Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 03-09-2011, 09:30 PM   #1
Supercharged SS
Drives: 2010 Camaro
FS: TVS 2300 w/ 8 rib and OD rear cog
I'm putting this out there to see if there is any interest. Everyone knows that Ted is involved in every aspect of my car and the blower is no different. It seems that the good ole 2300 is having a hard time making the 17+ psi we are looking for. Magnuson has even told us that we are well within the blower's limits but at 16psi or so we get belt slip. We are trying everything possible but just in case I want to at least get the word out that there is a very good possibility that this will be on the market. If we do find a cure then I will update this thread imediately!
I do love this blower to death and the only reason that it will go is becasue we, and the engine have outgrown it. It's makes gobs of torque right off idle and even at 12.5 psi it got my car down the 1/4 @ 10.19.
With that being said I guess we need the details. Obviously you will get the blower and every part that is needed for a quick install. Now I do have an SCT but I would need to check to see if I still need that. I don't think so seeing that I am 10 minutes from Ted and making any future changes wouldn't be hard. But again, I would need to look into it. The only other thing that would be needed would be the injectors. I traded mine in for the ID 850's. I'm know Ted will work with the buyer to get you the best deal possible on these. I may also be able to help with the cost. Maybe split the cost? Something like that. I also have the Innovators west 8 rib set-up and either a 3.2 or 3.4 pulley. Most of you that are looking surely don't want either of those so we could get you a 3.8 that with the OD rear cog would get you a "safe" 10 psi with great belt wrap and zero slippage. And of course, the blower whine is great with the cog drive in the rear. The IW is about 1500 with the blower pulley and the OD cog was $350.
And of course with this you will get the best customer support in the business today and help with the install if needed.
I'd like to get $5500 for all of the above shipped to anywhere in the lower 48. And like I said I will help with the injectors becasue they come with the blower when bought new.
Any questions just ask. I'll do my best to answer or just pass them along to Ted. Again, this is prob 50/50 right now. They still have a couple things to try first. But If someone really does want it then its theirs.
Thanks guys, Jamie
Old 03-10-2011, 08:53 AM   #2
Bossmanz07
Bossmanz07's Avatar
Drives: 2010 Camaro 2SS Supercharged YSI
Do have a faster time with your built motor and more boost....but 16psi of boost should at lease 900rwhp with manual or 850rwhp with automatic.
Bossmanz07 is offline   Reply With Quote
Old 03-10-2011, 09:14 AM   #3
Supercharged SS
Drives: 2010 Camaro
No sir. The car hasn't been tracked since the forged engine was done. Last time it was tracked, successfully the car was @ 625 rwhp. That's was the best it did of 10.19. It also did a 10.3 and about 15 passes of 10.5. Then we went back to the track with some more rwhp, still on the stock block, and the 4.10's and popped a piston. Game over. That's when Ted did the new engine and that was last Nov/Dec. I'm patiently waiting to go back.
Old 03-10-2011, 10:43 AM   #4
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
How many miles? How many track runs? Is there a way to have Ted or Magnussen verify that internals are working properly and within proper thresholds. My plan is take this install it on my A6 for now, and down the line cam, meth and crank up the boost. Let me know ASAP.
tsears is offline   Reply With Quote
Old 03-10-2011, 10:52 AM   #5
Supercharged SS
Drives: 2010 Camaro
6k miles. Approx 30-35 passes with the blower. I would have to ask Ted or pm Jon from Magnuson and check but I would think if its working fine on the car now it would work fine on another app. But I do understand where you are comming from. As for cranking up the boost, how high do you want to go. We are having a hard time getting to 18 psi. Currently Ted is on the dyno right now working on it as he has been for the better part of three weeks. It made 14 all day long with zero slippage. But who can live with only 14 psi!!!
Old 03-10-2011, 11:35 AM   #6
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
SCSS why dont you just put nitrous on it
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 03-10-2011, 12:24 PM   #7
tsears
tsears's Avatar
Planning on running 10psi in a normal application. Meth injection I'll probably up it to 12psi.
Old 03-10-2011, 01:47 PM   #8
Supercharged SS
Drives: 2010 Camaro
Easy there cowboy! Don't give Ted anymore ideas! I
Old 03-10-2011, 01:48 PM   #9
Supercharged SS
Drives: 2010 Camaro
10-12 psi you could spin a 3.8 on the front and be money. No slippage at all. We are exploring a few things and just waiting for some answers at this point.
Old 03-10-2011, 02:18 PM   #10
tsears
tsears's Avatar
Sounds good. Let me know. I got cash on hand and an installer ready. :-)
Old 03-10-2011, 04:23 PM   #11
klatterblast
SSCS did you and Ted try a solid mount (no spring) belt tensioner, just curious to know if they work better or not.
Old 03-10-2011, 04:57 PM   #12
Supercharged SS
Drives: 2010 Camaro
Yup, and it sucked worse that the stocker! We tried it today.
Old 03-10-2011, 05:07 PM   #13
Supercharged SS
Drives: 2010 Camaro
Originally Posted by bigcamaro View Post
you better buy a bigger blower in case i ever clean the dust off my transformer camaro.
We are stuck at a lousy 17 psi!!! What good is that. I need 20.
Old 03-10-2011, 05:09 PM   #14
klatterblast
Really well i guess the mad scientist is at his drawing board now
