BORLA
Old 11-07-2011, 10:06 AM   #29
aldaron327
Onward and Upward.
aldaron327's Avatar
Drives: '13 Equinox LTZ AWD,'09 Silverado
Send a message via MSN to aldaron327 Send a message via Yahoo to aldaron327
Regarding the TTY bolts, is it recommended that you'd use some sort of compound for torqueing down the bolts (I think ARP has some stuff) that is supposed to help in the process or can you just torque down the new bolts with some Loctite and call it good? Just curious as I have all the parts enroute to replace pads, rotors, and brake lines.
Thanks for any input and Thanks OP for the awesome write up with good pics!
-Tim
2010 Summit White 2SS/RS LS3
MODS: CAI by CAI, Flowmaster American Thunder Cat-Back, DBA 5000 Slotted/Cross-drilled rotors (Front), Hawk HPS Pads, Russell Braided Brake Lines, DBA 4000 Slotted/Cross-drilled rotors (Rear), Barton Short-Throw Shifter, UM Comp Extractor Hood & Gen I Spoiler, custom paint
aldaron327 is offline   Reply With Quote
Old 11-25-2011, 11:07 AM   #30
full of days
full of days's Avatar
Drives: Camaro GT
i'm swapping my front calipers/rotors to the cts-v 6 piston setup. What is the part number for the new spindle caliper bolts? anyone have that?
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 11-26-2011, 12:24 AM   #31
aldaron327
Onward and Upward.
aldaron327's Avatar
New DBA 5000 Series 2-Piece front rotors and 4000 Series rear rotors with Hawk HPS pads and Russell braided steel brake lines installed as of today. All Brake Equipment was purchased from MarylandSpeed.
Initial thoughts:
I took my car out onto the interstate and on to an off-ramp to bed the pads in. Jammed on the brakes from 75 mph (speed limit on I-70 where I live) down to the stop sign. Immediate right turn to a road where the speed limit at the off-ramp's stop sign is 40MPH but goes up to 55 MPH 1/4 mile up the road. I conducted a few hard stops from 40 and 55 and then made the right turn onto another road where the speed limit is 55 and conducted a couple more hard "brake events". I drove back through town and conducted the same loop without hitting the brakes "hard" twice more for a total of 15 minutes without hard stopping. On initial "bedding" and subsequent stopping, the brakes now feel almost "spongy" where they used to have an initial "bite". However, pushing harder on the brake pedal initiates a more "sharp" stopping event. The brakes used to have that initial "bite" and then stop hard with a slight "fading" feeling. Now, it's the exact opposite. It takes more pedal pressure to feel that "bite" but it's more progressive and the stops are definitely shorter from a "seat of the pants" perspective. I hit the brakes where I used to to turn onto the main road that my driveway sits off of, for example, and I actually almost stopped short of the road. I've experienced ZERO noise from the new set up and my only complaint at all is that when I ordered the rotors, they were supposed to be "black hat" rotors, but what I received was painted gold. Personally, I don't care as long as the parts that I spent money on work better than stock. Out where I live, it takes deliberate braking events to "test" a brake system short of racing a car on a track. I'll be adding the separate reservoir for the clutch tomorrow and I'll check to make sure that everything still looks and "acts" normal.
Again, thanks to Maryland Speed, Ofer(2SSRS), and 2010CAMAROJ for getting me the parts that I need to complete my brake and clutch systems. I'm hoping that in the spring I'll get my chance to test the brakes to their "full potential" to see just how much better what I purchased is than stock.
-Tim
Old 11-30-2011, 01:10 AM   #32
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
Thanks for the order! This is a great write up!
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 01-28-2012, 07:35 AM   #33
hysonmb
hysonmb's Avatar
Drives: 2010 2SS / RS
Thank you for this! I just installed new pads last night. This was, by far, the easiest brake job I've ever done and your post made it a breeze.
hysonmb is offline   Reply With Quote
Old 02-14-2012, 07:41 PM   #34
DSPark13
Drives: 2006 Silverado 2500HD D/A
Thumbs up
Thanks for the write-up. I will be replacing brake pads this week.
DSPark13 is offline   Reply With Quote
Old 02-20-2012, 12:40 PM   #35
rgmatlo
Drives: Imperial Blue 2SS
Ok have stock pads on and ordered some ceramics through the local auto parts store. The pads they gave me were not the same size and shape of the stock. Is there a difference in aftermarket size and shape compared to the OEM? If so shouldnt they still use the spring and pins that the stock use?
rgmatlo is offline   Reply With Quote
Old 02-28-2012, 07:19 PM   #36
unclepat
Owner of Red Heat
unclepat's Avatar
Drives: 2011 Chevrolet Camaro V6
Just installed a set of crosss drilled and slotted rotors along with the pads on my 2011 Camaro. Scared as hell but I got thru it with flying colors thanks to this article. I also installed MGP caliper covers while everything was apart. Thanks a bunch for a GREAT DIY article. Helluva lot of brake dust during the "bedding" process though!
unclepat is offline   Reply With Quote
Old 03-06-2012, 09:39 PM   #37
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Holy crap. I've never even watched someone else install brake pads before but I read through this and it gave me the courage to save the $500 the dealer was going to charge me.
Literally took me 15 minutes per wheel. Thanks for the write up.
2017 Camaro ZL1 M6 - Everything but the sunroof - New Daily Driver! Commuting has never been so fun.
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 03-11-2012, 12:32 AM   #38
blk96gt
Drives: 11 SS(sold),96 Mustang,12 Silverado
Originally Posted by Big Brunsy View Post
Are these two bolts the torque to yield bolts?
blk96gt is offline   Reply With Quote
Old 03-23-2012, 10:20 PM   #39
EDWEIRD
EDWEIRD's Avatar
Drives: 2011 Camaro V6
Send a message via Skype™ to EDWEIRD
going to paint my rotors and not the caliper.
Originally Posted by Dave Den View Post
Great write up, I am going to paint my rotors and not the caliper.
I want to rmove the rotor can I just unbolt the 2 18mm bolts and how do I release the caliper piston ?
Dave
AM I the only one who's never heard of anyone painting the rotors before??
EDWEIRD is offline   Reply With Quote
Old 03-24-2012, 07:58 AM   #40
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
That's what I was thinking, LOL! Maybe he's going to paint the center???
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 03-24-2012, 09:26 AM   #41
The Stig
knows 2 facts about ducks
The Stig's Avatar
This. He's probably going to paint the rotor hats.
Click to view my build thread
Old 03-24-2012, 10:44 AM   #42
ducatisl
ducatisl's Avatar
Drives: 2010 2SS 6m
You never know in this crowd
Stainless Works Longtube w/High Flow cats plus Hawk Ceramic Brake Pads Xplosive Performance V8 Bolt-Ons & Tunes 5 04-13-2011 09:03 AM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
***STILLEN Camaro5 SS Brake System Upgrade Package*** Team STILLEN Suspension / Chassis / Brakes 20 08-06-2010 11:49 AM
FS: SS rotors, brake lines, pads, springs. trailing arms. Darth_Emma Suspension / Chassis / Brakes 0 08-05-2010 08:25 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
