Flowmaster Exhaust
Old 03-12-2011, 05:57 PM   #1
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Pedders EP1200 Sub Frame Insert Installation
Installed mine today. What a PITA. Heat is your friend getting those washers to pop off. That and a friend with strong arms and several pry bars. Once I got the fronts on, it was much easier to get the rears on with the tires off, but didn't have enough clearance to get the top rears on. A tug on the rear sub frame and it moved enough to put on, but then the bolt holes no longer lined up. That was a major PITA. Took a bunch of moving it around with a jack to finally get it lined up. Took me about 3 hours to do it, glad it is over.
And those bolts are a b*tch to remove to begin with!
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-12-2011, 06:19 PM   #2
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Use two hammers to remove the OEM subframe bushings metal washers.
Actually, if you use two, regular, claw hammers, those subframe washers will pop right off. No need to heat cause you could damage the OEM rubber inserts, impact is a better friend. Besides, I don't have the proper torch.
The problem is that those subframe washers are slightly pressed into the aluminum inner sleeve which is surrounded by all that OEM rubber. When you try to only pry the washers off, you are only stretching the rubber and you won't get anywhere. My first washer took more than 40 minutes until I used the two hammer method.
You still need a friend to pry down the rubber and take up the slack in the bushing. Then you can slip the claws of the first (pry) hammer under the washer and hold it firmly in place. Then use the second hammer to pound down on the head of the pry hammer. Three to four good whacks and those washers pop out without any sweat.
My buddy and I couldn't stop shaking our heads at how easy they came off once you get the right technique and tools.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 03-12-2011, 06:27 PM   #3
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
any info on the improvments?
or are you still to mad about the work involved?
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
1999 HUGGER SS SOLD :(
400rwhp (3375lbs)
2002 YELLOW Z06 SOLD :(
360rwhp (3040lbs)
2013 CAMARO ZL1 COMMING SOON
M6HuggerSS is offline   Reply With Quote
Old 03-12-2011, 08:02 PM   #4
justa25thTA
I don't drive it anywhere near its limits, and haven't taken it to the track yet, so I really don't have any comparison to make. I did it as more of a preventative measure than anything.
Old 03-12-2011, 09:49 PM   #5
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
So can you just take an air hammer to the washers and pry also?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 03-12-2011, 10:17 PM   #6
Rob@WretchedMS
Drives: His Wife Crazy
yes, but it's overkill,
Just use a big pry bar and they pop off easy.
Rob@WretchedMS is offline   Reply With Quote
Old 03-12-2011, 10:24 PM   #7
jsharp
jsharp's Avatar
lol some say easy some say hard. Some say you can do it yourself and others say you need a hand. LOL It should be fun! I made a post about bmr instructions vs pedders instructions both seem to take a slightly different approach
Old 03-12-2011, 10:37 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Where is that post? Curious to read because I'm eventually going to do these.
Edit: http://www.camaro5.com/forums/showthread.php?t=134500
Build Journal
Old 03-13-2011, 12:02 AM   #9
robsls3
Drives: 2010 camaro 1SS
Prybar and a big screw driver and a couple of good wacks. POP! they came right off.
robsls3 is offline   Reply With Quote
Old 03-13-2011, 09:26 AM   #10
justa25thTA
Either you have some rather large arms, or are doing this on a lift?
Old 03-13-2011, 09:59 AM   #11
Rob@WretchedMS
me, heck no, i'm a skinny fat guy, with a crazy white dog, lol
I was a tech for nearly 10 years, just gotta know how to use the force, lol
Old 03-13-2011, 01:52 PM   #12
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
My 2 rear washers popped right off with a screwdriver. The front 2 however were a PITA! I ended up using 2 large screwdrivers and just pryed like hell till they popped off with a fury!! Went flying accross the floor! I was ready to try some heat but decided to give it one more try! Glad I held off on the heat cause I was worried about ruining the OE rubber inside!
Old 03-13-2011, 02:00 PM   #13
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
I'm doing mine on Tuesday.....hopefully they'll pop right off....I'm planing on using a blunt air chisel.
Huggerorange73 is offline   Reply With Quote
Old 03-13-2011, 05:11 PM   #14
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
A softly rounded point chisel is my weapon of choice. Slide it in from the side and then like a pry bar lever the gun down and the point up. One or two short bursts have them popping off. Your not really 'chiseling' against anything. You are vibrating the plate loose. I'll shoot a video the next time I am under a 5th Gen using this technique.
FS: Brand New Pedders EP1200 Subframe Bushing Inserts DadsCamaro Suspension / Chassis / Brakes 4 10-30-2010 08:59 PM
Pedders XA Coilover questions flht99b Suspension / Brakes / Chassis 33 05-13-2010 01:39 PM
Pedders Day Sept 19th, Farmington, MI. Free Inspections by Pete Basica, Big Discounts Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 7 09-16-2009 09:39 PM
INDY 08 Attendees!!!!! TRIXXTERR Off-topic Discussions 19 12-01-2008 05:29 PM
