #34
The Stig
The Stig's Avatar
So drove around a bit tonight to see what the new ABL pockets looked like. Honestly I'm not feeling it. Its a it too bright if you know what I mean.
So I need to figure out what I'm going to do now. I'm picking up the screws needed for the door panels tomorrow morning and will be painting them. So I guess I'll figure it out then.
Old 03-22-2011, 05:05 PM   #35
The Stig
The Stig's Avatar
Some pics of Kaylee's front end disassembled.
Some of the headlights taken apart.
Needed to take a food break so I'll be finishing up the wiring later today/tomorrow.
Wiring Instructions: Dual Halos on a Single Switch
Wiring Instructions for AAC Halos (Single Color)
Things you Need:
  • (1) wire cutters/strippers
  • (1) wire coat hanger or straight wire rod
  • (1) LED rocker switch (or any switch, your preference)
  • (2) short lengths of black wire #2 and #3
  • (1) length of black wire, #1
  • (1) length of red wire
  • (2) yellow wire caps
  • (X) assorted t-taps/splice connectors
Installation Instructions:
1) First, congratulations on installing your halos. It is not an easy task.
2) We are going to start with the red (+) wires coming from each halo. You should have (2) red wires in your hand now, one from each fog light. Check the ends of these wires, if no copper is showing then you need to strip them. This can be done with a wire stripper, or any sharp knife. Once you can see the copper wire move onto the next step.
3) Now pick up the length of red wire from your kit and a yellow wire cap. You want to use the yellow wire cap that has a (+) drawn on it. Take hold of both red (+) wires from your halos (make sure that you have stripped them) and the red wire from the kit. Now twist them all into the yellow wire cap. Make sure it is nice and snug.
4) Take the length of red wire from the kit, now attached to the yellow wire cap, and run it to the positive post on the fuse box. This is the metal post near the front of the fuse box.
5) Put the ring terminal, marked with a (+) near this post. You will bolt it to the post at the end. You don’t want to fry yourself installing this wiring.
6) Take the two black (-) wires, one from each halo, and the black wire marked #1 in your hand.
7) Strip the two black wires coming from your halos if they have not been already.
8) Take the ends of the two black halo wires and the end of wire #1 and twist them into the (-) yellow wire cap. Make sure it is nice and snug.
9) You will need a stiff piece of metal for this next part. A wire coat hanger is best.
10) If you are using a wire coat hanger, please do the following steps.
a. Straighten the wire coat hanger.
b. Use wire cutters/hedge trimmers to cut roughly a one foot piece of straight coat hanger, we will call this piece “wire rod”
c. Using needle nose pliers make a small bend creating a small loop one end of the wire rod.
d. Continue to step 11
11) Looking in the engine bay, find a rubber gasket on the firewall that has wires going through it. These are very easy to locate, just trace some wires back to the firewall and that is it.
12) Using the black wire from step 8, put the spade terminal end (end with the blue plastic part on it) into the loop on the wire rod.
13) Using the other (non loop end) of the wire rod, push it through rubber gasket you found in step 11. It will take a bit of force but that is OK. You are not breaking anything, so don’t worry.
14) Once you have it about half way through the rubber gasket go inside the cabin of the car. Looking underneath the steering wheel, locate the part of the wire rod that is sticking through.
15) Pull the wire rod and wire number 1 through the firewall.
16) Remove the driver’s-side side panel for the center console. It is held in with clips, so just pull it will pop right off.
17) Looking at where the center console meets the dash you should see a bolt with a marker mark on it. That is your ground.
18) Unscrew the nut (13mm) and mount the ring terminals of wires #2 and #3 ring to this bolt. Rescrew the nut onto the bolt.
19) Now we will be mounting the switch. So first step, pick where you want to mount the switch. May I suggest the side of the center console (the side wall plastic panel.)
20) Using a 11/16 inch drill bit drill a hole in where you want to mount the switch.
21) Collect all 3 black wires. You should have a hold of (3) blue female connector terminals. These are labeled #1, #2, #3.
22) Looking at the switch, you will see that the spades are numbered #1, #2, #3.
23) Wire #1 goes to spade #1, wire #2 goes to spade #2, and wire #3 goes to spade #3.
24) Once all of the wires are connected push the switch into the hole. Be sure that you have it nice and straight.
25) Going back to the engine bay. Bolt the red (+) wires ring terminal to the positive post in front of the fuse box.
26) Your wiring circuit should now be complete. Go into the cabin and flip the switch. The LED on the switch should turn on, as well as your halos.
Old 03-23-2011, 01:28 PM   #36
The Stig
The Stig's Avatar
I drove up to Erie today to visit the body shop at Dave Hallman's Chevrolet and man am I impressed. They were super nice and friendly. I showed them the paint chip spoiler TSB and they were more than happy to repaint my trunk lid. They actually have already redone a few camaros so they knew the drill.
I completely forgot to ask them if they could install my street scene spoiler. (Had to take it off to show them the chipping and just put the stock back on to make things easier). Hopefully they will be able to do all that for me. I might also get a price quote for them to paint the door and dash trim gloss black. Save myself the hassel of a DIY.
Not going to lie, I have been pretty mod crazy this week. The worst part is that I wouldnt want it any other way.
Old 03-23-2011, 01:46 PM   #37
The Stig
The Stig's Avatar
Also, I want to touch on safety and the use of proper protective equipment when handling power tools. When I was installing the OEM halo ring over my LED halos I had to cut the bottom portion of the OEM halo so that it would fit in front of the LED halo. I attempted to cut the plastic halo ring with a sawzaw. BAD IDEA.
I ended up cutting my thumb pretty bad from the splintering/melting plastic. Took a safer route and used bolt cutters. Much better idea, worked like a charm and no further injuries.
Old 03-28-2011, 04:32 PM   #38
The Stig
The Stig's Avatar
Just got off of the phone with Jonathan at Advanced Automotive Customs and the paperwork for my partial sponsorship is all done. So I am officially sponsored by AAC, partially at least.
I figured it was good enough news to put into the journal. That and I have a few more pictures to boot. I haven't yet gotten around to wiring the dual halos up again. I have fieldgoal's wireless DRL harness, but it's currently not really working. So I'm on the fence with the following
1) wire the halos up to the remote box and turn them on that way
2) leave them plugged into the parking lights and they are only on when the car turns them on
3) Then my third option, is I can rig up a switch that runs power from the fuse box and then just change the colors of the halos via the remote box. This way I would still be able to leave them tied into the parking lights.
Old 03-30-2011, 11:34 PM   #39
The Stig
The Stig's Avatar
I pulled Kaylee into one of the empty bays at the fire station to do some wiring. I recently bought fieldgoal's wireless DRL harness, but had been having problems with it. Jeff (Fieldgoal) suggested that I take it out and send it to him so he could look at it. Well what do you know, I'm getting to taking it all apart and bam! I find out the the ground for the harness isn't screwed in all the way. Needless to say I fixed that problem and shazam! Wireless DRLs.
With that set up I'm thinking about redoing my wiring set ups. I could just run my RGB scanner ground to the remote box and control it that way. Instead of having a switch for it on the center console. Then I could also wire all of the halos into the remote as well, not sure if I like that idea yet. But we will see.
I'm just happy I figured out why the harness wasn't working. Damn thing was expensive.
On another note: Lets talk modding.
I have been exchanging emails with Jason from Grabiak Performance Center and I've got a long list of mods that I'm looking to get done.
- powder coat wheels black chrome or gloss black. I'm going with powder coating because A) it doesnt cost too much and B) its more durable.
- repainting trunk lid (spoiler chipping) and reinstalling my street scene spoiler.
- powder coating my calipers cobalt blue. Again more durable than paint.
- possibly ACS T3 bumper ports
- SURPRISE. I need to talk to Jason to see if this is possible, but I really really hope it is. Lets just say I'll be the 2nd camaro with this mod
Old 03-31-2011, 05:15 PM   #40
The Stig
The Stig's Avatar
Really excited, so I just had to post this even though I haven't technically done it yet. I figured out how to have my halos work as DRLs and my DRLs be off.
I am tapping the sets of halos (headlights and fogs) power supply into the DRL positive lead. This is essentially doing the same thing that AAC's DRL harness does. Having the halos and the DRLs on at the same time. But, this is where I have to give myself some credit. By using fieldgoal's harness I can disrupt the ground in the DRL circuit. Thus turning them off. But the halos are still receiving power from the DRL's positive.
Old 04-02-2011, 02:11 PM   #41
The Stig
The Stig's Avatar
No updates today, as of yet. I will be doing the wiring for her halos later this evening/afternoon. Have to do some "real" work first. But I wanted to do this before anything else, mostly because it has been bugging me FOREVER, and here we go...
So I requested to have my build thread combined with Kaylee's journal from this past summer. Thank you to Milk for helping me with that This doesn't really add anything new to my build thread, but it gives you the back story to Kaylee and my time with Eleanor. Hope you enjoy
Old 04-04-2011, 01:25 PM   #42
The Stig
The Stig's Avatar
Yesterday I installed a separate clutch fluid reservoir, on the recomendation of 2SSRS. But, I ended up using the instructions from flht99b. Here is is post on how to do it
Then I also did the glove box light install. Via these instructions Ended up not being able to get it to light up. It worked fine on the work bench though. I will have to do some more digging to find the right wire to plug into, I think that may have been the problem. Needless to say that I got pretty frustrated with being all contorted underneath the glove box and with having a flashlight in my face, etc etc. So I had to cut it short and will be picking up on it later tomorrow/Wednesday.
aac, advanced automotive concepts, ashen gray metallic, bad@sszl1, black chrome, boom, build thread, carbon fiber, cotw, fireball, gen5diy, kaylee, pedders, phantom black metallic, sad, the stig, this guy needs a lithograph, zl1
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
Official AustinJames "Oh My Bad" Camaro Thread [COTW 1/2/12] austinjames Member Car Journals 202 12-12-2014 10:14 AM
Zabo's '00 T/A Build Thread CamaroSpike23 4th Generation Camaros 514 07-05-2013 12:26 PM
3rd Gen Camaro Street Stock build thread (dialup beware) zlathim 3rd Generation Camaros 7 02-20-2013 12:04 AM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
