Old 03-13-2011, 07:24 PM   #29
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Yes suspension is also another priority. You will notice a lot more of use with s/c's working on suspension at the same time as thinking about cam. I have trailing arms, toe rods, and rear cradle inserts(very goodmod). About to look at axles after cam and stall are in before sticky tires. None of us can do it all at once but I can say from experiance that there are mods out there that you will get more benefit from other than power ( yes it doesnt sound as nice) but its true. Most auto guys would say stall first as well because for the money it is the best mod for auto and it will get you down the track quicker all day long if you compare stall and no cam vs cam and factory stall. The gains of power are good but its not beneficial unless you can hook it!!
1,000 POST FOR ME!!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 03-13-2011, 07:29 PM   #30
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
WINNER!
Huggerorange73 is offline   Reply With Quote
Old 03-13-2011, 07:32 PM   #31
jsharp
jsharp's Avatar
haha I said something smart and on my 1k post!!!!
Old 03-13-2011, 07:41 PM   #32
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Ok. So we may get somewhere with this.
A stall and cam at the same time.
Suspension mods for hooking. (trailing arms, bushing, etc.....)
So then, I still need to figure out what I think would be best. VVT cam, or LS3 conv.?
In order to not have to revisit. I wanna figure out my process.
Maybe a pros and cons of VVT and LS3 according to C5 member opinion.....
1,000 POST FOR ME!!
Old 03-13-2011, 07:51 PM   #33
Huggerorange73
Banned
Drives: The REAL C5
If I was you...this is what I would do :
1. Rear subframe cradle inserts
2. Trailing arms ( do the rear bushing as well, only the Pfadt trailing arms come with both the front & the rear )
3. Drag radials ( worst case, put them on your stock 20" wheels )
4. Decide how much power you want to add
5. Big power => LS3 conversion ( match stall to cam choice )
6. Smaller gains => VVT cam swap ( match stall to cam choice )
Old 03-13-2011, 07:54 PM   #34
jsharp
jsharp's Avatar
You probably wont get a lot of "valuable" information on one vs the other right now from members other than the ones with LS3 conversion say:
I have better/wider cam selection
I have good lifters now which shops say is a weak point
I spend more money lol
I think I have an ls3 now?
Those with VVT:
I have the best of both worlds
Its cheaper and easier to install
I kept my weak lifters or I chose a VVT cam with afm delete and got rid of them for a little more money.
I gained more low end torque then you LS3 guys and maintained Same hp as your cam.
If you want a big comparision what you see from the vendors is the best for now as really VVT cams for the camaro are just now starting to get into peoples mind and engines. If you want more one vs the other from actual drivers then wait. That will give you some time to do the other things!!! Not only do you have to decide ls3 vs VVT but also VVT vs VVT with afm delete
Old 03-13-2011, 07:56 PM   #35
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
I don;t understand why people are saying LS3 conversion is the only way for big power.
Many L99's are making big power on VVT cams. Granted, some of these results are with heads too.
http://www.camaro5.com/forums/showth...hlight=VVT+cam
Old 03-13-2011, 07:58 PM   #36
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Something to consider is that the LS3 conversion leaves you open to MOAR POWER later. But then, you're not likely to want that.
Old 03-13-2011, 07:59 PM   #37
Huggerorange73
Banned
Drives: The REAL C5
Because my LS3 with a sub .600 lift is at 470 RWHP without touching the heads.
Not knocking those 2 threads, trust me....475 RWHP out of a VVT L99 is stout, but you can make some insane power numbers with a big cam in a LS3 that you simply can't stuff in an L99 because of the lifters, and possibly piston to valve clearance.
Old 03-13-2011, 08:01 PM   #38
Darth_Emma
Darth_Emma's Avatar
He could always switch out his maggie for a TT and keep VVT with a cam.
Old 03-13-2011, 08:03 PM   #39
Huggerorange73
Banned
Drives: The REAL C5
That would be pretty expensive....he's already got the blower and headers.
TT would have had to have been decided from the word go!
Old 03-13-2011, 08:04 PM   #40
Darth_Emma
Darth_Emma's Avatar
I guess I should have added this:
Old 03-13-2011, 08:05 PM   #41
Huggerorange73
Banned
Drives: The REAL C5
Old 03-13-2011, 08:09 PM   #42
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
There is something to be said for lift as well as the lifters that the l99 uses. Opening the valves more to allow more air and fuel mix isnt a bad thing..LOL
Also an automatic trans eats more power than the manual..
CC Performance is offline   Reply With Quote
Cunningham Motorsports Cam install Packages Ryne @ CMS USA - California 6 01-26-2011 01:38 PM
cam sensor part number needed for LS3 cam swap on L99 NEGXXIS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 12-12-2010 12:21 PM
Whiteside Customs Maggie 2300 + VVT Cam Project yyz28 Forced Induction - V8 3 10-17-2010 09:46 AM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 03:11 PM
Upgraded your cam in your LS3? What are your specs? Happy? papabearcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-26-2010 05:53 PM
