JUICEDMOTORSPORTS
Old 06-06-2011, 05:21 PM   #57
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by jdenotter View Post
Oh I drive the hell out of it lol.
Sent from my DROIDX using Tapatalk
Then, yes. It would be worth it.
Old 06-07-2011, 12:45 AM   #58
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Old 06-07-2011, 10:02 AM   #59
caverman
caverman's Avatar
Drives: '69 SS Convertible
Found both a 24mm and a 15/16 over at my dad's shop last night. I was working on my '69 so I didn't have the '10 with me to test fit the sockets.
I hope to be installing the inserts this weekend depending on when my parts get here. Cradle inserts and sway bars all in one day. I'm sure I'll feel a difference then.
Build Journal
Old 06-07-2011, 10:42 AM   #60
Synner
Drives: not stock
About how much does the entire rear differential and cradle assembly weigh? Would a 1500lb motorcycle jack be able to support it? I'm debating if I want to try and tackle this or not. I'd do full replacements versus inserts so the whole thing has to come down.
Old 06-07-2011, 11:51 AM   #61
BMR Sales
BMR Sales's Avatar
Drives: Race Car
You could definitely use a motorcycle jack to support the rear cradle when doing the bushings. The full bushing replacements can be a bit of a pain to install but there are quite a few reviews with step by step instructions here on Camaro5 that show some tricks for making it as easy as it can be.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 06-07-2011, 12:23 PM   #62
PQ
Booooosted.
PQ's Avatar
No doubt. You'll feel a huge difference. Take some hard turns before and then the same turns same speed afterward. You'll be glad you did.
Old 06-07-2011, 06:32 PM   #63
Synner
Drives: not stock
OK thanks. I just didn't want to have to buy a tranny jack for a single use. I'm out of room in the garage for more tools/toys.
Old 06-07-2011, 06:36 PM   #64
PQ
Booooosted.
PQ's Avatar
Just make sure you keep at least one or two bolts partially in no matter what you do. If the cradle were to rock free, might be a major pain if you are alone.
Old 06-07-2011, 06:38 PM   #65
Synner
Drives: not stock
Well if I do full bushings then the whole thing needs to come down right?
Old 06-07-2011, 06:40 PM   #66
L99CAMA2011
L99CAMA2011's Avatar
Yes It would. I had my rear cradle Pedders bushings installed yesterday and I kind of wished I had went with the stiffest option, no biggie , inserts however I honestly wouldn't even bother.
Old 06-07-2011, 06:43 PM   #67
PQ
Booooosted.
PQ's Avatar
That's right. I forgot you were. I guess it depends how you plan on getting the old ones out. They look pretty stout. LOL
You mean inserts?
Old 06-07-2011, 06:56 PM   #68
Synner
Drives: not stock
The same way everyone else does it. Cursing, bloody knuckles, and lots of beer.
Old 06-07-2011, 06:58 PM   #69
PQ
Booooosted.
PQ's Avatar
Old 06-07-2011, 09:41 PM   #70
JusticePete
VIR Specialist
Nope. Sawsall out the core by inserting a rough cut blade into the hollows of the sub-frame bushes. With the core out saw through the fiber reinforced plastic jacket vertically to the metal of the sub-frame. Make a second cut about an inch or two away. Use a pry tool to break out the cut section. With that section out you can easily fold in the remianing bush jacket.
There is no need to drop the sub-frame!!!!!
Installing BMR Pro Cradle Bushing LS3*LLY Suspension / Brakes / Chassis 14 03-10-2011 09:53 PM
Subframe Bush Upgrades. From Simple DIYer to Full Race Capable Info@PeddersUSA.com Suspension / Brakes / Chassis 16 05-03-2010 10:29 PM
New to Suspension (look over list please) Brokenlizrd Suspension / Brakes / Chassis 19 04-24-2010 12:31 AM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 01:14 AM
