JUICEDMOTORSPORTS
Old 08-17-2011, 03:04 PM   #99
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Some pictures of my MEATS!
SUX2BU is offline   Reply With Quote
Old 08-17-2011, 03:11 PM   #100
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
What cam/springs are you going with? (You mentioned it in my thread. )
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 08-17-2011, 03:29 PM   #101
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Padre
Texas Speed 231/236 cam
Texas Speed PRC .650" valve springs
I was just going to do a blower cam later since I plan to do a Whipple at the end of the year or the beginning of next but I got a SMOKING hot deal on the cam from my buddy. I figure I can use it for a few months and then make my money back and then some selling it after I pull it out.
Old 08-27-2011, 04:56 PM   #102
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Installed an Apex ram air scoop and relocated the washer bottle.
http://www.camaro5.com/forums/showthread.php?t=167747
Cost of today's mods: $134.99
Old 10-05-2011, 12:47 AM   #103
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
So I went down to Houston for the Texas Camaro Nationals, but couldn't stay for the racing Sunday so I got a few runs in on Saturday.
A big thanks to LoneStarCamaro for getting these videos of my car.
This was Ginger's first time on drag radials and I was VERY limited on time so I didn't get to experiment with different psi settings and rpm for a decent launch so I couldn't muster a good 60'. Best time was:
60'.............1.9177
330'...........5.3122
660'...........8.1082
660’ mph...88.13
1000'..........10.4886
1320'..........12.4867
1320’ mph…112.92
Corrected for the 1692 DA it is about a 12.25 @ 115.154
Here is a Video of me racing HPE650Ragtop. He was on street tires so I was able to get out on him enough to take the W.
Time slip
Me racing a supercharged Roush 427R Mustang
The time slip.
Old 11-06-2011, 01:32 AM   #104
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
11/05/11 Ginger gets some 18x4 CTS-V spares to use as skinnies.
I wasn't really planning on getting skinnies for the track but I ran across a set of wheels that I thought would fit for relatively cheap. They didn't, but since I had already bought them I decided to make them work with a little extra work. I did not want to simple run a spacer (not very safe especially for racing) and I also didn't want to run a huge adapter (didn't want to spend all this money to reduce the rotational mass and then add a heavy spacer with extra studs and lugs. I took a TON of measurements of everything involved and calculated that I needed 11mm of extra room to make the wheel fit and have adequate clearance for the brakes. Like I said earlier I did NOT want to run a regular spacer, I would only run a spacer that was hub centric on BOTH sides. I searched and searched but no one had what I needed. A couple companies would make custom hub centric spacers for me but they wanted an arm and a leg. Then I found a pair of 12mm hub centric spacers on Ebay for cheap, BUT they were 5x114.3mm bolt pattern and 67.1mm hubs. As you know our cars are 5x120mm bolt pattern and 66.9mm hubs. This wasn't the first time I had to make stuff fit so I ordered them and just figured I would wallow out the holes a bit (the important part is that they were hub centric inside/out and 67.1mm was VERY close to 66.9mm, .2mm is less than .008").
I also ordered longer studs to make up for the spacer I was going to add. There are a few choices for longer studs but the most affordable by far were replacement truck studs. They are exactly like ours except they are 7 mm longer. The spacer I was ordered was 12mm so I was giving up 5mm of threads going with this set up. It was going to be close on if I had enough threads to be safe. I calculated that I would have 7 full thread turns. Some places on line said the minimum was 6 turns and others said 9 turns, so this is where you have to make a judgement call. I actually ended up with about 7 1/2 turns, but I'll say 7 just to be safe.
Since the spacer was 12 mm thick and the hub "hat" was 11.53mm tall I knew the spacer was not going to sit flush. My remedy was to bevel the edge of the hub just enough for the spacer to fully seat on the rotor hat. I knocked out my studs and put in my longer ones. I had to grind a little notch in the aluminum part of the knuckle to be able to slide the longer studs in without having to remove the whole wheel bearing hub assembly. Since I am only getting 7 turns on the lugs I went ahead and used my stock GM wheel lugs from my Escalade for a little added safety.
When it was all said and done I think it came out pretty good. I lost ANOTHER 10 lbs off of each front wheels from my already VERY light street set up (44.4 lb 18x8.4 Forgestar F14 & 245/45 18 and 34.4 lb CTS-V 18x4 spare with M&H 185/50 18). If you are running stock 20" wheels you will lose almost 28 lbs off of each front wheel, that's a total loss of almost 56 lbs!
One thing you must also be aware of is that these tires are very short. my car is already VERY low because of my lowering springs and lightweight 18" Forgestar F14s. I'm sitting at about 2.5" lower than a stock SS. With these front runners I am another .6" lower up front. That's OVER 3" lower on the front of my car, so you have to be very careful when you drive on these. Since my car is already very low I'm already used to scanning the road when I drive to see what I have to avoid. I took some measurements and my front quarter fairs "mud flaps" were about 1.75" off the ground and my header flanges were even lower than that, about 1 5/8" off the ground. Also, these tires are made for a 5" wheel. These CTS-V wheels are only 4" wide, the rim lips are very tall and so are the bead shoulders. The tires were a HUGE pain in the ass to seat. I had to go to a specialty race tire shop to get them mounted and even he struggled a bit.
Finally, the last little thing about this set up I like is that one of these front runners can also double as a spare! Now, it doesn't fit perfectly in the spare tire well in the trunk. You can't actually put the flat cover over it, but you can put the carpeting back over and it's not that noticeable. I'm not going to drive around with this in my trunk all the time, but I will throw it in there when I go on road trips.
Total cost of today's mods: $561.97
two CTS-V 18x4 wheels: $180.00
two M&H 185/50 18 radials: $327.08
longer truck studs: $14.90
hub centric spacers: $39.99
Old 11-07-2011, 06:21 AM   #105
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
Jack and Spanner
Just a tip - including it as a spare will only save you time if you also include a jack and a lug wrench of some kind, as neither of these come with the car either.
I'd be scared to go that low, but glad these new rims work for you. Keep up the good work!
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 01-08-2012, 06:14 PM   #106
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Pics for my rub mark fix thread.
Old 01-08-2012, 07:05 PM   #107
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The complete thread.
http://www.camaro5.com/forums/showthread.php?t=194349
Old 01-08-2012, 07:20 PM   #108
The Stig
knows 2 facts about ducks
The Stig's Avatar
great write up. I can't believe how badly GM dropped the ball on the tops
Click to view my build thread
Old 01-08-2012, 08:05 PM   #109
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
Great job and great looking car, hope to see it in person at this years CFest III!
Old 01-27-2012, 12:58 AM   #110
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
1/25/12
Swapped my 315/40 18 Nitto NT05R drag radials for some 315/30 18 Hoosier drag radials. I'm of the opposite opinion of most of the people on this site when it comes to sticky tires. Most want to run a 305/45 18 tire that is almost 29" tall. I think our cars are too heavy and don't have enough gear to lug such a tall tire out of the hole and down the track. Even on my 28" NT05Rs, I felt, were too tall. I got a smoking deal on 25.4" Hoosier drag radials so i swapped out.
To put it in perspective going from a 305/45 18 to a 315/30 18 is the equivalent of going from stock 3.45 gears to 3.90 gears. Plus all the rotational mass you are getting rid of doesn't hurt.
1/4 mile tracks are closed right now but I will post results as soon as they open. This is the ONLY change I have done since my last trip to the track which resulted in 12.35 @ 112.9 w/ 1.89 60' (12.16 @ 114.7 corrected for +1,429 DA).
Total cost of today's mods: I actually made $25!
Hoosier 315/30 18 drag radials: $375
Sold my 315/40 i8 Nitto NT05R drag radials $400
Old 01-27-2012, 03:38 PM   #111
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Some daytime Wind Restrictor pics. Sorry my car is so filthy.
Old 01-27-2012, 05:47 PM   #112
Andrew6
TheDoubleAA.com
Drives: 2008 Corvette Coupe ZHZ 269of500
I wonder how minx oil would do on the top?
Andrew6 is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 11:05 AM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
Payment and Shipping info for 1st Edition Camaro5 shirts TAG UR IT Camaro5 Store Merchandise 154 10-18-2008 04:00 AM
SHIRT PAYMENT DEADLINE...OCT 17th!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 1 10-17-2008 02:06 PM
