Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#57 | |
Booooosted.
![]() If I install my new Pedders end links in the outermost position on the bar, will it cause the ride height to change due to the car sitting on the sway bar/end links? Mine is now, set in the innermost holes (softest). I changed them after it came off the bar before. Never came off the BAR again. BUT, I want it to be the stiffest. So I'll move them to the outer, it just seemed like it was gonna put too much weight on the links? ![]() |
#58 |
Just Because!
Drives: 2010 SIM 2SSRS Join Date: Jun 2010
PQ,
The endlinks/sway bar will not affect the ride height at all. What Pete wrote above is right on.... Dissconnect both endlinks, adjust the bar to line up with the endlinks, then reinstall the endlinks. You might need to jack the bar up to have it meet the endlink on one side. Trying to make it clear, but not sure if I am helping or not! lol Jason
#59 | |
VIR Specialist
![]() Drives: Camaro Justice Join Date: Jun 2007
Which is the strongest hole? The rear 5th Gen bar mounts with the main bar to the rear of the car and the arms pointing forward. The d-bushes are on the main bar. The further away from the main bar, the d=bush you move the WEAKER the setting. Think See Saw We'll just look at one half of the See Saw. The triangle or fulcrum is the d bush. You would have the most leverage furthest away from the fulcrum, but you would also have the most motion. The least motion would be closest to thee fulcrum or the d-bush. Excuse the lengthy explanation, but now we are on the same page. Are you in the softest or hardest hole position?
#60 | |
VIR Specialist
#61 | ||
Booooosted.
![]() Quote:
#62 |
Haven't read through the whole thread yet, but I have snapped 3 of these on my Camaro!
First one was on a bone stock suspension, but running at Sebring which is a pretty rough track. Both of the second times were with stock endlinks. I check and double check all my bolts before and after every single trackday to ensure everything is tightened properly. /Erik |
#63 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Hey everyone, there has recently been some discussion about the strength of the stock control arm, specifically where the sway bar mounts. We've seen damage ranging from cracking to full on failures from users and shops alike. Since we have access to OEM Cad files and Finite Element Analysis software, we decided to look into the situation this afternoon.
Finite Element Analysis is the process in which computer models of specific parts are mathematically scrutinized for potential points of failure, the analysis takes into account geometrical design, material thickness and strength. In the graphical representation of this data below, blue indicates areas of relatively low stress, yellow areas of medium stress, and red of potential failure points. This is the OEM Sway bar attachment point for the 2010 Camaro 5. This piece is welded onto the OEM control arm and the hole is where your sway bar endlink stud is pushed through. As you can see, there are localized areas of high stress directly above the hole... this backs up the physical evidence we've seen lately of endlinks pulling through that mount and rendering that control arm useless. As per our analysis, we've come to the conclusion that the amount of torque that is placed on the endlink stud will have a negligible effect on the structural integrity of the thin metal that the bracket was designed from. What extra torque will do is possibly keep the nut from backing off of the stud, but will not prevent the failure of the bracket it's self. The real issue is the material used in the OEM bracket, and the thickness of the steel in question. Here is a prototype design of a reinforcement bracket that we will be testing shortly. The design is incredibly simple and will take about 5 minutes to install. We're considering manufacturing this piece if there is enough interest in the forum. This plate will solve the fundamental issue of the material being too thin, without the need to replace your endlinks because the stud is too short. If anyone has questions or concerns please let us know. We strongly feel this solution is elegant, simple and will resolve issues surrounding the stock bracket. |
#64 | |
![]() Drives: WAS '10 SS IBM, NOW '14 BRM ZL1 Join Date: Jun 2009
I'm curious to know what the OEM material is, and what load you applied to it. Also the load is not strictly axial, did you account for the bolt being twisted in the hole? This is certainly more than a static load situation too. Fatigue is also an issue. For the final design a pretty hefty Margin of Safety should be applied to the results of a static load only analysis. |
#65 | |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
If you need a test car, I'm volunteering mine! I already have Pfadt springs, sways, end links, trailing arms, differential and subframe bushings, and the Pfadt control arm/toe link stiffener. IPS Motorsports has my car right now for the bushings and it's getting a cam and torque converter too. This would be a great time for them to put this reinforcement bracket on my car. |
#66 |
![]() ![]() ![]() Drives: NSMNJW=2010 CGM 2SS/RS LS3 Join Date: Dec 2009
From the looks of this one it's loose in the hole. Look at the brown area around the nut indicates its not tight.
DYI Oil Catch Can, DYI dash ABL, DyI fender "V"emblems, ACC Plasma DRL, DYI Painted red SS on steering wheel, DYI CGM painted bowties on wheels, DYI Clearcoated Brake Calipers, Eibach pro 1" lowering springs, GM Heratige grill, GM skipshift eliminator, GMPP 92206992 Exhaust, 2-10" Kenwood subs w/350watt pioneer amp, RiderGraphics hood spears/gill outlines, 9x20 wheels-custom silver,weather tech mats, ARH 17/8 headers and cats. Tuned by Davenport Motorsports.
#67 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
I, for one, am glad to see a variety of vendors chime in on this situation. It seems from the Pfadt Demo above that HP may have something to do with this along with driving style and other factors if I am reading correctly.
For those who know, how do you tell if this becomes an issue during driving? Or do you have to check this visually? Is this something that should b checked like a maintenance item like oil changes or rotating tires say 5000 miles, or after a couple of times it should be good? Thanks
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
#68 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
Well done Pfadt obviously your new part will be a vast improvement over oem.
![]() But I want to be clear on the fact that lose end links will eventually elongate any bolt hole whether it be an oem product or aftermarket? Obviously, as your data shows oem is more susceptible to failure. But as a rule keeping everything nice and tight will go a long way to prevent failures? Yes? ![]()
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#69 |
VIR Specialist
The sky is NOT falling. What occurred to PQ is not the norm. Please return to your regular scheduled program.
The 5th Gen has been on the road for a couple of years now. We have reports of two owners in this thread with failures. Pedders has known from day one that the lower control arm tab has limitations based on our own in house testing of the OE arm. PQ should already have his brand new OE replacement arm that was left over from our early R & D. (PQ, Please excuse the dust.) It has a mild steel tab as do all 5th Gen arms. We are confident that a hardened washer added to the assembly on the nut side adds sufficient strength. Will it last forever? Probably not, but nothing else on the 5th Gen will either. Replacement arms are available from GM online parts sellers for as low as $28 so this isn't a big ticket item. The problem isn't new. The bigger the bar the greater the potential for damage. It is now and has been in our Solution C product description. Forum rules prohibit a direct link to the catalog, but you can get there through my signature. There are a number of Pedderised cars doing serious track duty on all OE arms. There are similar cars from other vendors doing the same thing. The failure rate for the rear OE endlink tab is extremely low. The sky is NOT falling. What occurred to PQ is not the norm. Please return to your regular scheduled program.
#70 | |
VIR Specialist
Thread Tools | |
Now i broke the rear drive shaft bolts and alot of damage. | Vinnysrt8 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 82 | 07-04-2016 09:41 AM |
Broke Something - Help Identify | smaegley | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 44 | 02-08-2011 05:03 PM |
Headlamp Broke | phenixdragon | Cosmetics and Lighting Modification Discussions | 1 | 12-10-2010 09:35 PM |
Stock Gears Broke | NickeyStage2 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 21 | 09-14-2010 04:11 PM |
2010 Camaro 2SS Needs Repair | Bumleb | 5th Gen Camaro SS LS LT General Discussions | 164 | 04-27-2009 10:09 PM |
