JDP Motorsports
Old 07-10-2011, 07:40 PM   #15
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
Originally Posted by Big Brunsy View Post
The E-brake on the Camaro is kind of like a drum brake inside the rotor, so no special tools required.
you are not removing any brake lines, so there should be no way for air to get into the brake line. So you do not have to bleed the brakes.
Always bleed the fluid at every brake pads you change. Brake fluid absorbs water from the humidity in the air, the water is heavier than brake fluid so the water is pushed to the end of the line, and then it allows corrosion of the system.
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 07-10-2011, 09:49 PM   #16
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Originally Posted by faSSt View Post
...Just my thoughts, it's only two more bolts to remove the caliper, along with the torx that hold each rotor on....dont stop short go the rest of the way and get them rotors turned!...
You'll need to buy new caliper-to-spindle bolts. They're not expensive, but they are torque-to-yield and should not be reused. You'll never get them torqued to specs once they've been stretched.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 08-19-2011, 10:11 AM   #17
RedVictory
Luv my LS3
RedVictory's Avatar
Drives: Summit White 2010 2SS/RS M6 LS3
It it nessesary to grease the back of the pads? If so how do you do it?
Also do you have to push back both pistons at the same time or can you just do one side of the caliper at a time?
RedVictory is offline   Reply With Quote
Old 08-19-2011, 10:46 AM   #18
SSMOKINHOT
obseSSed
SSMOKINHOT's Avatar
Drives: 2010 Camaro 2SS/RS
Great write up!! Thanks!!
Proud to be COTW 12/19/11
My build thread -----> http://www.camaro5.com/forums/showthread.php?t=140034
SSMOKINHOT is offline   Reply With Quote
Old 08-19-2011, 11:42 AM   #19
Chito
SoCal HT5
Chito's Avatar
Drives: 2010 Camaro black 2ss/rs
Great write up. bookmark for sure. quick question. I'm trying to get my calipers powder coated, I'm removing the entire caliper and pins, what else do I need to remove from the caliper in order for them to get powder coated. thanks.
Chito is offline   Reply With Quote
Old 08-19-2011, 12:31 PM   #20
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
I changed my pads over to Hawk HPS the other day. This was by far the easiest brake pad change I have ever done!
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 09-07-2011, 05:16 PM   #21
Dave Den
Drives: 2011 Camaro SS red convertible
Great write up, I am going to paint my rotors and not the caliper.
I want to rmove the rotor can I just unbolt the 2 18mm bolts and how do I release the caliper piston ?
Dave
Dave Den is offline   Reply With Quote
Old 09-07-2011, 09:27 PM   #22
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Dave
T30 torx bolt into the face of the rotor.
The caliper will push back in with not too much force. You can use clamps as shown or just pry it in with a large screwdriver.
BSR-1 is offline   Reply With Quote
Old 09-07-2011, 09:59 PM   #23
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Thanks for the awesome writeup! I'm planning on doing a brake pad upgrade.
MAYBE in the future I'll do the CTS-Vs up front, I haven't felt the need for too much more braking performance yet though. All bolt-ons so far...
Thanks for the DIY write-up!
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 09-07-2011, 10:16 PM   #24
Dave Den
Thanks ,
I got them off and am in the process of painting.
Davd
Old 09-15-2011, 10:26 AM   #25
toehead93
Drives: 2014 2SS/1LE
This is great! I plan on swapping the pads Sunday monring before the AutoX event and the rotors the next weekend. I plan to use a scoth brite to scrub the rotors, should I use any chenical or water with it? More importantly, will waiting a week for the new front rotors cause any bedding issues with the pads?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-22-2011, 01:07 PM   #26
Colby627
Colby627's Avatar
Drives: 2010 2SS T/C 6.2 L Meth-Injected
IMO, it would be nice if the suppliers selling replacement rotors would go ahead and include the caliper to knuckle bolts in their packages,,,
Colby627 is offline   Reply With Quote
Old 10-22-2011, 11:48 PM   #27
Tom0662
Drives: 1998 Camaro SS
Good job on the DIY Big Brunsy.
I think that this should be added to DIY because if they are torque to yield bolts they should NOT be used again. Sure you might be able to get away with it a time or two but are you willing to take the chance. That being said does anyone also have the torque spec for the caliper mounting bracket bolts? Or are they standard torque? I failed to find that anywhere :(
And torque specs from what I have found without talking to the dealership for the caliper bolts.
These specs were from a thread posted on C5
http://www.camaro5.com/forums/showthread.php?t=169229
Front - 33 ft lbs + 90 degrees GM P/N 11570788 M14 x 2.0 x 56.5
Rear – 30 ft lbs + 90 degrees GM P/N 11515781 M12 x 1.75 x 60
GM manual states install new bolts.
Tom0662 is offline   Reply With Quote
Old 10-23-2011, 03:51 PM   #28
Tom0662
My bad. For some reason I was thinking that the caliper bolted to a bracket that you had to remove in order to get the rotor off. I went out today and pulled one apart and answered my own question. If I would have looked at the pictures a little closer I would have seen that, plus I thought last night that the 33 + 90 seemed a little extreme for caliper to bracket bolts
So I guess I will go to the dealer tomorrow and get some new bolts.
Stainless Works Longtube w/High Flow cats plus Hawk Ceramic Brake Pads Xplosive Performance V8 Bolt-Ons & Tunes 5 04-13-2011 08:03 AM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 03:57 PM
***STILLEN Camaro5 SS Brake System Upgrade Package*** Team STILLEN Suspension / Chassis / Brakes 20 08-06-2010 10:49 AM
FS: SS rotors, brake lines, pads, springs. trailing arms. Darth_Emma Suspension / Chassis / Brakes 0 08-05-2010 07:25 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 01:44 PM
