Frankenstein Engine Dynamics
Old 05-12-2011, 06:05 PM   #281
GearheadSS
Member #63
GearheadSS's Avatar
Drives: 1969 Chevelle SS
Awesome read, Kyle.
That sucks about your ordeal with XHP. You're not the first person I've heard that has had a bad experience with them. I've seen a lot shops like them over the years and the ones like that, don't stick around.
Jeff Blain-Inventory Manager @ Britain Chevrolet
My Available Camaro Inventory
jeffblain@britainchevy.com
1969 Chevelle SS 454-4 Spd., Triple Black
2016 Camaro 1LT 2.0T-A8, Triple Black
GearheadSS is offline   Reply With Quote
Old 05-13-2011, 02:09 AM   #282
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
Good stuff bro!
GMtothecore is offline   Reply With Quote
Old 05-13-2011, 07:53 AM   #283
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Busted!!!!
Looks like the GM photographer got a pic of the LSX getting a speeding ticket..
Old 05-13-2011, 08:20 AM   #284
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
oh crap... they got some...
oooooh well.
Live Laugh Love...
or is is Live and Learn.. i dont know... i still had lots of fun that day
Old 05-13-2011, 08:48 AM   #285
racer778
Camaro Sold
racer778's Avatar
Drives: 2010 camaro 2SS/RS
Kyle, if you swing by dayton anytime soon HOLLA at me. I will be here for a month or so. got a ticket myself on the way to Ohio. couldnt talk him out of it, first ticket in years, oh well youve got to pay to play.
racer778 is offline   Reply With Quote
Old 05-13-2011, 08:51 AM   #286
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Gah... I'm still ticketless... :fingerscrossed:
Leave it to mike to share it with 40K others.
Old 05-17-2011, 01:53 PM   #287
Kyle.Gilmour
write up I did for my new ARD Trans
Soooo… it happened again…. At CamaroFest I messed up another clutch. But mind you I do not take responsibility in either occurrence. Hahaha.
At Fest 1, I just had too much power for the stock clutch, so the failure was almost expected.. almost
For Fest 2, well that was still under investigation until a few days ago when Monster said they would not warranty my clutch because there was organic material on it (oil) and this was due to improper installation. I will give you one guess as to who installed my clutch… if you read the first few posts of my build thread you will know.
Anyway, with my whole transmission already out of the car, it did not take much convincing from Russ/Deaver/Mike/Jason/Ronnie and even Owen to push their ways on me and convince me to put an Automatic into Detroit Muscle. Owen from ARD in Houston built up his own 4L80E and built it to RUN!!
To put in perspective, Owen’s daily driver has this same transmission and he has not had to touch the tranny in 2 years….. oh, and his car is well over 1000 rwhp and I believe… 4th fastest 5th gen in the world. So I was pretty stoked to have something similar in my car.
From what I hear the build went fairly smoothly, other than actually getting the yolk, but in the end, the Drive Shaft Shop came to the resuce and theirs turned out better than what was going in. Owen’s transmission went into an Automatic Camaro with a few headaches here and there, but it turns out that installing a 4L80E into a Manual Camaro makes for a much easier and cleaner build.
Below are pictures of the transmission, the B&M Proratchet shifter with LockUp mechanism, and a few internet shots of the hardware I did not have actual pics of.
4l80E: ARD stage 3 (manual)
• 3800 stall Circle D multi disk billet
• Upgraded servo piston
• Carbon rear band, carbon lined coast band
• Alto red eagle Power packs all forward gears
• 36 element sprag drum
• Trans Go 4l80E-3 full manual valve body kit
• New lower roller sprag
• New overdrive sprag roller type
• New Borg warner High energy 4th gear clutches
• All new bushings and seals
I do love the new transmission, it is fast and keeps me in boost pretty much all the time when you are above the stall converter. I have not been to the track yet, but with this, it will be almost impossible not to run mid-10s.
There are a couple downfalls to it though.
• The MPG, we expected it to drop a couple miles per gallon, but it was almost 7-8 mpg at 70mph. Even with the LockUp it still does not drop the RPMs low enough. I think another reason for this is the stall converter; quite a bit of fuel is used at lower speeds. I was getting at best, 21mpg with 708rwhp. Now with the new trans I am getting 14.5 at 70mph, if I drop it to 60 and use cruise control I can muster out about 17.5mpg. So this was a bit of a surprise for me, but you got to play to pay as we all know.
• Tranny noise – there is definitely a lot more road noise, especially in first gear, but this is all expected when dealing with the high performance parts that we have.
So those little things set aside… I love the transmission and to know it is “bulletproof” (hope I did not jinx myself) makes me feel secure that it will last a long time even with me beating on it.
I picked up car on a Friday night, Owen took me for a “spin” literally, hahaha. He showed me how it drives, and how to use the ProRatchet shifter. This took me a few hours to get into the groove, so I didn’t have to count what gear I was in. Those that have used this type of B&M shifter know what I mean. The LockUp feature, for those that dont know what it is, is described as “A lock-up clutch physically links the impeller and turbine, effectively changing the converter into a purely mechanical coupling. The result is no slippage, and virtually no power loss.”
I have an on/off switch on my console that I can use to LockUp when I am driving at highway speeds to help reduce my RPM and increase my MPG. It is a great feature, but I learned the hard way… you have to remember to turn it off before coming to a stop. Hahahaha
So, I headed over to Mlee’s house to have dinner with DaHose and DangerRuss that night, we also cleaned the car so it was ready for the Houston 2011 Camaro Convertible GM Media Event the next day. We had a blast at the event, but I tell you what… that new tranny helps me hit speeds much faster….
I am sure if you Search hard you can find some pictures proving that
So all in all, I am very pleased with my new automatic 4l80E ARD stage 3 (manual) transmission, the fit and finish that Owen puts into this is fantastic. Nothing was affected, the cruise control still works, the trans temp reads accurate, tires spin uncontrollably, and the stitching he did on my stock shifter boot is ingenious!! All I do is have to hit the throttle part way and I am off like a rocket in a straight line, when i get to the rev limiter I just smash the shifter forward, then again, then again. It is way different than having to lift and shift.
One more point to how great of a shop ARD is, my B&M shifter broke the second day, no fault at all associated with ARD, it was just a bad mechanical part. Owen sent his driver and mechanic to Austin to pick up my car, brought it back to Houston and welded up inside of the shifter to make it better than it originally was. Then brought it back to me the day before I needed it for a Cruise in my honor (going away party cruise). I cannot express how genuine and caring this shop is.
PICS BELOW -
The shifter pic does not show the LockUp button on the console, must not have been installed at the time of the pics, but there is also an intermediate LockUp button on the handle of the shifter
Oh, and I through in my Dyno sheet WITH the auto and Meth Injection.
Old 05-17-2011, 01:55 PM   #288
Kyle.Gilmour
http://www.camaro5.com/forums/showthread.php?t=147719
Old 05-17-2011, 02:12 PM   #289
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
That looks gay.... lol j/k
Very nice Kyle ! Looks like a first class rebuild, install and tune.
You must be having a blast with that. If people really knew how fun an auto can be, I bet you more would go that way. A stock tranny/converter/shifter is one thing, but once you set it up for some serious hp, they are just a blast to drive. ...and yeah, you aren't the only one who has forgotten to unlock the converter and sometime forget to put the tranny back in first at a light... Have done that on a few cars in the past.
But overall glad you are enjoying it. Like a brand new toy !!
Old 05-17-2011, 02:13 PM   #290
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
Awesome bro. I've been wanting this for months, but you beat me to it.
BTW...parts are on order for mine as we speak!
Old 05-17-2011, 02:13 PM   #291
garcmol
garcmol's Avatar
I only understand "it's faster". That's good enough for me. Really though, I don't understand the automatic manual transmission. You just step on the loud pedal and bump it to the next gear when ready? Forgive my ignorance, I'm just figuring out suspension parts.
Old 05-17-2011, 02:17 PM   #292
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Yea...the 4L80 is really the best of both worlds. You get the thrill of shifting without the clutch. The shift is immediate which means you can stay in boost as you shift.
With the shifter Kyle has you simply push forward to upshift and pull back to downshift. There are some things to learn to get to reverse and park, but it doesn't take long to get used to.
Old 05-17-2011, 02:18 PM   #293
speedster
SST...
speedster's Avatar
Kind of a Manumatic...
Old 05-17-2011, 02:20 PM   #294
garcmol
garcmol's Avatar
Okay, now I know what he means by staying in boost, no lifting. That is cool. So what does the little toggle next to the B&M shifter do?
Sounds Dr Evil~ish
427, camaro of the week, detroit, gilmour, texigan, the circle, the mother of all twins
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 12:05 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Off-topic Discussions 0 07-28-2010 08:28 AM
Detroit muscle question xxbrankxx General Automotive + Other Cars Discussion 3 08-19-2009 12:08 AM
Sad day for detroit muscle.. Corvette next to be axed? camarofanatic General Automotive + Other Cars Discussion 33 05-03-2009 06:43 PM
Top Gear - Dodge Challenger & American Muscle Cars Tran General Automotive + Other Cars Discussion 8 04-24-2008 10:48 PM
