JDP Motorsports
Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro
Old 03-15-2011, 06:53 PM   #1
GuidosCamaroSS
Drives: 2010 Black Camaro SS/RS MTX
TR6060 Tranny 4.2QT Capacity?
I just changed the transmission fluid on my SS and it only took just under 4qts before it started spilling out of the fill hole. I know it says 4.2qts, but has anyone ever been full under 4qts? Just wondering if I should get back under and try to squeeze some more in there. By the way, I used Royal Purple Synchromax.
thanks
GuidosCamaroSS is offline   Reply With Quote
Old 03-15-2011, 07:05 PM   #2
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
thanks
Sounds right for a TR6060(M6).
Cooler, and Cooler lines have fluid in them...Unless you drain them.
Were you level when you filled the transmission?
After a few miles, jack it back up and check...If you nervous about it.
D1SC-LG G6x3-SW 2" Headers-DMH Cutout-3" Flowmaster A/T-ADM Dual Fuel-ADM Boost,Air/Fuel gauges-Nitto NTO5r-SJM line lock-Modded LS3 Oil pump-BMR-Toe Bar,Trailing Arm,Sub Connectors,Cradle Bushings-Shep Tunnel brace-MSD Shift Light,2Step-CINCY SPEED Tune-DSS 9" Conversion..3.70s gearALKY Control-Extream Innovations Roll Bar- 4l80!! 763RWHP 629TRQ
acowherd is offline   Reply With Quote
Old 03-15-2011, 07:10 PM   #3
GuidosCamaroSS
....I forgot that we had cooler lines on the M6. Sorry, my bad.
Old 03-15-2011, 07:57 PM   #4
jpizzle007
jpizzle007's Avatar
Drives: '10 LS3, '11 328i, '78 El Camino
mine was the same, just about 4 qts and it started spilling out. maybe not even 4 qts, so you should be good.
good choice on the RP, I noticed a big difference.
Custom stainless steel catch-can, Halltech Yellow Jacket CAI, T-304 MBRP 3" CB, Solo HiFlow Cats, TSW Interlagos Matte Black, Nitto Invos 275/315, SkipShift Eliminator, MGW ShortThrow Shifter, Flux Capacitor - fully tweeked
jpizzle007 is offline   Reply With Quote
Old 03-15-2011, 08:37 PM   #5
Stingr69
'69 Owned Since '79
Stingr69's Avatar
yup. Just under 4 qts.
-Mark.
Stingr69 is online now   Reply With Quote
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 08:25 PM
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More maperformance Transmission / Driveline 18 10-26-2010 02:16 PM
Interesting article on LSA powered 2010 Camaro Sax1031 Camaro ZL1 Forum - ZL1 Specific Topics 43 05-26-2010 07:30 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 09:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 01:28 AM
