Old 02-16-2009, 02:01 PM   #1
UA488Fitter
UA488Fitter's Avatar
Drives: 1981 Z28 1995 Z28 2010 2SS/RS
Battery Questions
Wet Cell or Dry Cell?
I recently discovered the battery is located in the trunk of the new Camaro.
Great place to put the battery, IMO
Hot rodders have been doing this for years, mainly for weight distribution.
Seems to me that GM has done this for the same reason.
I'm sure that is is contained in an enclosure of some sort.
Does anyone know?
Is the enclosure metal or plastic? Probably plastic.
Is it a plastic box bolted to the bottom of the trunk well? What about venting?
Or, is it a separate compartment under the trunk floorpan, accessed through a trap door?
Or, is the battery just strapped down to the tunk floorpan with plastic cover over it?
I see the the postive battery cable is inside the trunk compartment;
so I would assume that a separte compartment is not the case.
So, if it is a wet cell battery.
My very first mod on the car would be a change to a dry cell battery.
Would doing this affect the warranty?
I know that I don't care to have a half gallon or so of sulfuric-acid sitting in the same compartment as I do.
IMO A dry cell would be a far safer option.
Anyone seen what sulfuric-acid doed to human tissue; it's not pretty.
And yes the trunk is part of the cocpit, it's only separated by a folding seat back;
and in most cars not even by that much.
There is no bulkhead separtating the trunk like the firewall separates the engine compartment.
Anyone know? Wet Cell or Dry Cell?
UA488Fitter is offline   Reply With Quote
Old 02-16-2009, 02:10 PM   #2
MLL67RSSS
Drives: car
Battery is located in a well that holds the (optional on V6 cars only) space-saver spare tire. It sits under the spare. On SS's and cars that didn't order the spare there is a small tire inflation compressor in with the battery. There are some pictures of the battery in the well in the Indy show pictures thread.
MLL67RSSS is offline   Reply With Quote
Old 02-16-2009, 02:16 PM   #3
MLL67RSSS
Drives: car
Here ya go!
Old 02-16-2009, 02:24 PM   #4
UA488Fitter
Thanks MLL67RSSS
Yes I have see those pix; and that what I thought.
But; it doesn't answer my question.
Wet Cell or dry Cell?
And encloure? If an enclosure what type?
Just questions
Old 02-16-2009, 02:38 PM   #5
UA488Fitter
Thanks again MLL67RSSS
Great picture
Oh MY GOD!!!! It looks like a Wet Cell.
Hope I'm wrong!
If it is a Wet Cell. Looks like I'll be swapping that out for a Dry Cell.
Will that affect the warranty an any way?
Can anyone tell me?
Old 02-16-2009, 02:43 PM   #6
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Does ACDelco even make a dry cell battery? I didn't think they did.
Here's a picture from Heather's SS:
rolnslo is offline   Reply With Quote
Old 02-16-2009, 02:48 PM   #7
UA488Fitter
Is that a vent tube that I see on the negative side of the battery?
It might be a battery purpose built for the new Camaro.
I wonder what it's RPO is.
Once again great picture MLL67RSSS
Old 02-16-2009, 03:23 PM   #8
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
i hope you can fit an optima in there.not that im going to drop one in right away,but when it needs replacing i will use an optima.
Nexus6 is offline   Reply With Quote
Old 02-16-2009, 03:27 PM   #9
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
Great picture
Hope I'm wrong!
Can anyone tell me?
Why would changing the battery effect your warranty? Of course it wouldn't. There is nothing wrong with the battery being in the trunk. heck, Corvettes use to have it behind the drivers seat and Audis use to have it beneath the rear seat. Come to think of it, the VW Beetle had the battery under the rear seat also. And that was before sealed type batteries were the norm.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 02-16-2009, 03:48 PM   #10
UA488Fitter
Thank Txturbo
Don't get me wrong I really like where the battery is.
But; it realy should be a dry cell.
I have seen the damage cause by a rollover in a VW with the battery under the rear seat.
The person lost the use of their arm from that battery acid; and again I will say not a pretty site.
Sure a freak accident but it can happen.
I still think a dry cell would be way safer.
I guess that the stats on this issue are low enough that it is a non-issue.
Anyone have more info on this battery.
Is it the same as use in the Vet? It must be.
Old 02-16-2009, 04:14 PM   #11
Angrybird 12
Retired, Cancer Survivor
Angrybird 12's Avatar
Drives: 12 CAMARO, 15 Impala, 07 Colorado
Optima isn't worth the money, I have had to and they both crapped our in a year, I ended up going to autozone and getting a 5 year battery for half the price and no issues with it at all...
Cancer's a bitch! Enjoy life while you can! LIVE, LOVE, DRIVE...CAMARO!
The Bird is the word!
Old 02-16-2009, 04:18 PM   #12
Angrybird 12
Thank Txturbo
GM has been putting batteries in the trunk for several years now, ever since the Saturn Ion Came out. I know for a fact the ION, Cobalt and HHR all have the battery in the back. I see no problem with them being there.
Old 02-16-2009, 04:26 PM   #13
Corvin
Corvin's Avatar
Drives: Soon to have a 2SS 2010 Camaro
I'm getting the 2SS and I ordered a spare tire because if you get a hole in the side wall the air compressor isn't going to help one bit. But I'm wondering, does me ordering the spare tire mean I'm not going to get the air compressor also? I mean it should come with it if it's standard equipment for the 2SS but I didn't know if they were just going to leave it out because I got the spare tire also. Anyone know for sure?
Corvin is offline   Reply With Quote
Old 02-16-2009, 04:30 PM   #14
Angrybird 12
you can't get the spare with the 2SS... but even if you could you would not get a compressor if you get the spare tire.
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 02:03 PM
Few Questions I would like answered. dect 5th Gen Camaro SS LS LT General Discussions 50 01-13-2009 01:52 PM
changing a battery in the wintertime is FUN Dave McFly General Automotive + Other Cars Discussion 10 11-20-2008 06:37 PM
V8 Questions 96CAMaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-19-2008 10:25 PM
2010 Camaro Questions Th3Nigh7Stalk3r 5th Gen Camaro SS LS LT General Discussions 13 10-17-2008 04:21 AM
