sjm autoprod
Old 03-13-2011, 11:12 PM   #57
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
It primarily has to do with LSA and then duration... If the LSA is too small, then the exhaust and intake valves are both open at the same time... This can also be affected by the duration. The exhaust valve can still be open when the intake valve opens, thus, boost swirls through the chamber and out the exhaust valve...reduction in boost...limit the duration, and open the LSA and you retain the boost where you want it, in the cylinder... Basically, you want the exhaust valve closed when the intake valve opens...
This, very much!
So is anything else limited at that point? Lope? Power?
Lope is created by LSA....what you're hearing is the valves both being open at the same time. You can retain power with a cam and a blower by using a narrow LSA to limit the amount of time the valves overlap.
I'm on a 113 LSA.....sounds great, but not what you want with a blower.
Originally Posted by Supercharged SS View Post
PQ, have you thought about bigger headers if you do a cam. There might be some gain if you do. I didnt read this entire thread but don't you have 1 3/4's.
Bigger headers hurt boost....same thought process, air is leaving in more volume...that's why you have to swap the pulley out to get back boost lost with headers.
Huggerorange73 is offline   Reply With Quote
Old 03-13-2011, 11:12 PM   #58
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Power is better with the right cam, boost in the cylinders makes more power, and the lope is related to the smaller overlap, which is ok/good for NA motors...like someone else mentioned, with boost, and big cams, be sure to upgrade the springs, valves and pistons kissing is a death sentence...
As an aside to the springs comment, bear in mind these are pretty big valves in these heads, so, think of an umbrella in a hurricane... Big valves and big boost require schwzeneggar springs... I'll be Bach...Is knot a tumah
Old 03-13-2011, 11:14 PM   #59
Huggerorange73
Banned
Drives: The REAL C5
PQ, I believe the LSA with VVT is where you get into the +... Cams, but don't quote me on that...
The " + " you see following the LSA is advance thats ground into the camshaft already.
Old 03-13-2011, 11:16 PM   #60
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
If I do the conversion then I don't have to worry about all that right? Just get a cam that I know works and put it in.
No way. I'm not gonna spend money on headers when I already have some. I LOVE the sound of these.
Ya, I have 1 3/4 and it may actually be good so as to not lose as much boost when I cam it. It would seem anyway.
Ya, I have to do some more reading. But, again, if I just pull the heads, It becomes much easier.
Old 03-13-2011, 11:21 PM   #61
Supercharged SS
Drives: 2010 Camaro
You'll need bigger headers for that cam. Yes, you will produce less boost but make more power. Less boost = safer
Old 03-13-2011, 11:21 PM   #62
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
OK...a vein just popped out of my head. You guys know way more about this than I do.
My Whipple and cam were installed at the same time. The 4" pulley that ships with the Whipple is typically supposed to produce 9lbs of boost. Mine was at 7.3lbs. I had headers, catback exhaust, intake and a cam. Was the drop just a combination of all of the above?
Old 03-13-2011, 11:22 PM   #63
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Don't have to worry about all what... The VVT, or the LSA and duration... VVT goes away, then get a suitable cam for boost... My cam is a 121 degree separation, awesome sounding, and works great with boosted motors...
Old 03-13-2011, 11:22 PM   #64
Huggerorange73
Banned
Drives: The REAL C5
You got it!
Old 03-13-2011, 11:27 PM   #65
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Without knowing the specs on the cam, it's hard to say...lots of shops will install a rump rump cam for the sound, but, that's not always the best thing... Do you have your specs... And I'm not slamming any shops or peeps... Just throwing info, what little I know out there...
About a year ago, Someone did a good write up, not specifically about this, but this was included...wish I could remember who, might have been Ted...
Old 03-13-2011, 11:29 PM   #66
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Hey Randy...it may not have as much lope as mlee's, but I'm pretty happy with my mild VVT cam.
Old 03-13-2011, 11:30 PM   #67
Supercharged SS
Drives: 2010 Camaro
What he said. Cam + headers = less boost but more power. Take that out of your equation and blam, there's your 9 lbs.
Old 03-13-2011, 11:30 PM   #68
Huggerorange73
Banned
Drives: The REAL C5
Headers and the cam are the biggest factors in it....a good tuner/ builder is not going to let you put the wrong cam in it PQ!
Old 03-13-2011, 11:31 PM   #69
PQ
Booooosted.
PQ's Avatar
Which is why my 1 3/4 primaried headers may actually work just fine with a cam. Or am I off base on that?
But if I keep the boost shouldnt' I be able to make more power and find a happy medium with the whole aspiration process?
Worry about LSA. Because it will be constant with a non-VVT cam. With a VVT cam it can change, right?
Old 03-13-2011, 11:32 PM   #70
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
That's what I thought, but I guess I figured the cam made most of the drop.
Cunningham Motorsports Cam install Packages Ryne @ CMS USA - California 6 01-26-2011 01:38 PM
cam sensor part number needed for LS3 cam swap on L99 NEGXXIS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 12-12-2010 12:21 PM
Whiteside Customs Maggie 2300 + VVT Cam Project yyz28 Forced Induction - V8 3 10-17-2010 09:46 AM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 03:11 PM
Upgraded your cam in your LS3? What are your specs? Happy? papabearcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-26-2010 05:53 PM
