Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Wheels / Tires
Old 03-15-2011, 04:42 PM   #1
Jason 98 TA
Drives: Camaro
Weld Drag Wheels IN STOCK for 2010 SS!
Guys we have just got our stocking order of the Weld RTS wheels. We have the 17x5 RTS polished fronts and the 17x10" Polished rears ready to go! Call for pricing!
Jason 98 TA is offline   Reply With Quote
Old 03-17-2011, 08:35 AM   #2
Jason 98 TA
Drives: Camaro
TTT!!!
Old 04-26-2011, 02:17 PM   #3
Kwik
Drives: car
Bump for ya!
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 04-26-2011, 02:40 PM   #4
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Pm on the way!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 04-26-2011, 03:48 PM   #5
EvoWake
SSTOCK
EvoWake's Avatar
Drives: 2010 Camaro 2SS/RS
Jason, I sent an e-mail over to ya, looking for pricing on a set of rears.
Thanks!
2010 Camaro 2SS/RS
EvoWake is offline   Reply With Quote
Old 05-09-2011, 03:22 PM   #6
Kwik
Drives: car
ttt
Old 05-09-2011, 03:38 PM   #7
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Be sure your modded car is stock before buying. ( doesn't make sense huh? )
If your lowered, then these are not the wheels for you. Just FYI.
kevin1106 is offline   Reply With Quote
Old 05-09-2011, 04:41 PM   #8
Wheel Czar
Mans First Invention
Drives: Killer
17x10 Weld RTS
Spohn Performance offers a low profile control arm to eliminate this. 17x10 with a 7.2 inch backspace.
The 17x10 can also be ordered in a 6.7 inch backspace. It will come out to the fender.
A 17x9.5 will also work in a 6.2 backspace to keep it from coming under the stock control arm.
So not accurate information.
Wheel Czar is offline   Reply With Quote
Old 05-09-2011, 04:59 PM   #9
kevin1106
kevin1106's Avatar
Oh Ok... Well I Guess this type of information should be enclosed in this thread.... If your lowered and want welds, plan on spending another 500.00 to make them fit. This isnt just a bolt on wheel if your lowered.
http://www.spohn.net/shop/2010-Chevr...-Control-Arms/
And you will also need these...
http://www.spohn.net/shop/2010-Chevr...Camaro-V8.html
So actually that 625.00 to make them fit, plus shipping. Brake pads I can understand cause of the front dampers on some of the later 2010 camaros.
Sorry I wasn't 100% right here. Still would like to see this setup to see if there really is any fitment issues.
Old 05-09-2011, 06:15 PM   #10
PTS
PTS's Avatar
Drives: 2011 Camaro
When was the backspace and the 9.5" listed to be available as an option? I am looking at the app guide and it shows nothing of what you talk about. Point blank the customers with the problems are absolutely in the right and it would impress me if Weld will take care of them. Be sure to tell Weld since you have the inside hookup to take care of the problems with the wheels that are damaged.
So not accurate information you say! Helluva comment...
PTS is offline   Reply With Quote
Old 05-09-2011, 09:05 PM   #11
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
They fit fine on lowered cars.
Ovenmitt is offline   Reply With Quote
Old 05-10-2011, 08:47 AM   #12
Wheel Czar
Drives: Killer
Fitment
Weld makes the RT-S wheels in many sizes and back spacings. It is also one of a few wheels that will let you drop down any where from 1 to 3 inches in diameter and still clear the brakes. When I looked at the wheel being used a 17x10 with a 7.2 inch back space and from the statements made in this forum of it needing about 1/2 inch to clear the control arm on a lowered Camaro I subtracted the 1/2 inch of back spacing. Also knowing that the 10 wide wheel sets right at the fender on the outside a 9.5 seemed a good solution with a 1/2 less backspace. Also the Spohn control arm is a great solution if you have to run a 10 wide wheel. I did not look at any app guide to subtract this and come up with a solution. I am only trying to help clear up a fitment issue some of our members are curious about. I would think this would be welcome information, and a pretty easy solution if you look at the information given. And for the guys who have a problem, I would suggest to them to call the dealer in which you purchased the wheels. Explain the situation to them and have them call Weld to see what can be done. I hope this helps. Thanks
Old 05-10-2011, 03:56 PM   #13
Ovenmitt
Weld only makes three centers for the rts. Only one center will clear the caliper in 17" size. End of discussion.
Old 05-10-2011, 04:03 PM   #14
kevin1106
kevin1106's Avatar
I think you need to read this thread. http://camaro5.com/forums/showthread...55#post3121655
Different Wheel Construction Types Explained Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 45 12-21-2017 08:37 PM
F/S: 20" SS Stock Wheels (Two sets!) aLL STaR Camaro Local Marketplace 13 01-26-2012 08:46 PM
Challenger Fest ! Only 20 spots for Camaros to Drag race nhra stocker Dragstrip and Launch Techniques Discussion 61 08-23-2010 06:30 PM
**SUPER DEAL** Widened Stock SS Wheels GrinderSS Wheels / Tires 11 08-11-2010 04:17 PM
Anyone Run 17" Wheels On Stock SS Brakes? Jason 98 TA Dragstrip and Launch Techniques Discussion 4 07-29-2010 06:31 PM
