Solo Performance
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 02-13-2009, 04:43 AM   #1
digidigi
Drives: NN
Supercharger or LS9 Swap?
Hello,
I`m Rick from Norway, I will move to FL this fall. I was also living there from 99-03 and I had a supercharged (Prohcarger) LS1 Corvette back then.
I first decided to get a C6 Z06, but after sean all the pictures and read about the new 2010 Camaro I just changed my mind, I just must have one of those ( a real muscle car). Will get 2SS/RS with other goodies except sunroof.
Just to bad it´s not offered with LS7,LSA or LS9, so I´m consider modifications right away.
Here is my playing with cost of the swap (after some google for LS9 prices).
Solution 1.
LS9 engine: aprx 20.000 USD
Clutch: aprx 1.000 USD
Dry Oil Tank and Lines: aprx 1.000 USD
Custom Exhaust and Headers: aprx 1.500 USD
Fuel pump aprx 500 USD
Misc costs aprx 1.000 USD
SUM 25.000 USD
Reduct LS3 Engine - 6.000 USD
Total ex Labor aprx 19.000 USD
Labor and Tuning (700+ hp) 40 Hours?
Custom hood?
I should be able to ship the stock LS3 engine with a LS3 to LS1 electronic package to Norway and sell it there as a complete Ls1 swap package.
Solution 2.
I´m not sure how strong the stock LS3 engine is for supercharging, so I would have to rebuild my engine before adding supercharger so my guess would be:
Rebuild LS3 engine aprx 6.000 USD
Supercharger Kit (root style) aprx 7.000 USD
Total ex Labor aprx 17.000USD
Labor and Tuning (700+ hp) xx Hours?
Custom hood?
Solution 3.
Keep stock LS3 engine internals (5-6? PSI):
Custom Exhaust: aprx 750 USD
Misc costs aprx 500 USD
Total ex Labor aprx 9.250 USD
Labor and Tuning (600 hp) xx Hours?
Custom hood?
Solution 4.
Could be Head & Cam package with headers (550-600 HP)?
This is just playing with numbers, I will of course discuss this with some serious tuners before I make up my minds.
Think my numbers will add up?
I do not know from whom or where I will order my 2010 Camaro, I guess a good idea would be close to a good tuner.....
Regards,
Rick
Last edited by digidigi; 02-13-2009 at 06:30 AM. Reason: Added more "solutions", dang forgot custom hood
digidigi is offline   Reply With Quote
Old 02-13-2009, 07:40 AM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
If you can afford it ... Solution 1 or Solution 2 ..
I think that way you will get the most HP/TQ and keep it reliable ..
Crowley
Crowley is offline   Reply With Quote
Old 02-13-2009, 08:03 AM   #3
edbrick
edbrick's Avatar
Drives: 2009 GXP -2007 MustangGT--Wife
When you build a car and you figure the budget add 25% for overage. trust me I built a 68 Camaro and thought I had it all figured out to the penny. NOT!!. The best way to go IMO is with the stock engine and supercharger. If its a street car that will be more than anyone can handle.
edbrick is offline   Reply With Quote
Old 02-13-2009, 08:23 AM   #4
digidigi
Drives: NN
You´r right, I remember when I supercharged my 2000 Corvette, added new wider wheels, radiator, brakes, etc.
However, this time I do not plan to race my car much, I just want it to be a extreme fast everyday driven car
I think the stock brakes, suspension and cooling system will be safe and good enough for street use, but I guess we will know as soon as the first V8 are put to real road tests this spring.
Don´t know how the tires wild hold up with 600+ HP, but again for street use I will try them first and add some slicks the few times I will go to the track.
I will at least try to get the same numbers my 2000 SC Manual Corvette did (490RWHP), had a few run 1/4 mile with drag-slicks @11.5. but this was a much lighter then 5. gen camaro will be.
/Rick
Old 02-13-2009, 09:29 AM   #5
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
You will easily pass the 490rwhp numbers. You should easily break those numbers with stock internals and a low boost pressure.
I will be using the STS twin turbo kit at about 6.5psi and I would expect close to 600 at the rear. The procharger would do abou tthe same, as I am also considering their product. You will be safe on the factory internals at those numbers, but over 600hp I would rebuild, and I know some places that will do your rebuild for only 4,000 or so.
ZZcamaro is offline   Reply With Quote
Old 02-13-2009, 10:18 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
IMVHO - I say 1 or 2 also.
A crate engine will have a warranty (unless it excludes the LS9) from GM and you know everything is about as good as it's going to get from the factory. It's precision built and hand assembled. They check it before it goes out the door so it's not likely you'd have a problem down the road. However, I remember reading that engine is at it's limit, at least per the engineers. I don't know if that means durability, emissions, or fuel efficiency (or a combination for that matter) but it's got a lot of good stuff in there.
Rebuilding the LS3 I think is a good alternative too. It's mostly the same block as the LS9, minus the oil squirters and bigger head bolt holes. The heads on the LS9 (and LSA - I think) are different as they are rotocast and heat treated to a different specification (I suspect) to minimize distortion under boost. You could just throw a Lunati reciprocating kit in there and be good.
But if you go to that extent, why not consider an LSX block, either GMPP heads or some aftermarket heads, and go with a forged set-up? You have room to grow with that block, and you won't have distortion issues as one would with the aluminum LS-engines, but it'll probably extend your budget more.
I think that that LS3 will live with some moderate boost though without much trouble for a long time. If you're just going to be playing around and not beating it up on the track then I think this would be a great way to go.
Since it looks like a Z06 was your original plan, I think you can easily spend the money in the difference between the cars and build an even better Camaro. With as much support there is from GMPP and the aftermarket you're going to be covered however you want to build it. Please do me a favor though - keep us posted on what you eventually plan and how things come out
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 02-13-2009, 11:56 PM   #7
gunslinger
Drives: 1998 Z28 M6
I think the LS3 with a set of forged and low compression pistons will probably be the best option. I don't think you will need the whole 6,000 to rebuild the motor (depending on head strength and the possibility of "lifting" the heads) but I dont know how much boost you will want to run.
With about 10 PSI, you should be OK with the stock heads and a set of pistons and maybe rods...
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 02-14-2009, 12:42 AM   #8
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
i would probably start off by driving it in stock form for a couple days, maybe a week.
THE EVIL TW1N is offline   Reply With Quote
Old 02-14-2009, 12:46 AM   #9
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Again. Two of my friends, on completely stock LS3 C6s (well, one had longtubes, but the other didn't), made 550whp on just a bolt-on Paxton Novi1500 kit and an EFI Live tune at ECS. Installed, all told, I think it was about 10k.
10k for 550whp? Unless you're planning on tracking the car and want to keep the heat down for 30+ minute sessions, why the hell would you blow an extra 15k on a car that'll weigh, by the time you're done, 4000 lbs?
Get the blower, or just get a C6.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 02-14-2009, 11:18 AM   #10
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
go for this LSX 454
Both the Pontiac G8 GXP and the LSX454 crate engine from GM Performance Parts are new this fall. GM engineers figured there was no better way to highlight them than combining them in an intimidating street machine.
In factory form, the G8 GXP features a 6.2L (376-cu.-in.) V-8 rated at 415 horsepower (309 kW) and 415 lb.-ft. of torque (562 Nm), but the new LSX454 (part number 19166972) delivers 7.4 liters of unadulterated grunt. It cranks out 638 horsepower (476 kW) and 600 lb.-ft. of torque (813 Nm). The engine uses the LSX Bowtie cylinder block, new six-bolt LSX cylinder heads and an all-forged rotating assembly. Backing the LSX454 is the GXP’s Hydra-Matic 6L80 six-speed automatic transmission.
2SSRS is offline   Reply With Quote
Old 02-14-2009, 11:45 AM   #11
pondo
Drives: '06 Corvette Convertible
my dealer has a callaway corvette sitting in the showroom, blown LS3 under the hood with 580hp and a warranty.
The owner of the dealership said Reeves Callaway visited the dealership, signed the motor of the callaway in the showroom and said they have a SS camaro in the shop which they are working on. Expect the same gains as the vette. Mr. Callaway said they are putting the fine touches to the hood.
pondo is offline   Reply With Quote
Old 02-14-2009, 01:01 PM   #12
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
Originally Posted by 2SSRS View Post
go for this LSX 454
if ur spending 20k on a motor, might as well go all out.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 02-14-2009, 06:51 PM   #13
2SSRS
2SSRS's Avatar
A ls9 is 22,000 + ECM + wiring + new Custom hood
Solution 1.
LS9 engine: aprx 22.000 USD
ECM + wiring: aprx 950 USD
Custom Exhaust and Headers: aprx 2,500 USD
Misc costs aprx 2.000 USD
SUM 30.000 USD
30,000 x 1.2 = 36,000
Total ex Labor aprx 30.000 USD
Custom hood? 950-3500 for Carbon fiber + paint
now lsx 454
engine: 12,000 to 15,000 USD all 4340 forged Crankshaft + rods + forged pitons and Ls7 cylinder heads
SUM 22.000 USD
pan from your LS3
intake ported from your ls3 or after market
Download the catalog....http://www.fuelairspark.com/WhatsNew...009f2009-1.pdf and look on page 21:
LSXR
™ 102mm Intake Manifold – LS7 Car #146202
+30hp/+25Tq over stock manifold..
so the 620 hp is now 650 hp for this engine.
P.S. there is no replacement for displacement 454ci v 376ci
Old 02-14-2009, 11:13 PM   #14
The_Blur
Moderator, USN
The_Blur's Avatar
Drives: 2000 Firebird Formula NHRA SE
You'll have much more fun building your motor than installing the LS9. If that is your goal, do it the custom way.
If you want to keep it as much of a GM product as possible, using the LS9 will make that a reality, although building your own motor gives you the possibility of more power. That being said, the aftermarket is a great resource, sometimes with less reliability than factory products due to sub-par R&D.
If you want to be the fastest car ever, then you may want to consider a lighter car with an engine containing more cylinders by considering the idea of mating 2 GM large-displacement V8s together, upgrading the internals, using 1 turbo per cylinder, and adding so much boost that the power will make a you-shaped impression in the driver seat.
newborn gifts
Old 02-15-2009, 06:12 PM   #15
CamaroSpike23
The Jalopy Jedi
Solution 1.
SUM 30.000 USD
now lsx 454
SUM 22.000 USD
pan from your LS3
LSXR
k.... so if you are spending 30k on a motor/etc, might as well go all out. lol
ps.... see the second quote in my sig.
I piss excellence
Old 02-15-2009, 08:56 PM   #16
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 86 Camaro Berlinetta, 94 Burb 4x4
id go for the ls9 personnaly. but thts just me. of course i wud NEVER be able to afford any of tht lol
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
--WORK IN PROGRESS--
Supercamaro64 is offline   Reply With Quote
Old 02-18-2009, 06:18 PM   #17
digidigi
Drives: NN
Unhappy
Thanks everyone for your input.
However I just figured out that if I order a SS2 now, I will not receive the car before Q4.
Since I live in Norway and I have only accepted one year project (Aug 2009- Aug 2010) in the USA for now, I will not have much time to enjoy the Camaro.
And to bring the car back to Norway is not an alternative because I must pay at least 120.000 USD in taxes!!
I will instead try to find a nice 06-08 Corvette Z06 and use it in FL, if I decide to stay longer then one year (my brother owns the company) I will defiantly try to get a SS2.
Regards,
Rick
Old 02-20-2009, 10:43 AM   #18
scomaro22
scomaro22's Avatar
Drives: 2010 VR 2SS! ,'09 Genesis
what i want to know is, what full custom exhaust setup are you gonna get for 1500 ??? Lots of options though, tough decision, i say go for option 1.
scomaro22 is offline   Reply With Quote
stock ls3 vs. a ls9 w/ no charger? 454lsxss 5th Gen Camaro SS LS LT General Discussions 4 11-01-2008 05:05 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 09:21 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
It's official: ZR-1 LS9 engine makes 638hp / 604tq !! Tran General Automotive + Other Cars Discussion 28 04-29-2008 05:38 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
