Emblempros
Old 02-12-2009, 11:22 PM   #1
nickspohn
nickspohn's Avatar
Drives: 2002 Camaro
My Turn Signals...
Okay, I got my 2002 Camaro back out of storage about 3 weeks ago. About a week ago, my blinkers on the inside (both the left side and right side) would blink like they were dying. Like "blink..... blink blink blink" almost like it was dying. This would reflect on the lights outside as well. Whatever sequence blinked on my dash, would blink on the outside the same.
So today, I go and use my signals, and neither side works. The ones on the inside don't turn on, or click at all. My hazards work completely fine though, and all the lights are lit up. The hazard lights light up on the inside too.
What should I do? I never realized how important turn signals are.
And it's not a fuse. My fuses are all fine.
Debating, either a Corvette or Camaro
nickspohn is offline   Reply With Quote
Old 02-12-2009, 11:32 PM   #2
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
Sounds like a bad bulb. Check all the bulbs and did you change any recently? I put one in backwards once and it acted like that. An incorrect bulb may do the same thing.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 02-13-2009, 08:26 AM   #3
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
I'd start by replacing the bulbs.
Moose is offline   Reply With Quote
Old 02-13-2009, 09:48 PM   #4
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Check the plastic housings that the bulbs are in...see if they are melted and/or the base of the bulb is melted. My 2002 has done this on both sides and the signals acted really wierd before I figured it out the first time (one day they'd blink fast, then they'd go out, then they'd work again, etc.)
jachevy28 is offline   Reply With Quote
Old 02-13-2009, 11:21 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If the bulbs and housings are good then it may be the signal switch. Just had to replace mine as it was doing something similar. Boy was that a pain.
Old 02-14-2009, 01:24 AM   #6
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
replace your front turn signals/Daytime running lights and that should fix it.
TFord is offline   Reply With Quote
Old 02-14-2009, 11:31 AM   #7
nickspohn
nickspohn's Avatar
Drives: 2002 Camaro
Alright will do. Thanks
Sequential Turn Signals? Captain Awesome 5th Gen Camaro SS LS LT General Discussions 26 12-10-2009 08:50 AM
Turn Signal Question kanys Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 01-20-2009 05:14 PM
Whats the "MENU" on the turn signal stalk for? fredl11 5th Gen Camaro SS LS LT General Discussions 23 10-11-2008 06:20 PM
Blinker placement opinions CyberGamaro Cosmetics and Lighting Modification Discussions 21 07-31-2008 06:58 AM
