B&M Racing
Old 03-17-2011, 10:59 AM   #1
smokingcamaro
smokingcamaro's Avatar
Drives: 2010 Camaro LS
30,000 mile service
I have not reached It yet But my dealer said that It is going to cost me $450 to do it and that is just stupid. My question is what needs to be done at 30,000 miles why does it cost this much or are they just trying to get my money lol.
smokingcamaro is offline   Reply With Quote
Old 03-17-2011, 12:55 PM   #2
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Ask the dealer for a list of services performed. Chances are 80% of the things on the list aren't call out in the maintenance schedule. What's required is mostly a lot of check this and inspect that... plus an oil change.
So yeah, the dealer service packages are usually ripoffs...
Old 03-17-2011, 01:26 PM   #3
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Here's a list of things they do off my dealers service site.
30,000-mile Service
Due at: 30,000 ; 90,000 Miles
• Lubricate and Inspect Suspension, Drive Line and Steering
• Change Engine Oil and Replace Oil Filter
• Rotate all Four Tires and Adjust Pressure for Longer Wear
• Inspect Air Filter and Fluid Levels, Top-off as Required
• Inspect Engine Drive Belts and Hoses
• Inspection of Brake System, Clean and Adjust as Required
• Full Inspection of Fuel System
• Replace Fuel Filter, Air Filter and/or PCV if needed
• Service and Clean Fuel Injection and Induction System
• Clean Throttle Body
• GM Multi-Point Vehicle Inspection
• Free Soft Cloth Car Wash with all Service
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 03-17-2011, 04:15 PM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
I looked through your owners manual to check on the recommended services and found that at 25,000 miles it is suggested that you get your fuel and exhaust systems inspected (on top of an oil change if needed). I found this information in section 10 on page 5. I hope this information helps you.
Jeff Morris, Chevrolet Customer Service
Old 03-18-2011, 05:57 AM   #5
windzurfer
Roll Tide!!!!
windzurfer's Avatar
Drives: 1987 Yugo
I use a cool app for my iPhone called Gas Cubby. You can import/export from/to Excel and also backup your data to their servers for easy restore if you want to load it on a new iPhone or iPad or jay want to reset your iPhone and start over. You don't lose the data. It also supports multiple cars. I have all mine tracked. It even graphs mpg, cash spent on repairs, etc.
http://appcubby.com/gas/index.html
windzurfer is offline   Reply With Quote
Old 03-18-2011, 06:08 AM   #6
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
30,000-mile Service
If they do the bolded one above, shoot them!
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 03-18-2011, 08:13 PM   #7
smokingcamaro
But why is it going to cost me $450 to get this done? Has anyone had theirs done if so how much did you pay and what for?
Old 03-18-2011, 10:12 PM   #8
jehartley
jehartley's Avatar
Drives: Red LT1 & Silver LS3
There is no such thing as a "30,000 mile service". It is a scam. Follow the maintenance schedule in your owners manual...it's that easy.
jehartley is offline   Reply With Quote
Old 03-18-2011, 11:02 PM   #9
talltom
talltom's Avatar
Drives: Silver LS
32,000 mile service
Oil and filter change (Mobil 1) - $69.95, fuel injection service (I think they just flush some solvent through there) - $144.00, plus tire rotation (LS does need tires rotated) and gave everything a good looking over ("27 point inspection"). Total was about $225. $450 would have to include a lot of stuff...I looked at getting the gear box oil changed, but that was $60 a quart and way too much labor charges.
At about 12k miles I had the differential gear oil changed because of a rubbing/growling/chunking sound and this was done free under a technical service bulletin (TSB). It solved the problem for a while, but it has come back. I didn't do anything on this visit and may have to take it back in a week or two. (this is only for the V6 manual transmission).
One other thing...I understand there is a passenger compartment filter under the windshield wiper cowl that can be changed and I will do that next.
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage).
talltom is offline   Reply With Quote
Old 01-16-2013, 12:34 AM   #10
Trevorw24
Black Ma6ic
Trevorw24's Avatar
Drives: 2011 Camaro LS M6
I just moved to LA and I took my car to get the oil changed. The rep told me that I was approaching my 30,000 mile service, and he said it would cost between $500 and $700. I was shocked so I looked here. These dealers....
DT Headers l MRT v2 l Injen SRI l Hurst STS l Resonators Delete l Lowered 1.25'' l 35% Tint l Black Bowties l Tinted Tail Lights l AAC lighting l Debadged
Trevorw24 is offline   Reply With Quote
Old 02-05-2013, 05:34 PM   #11
cabbe
Drives: 2014 2ss 1le
What did you end up doing Trevor?
I'm at that point as well now.
Thanks!
cabbe is offline   Reply With Quote
Old 02-05-2013, 06:19 PM   #12
BigVic
Speed Racer
BigVic's Avatar
Drives: 2012 AGM 1LS
LS yes, but not on nak3dsnake's 2LT/RS!
The fuel filter is part of the in-tank fuel pump module an I don't believe it's a serviceable part.
Dealers...what a joke. :bangdesk:
BigVic is offline   Reply With Quote
Old 06-26-2013, 11:41 AM   #13
jezebel
Drives: 2011 Camaro LT1
hahaha, dammit i took my car in to get an oil change and i asked them to rotate my tires... idiots did it front to back! and i didn't notice until i got home and i had to drive there and get them to do it the right way.
jezebel is offline   Reply With Quote
Old 04-19-2014, 01:17 AM   #14
Inferno LT
Drives: 2011 Inferno Orange 1LT
You should rotate them according to Pirelli (or whatever the tire manufacturer says) or you could void the tire warranty, which is always separate from vehicle warranty. Pirelli says to rotate front to back.
Inferno LT is offline   Reply With Quote
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
Are you a stupid [cable] customer? (BEWARE: sarcasm) The_Blur Off-topic Discussions 32 03-16-2011 09:11 AM
XM Radio Service Issue "BE AWARE" dalasD Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 89 06-20-2010 09:34 PM
Frustrated with GM & Dealers' Service eckerj Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 20 04-27-2010 01:44 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
