R1 Concepts
Old 03-08-2011, 06:26 PM   #1
Wink2010
Wink2010's Avatar
Drives: 2010 2SS/RS LS3
JBA Axle Back Installation Question
Hi
I've purchased a set of JBA 40-3112 axle back exhaust after listening to a bunch of different axle back exhaust systems. In the installation instructions it states "Using a reciprocating saw, cut the factory exhaust assembly in line with the the rear differential housing as seen here". (a small black and white photo) I'm a bit nervous about cutting them evenly.
My questions are:
1. Has anyone installed this exhaust assembly?
2. How did you accurately determine where to cut the factory pipe on both sides?
Thanks in advance!
Gary
2010 JEGS Sweepstakes Winner! JBA Axle Back, HalltechYellow Jacket, Adaptive Performance Skip Shift, Elite Catch Can, BMR Trailing Arms, Clutch Fluid Reservoir
Wink2010 is offline   Reply With Quote
Old 03-08-2011, 07:23 PM   #2
indigloflow
indigloflow's Avatar
Drives: Summit White 2ssrs inferno
I installed the the slp loud mouth 2 system, and cut them with a sawzaw you can locate something to measure off of to make sure get them both cut in the same place.
Is far as being worried about cutting them at a slightly different angle, I wouldn't be concerned, because if one is off a little from the other, the clamp allows you some adjustment, is far as getting your tips in the same location exiting the rear valence.
Hope this helps.
indigloflow is offline   Reply With Quote
does the pypes-bomb axle back fit the v6? jgflores35 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 30 03-18-2011 11:25 PM
FS: Borla S-Type Axle Back Exhaust 11775 for '10/'11 Camaro SS shiftz33 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 8 01-18-2011 06:24 PM
Trade: My SLP Loudmouth 1 Axle Back for your? hoffmk2003 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 5 01-06-2011 06:45 AM
JBA Axle back?????? DANS2010BLKCAMARO Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 12-20-2009 09:37 AM
Question about CAI's and Axle Back add ons Mr Smith Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 10-18-2009 11:28 PM
