Flowmaster Exhaust
Old 03-22-2011, 11:26 PM   #1
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Rear view camera and LCD mirror install on my vert.
Not really sure where to post this, but it looks like there might be some differences between the coupe and vert for this, so I will post it here.
The ZL1 will have a back up camera and what sucks is that our cars already have the reverse wire going to the mirror and there is a spot blocked off by the license plate that looks like the location where the camera will be.
Ok, first off the parts you will need are:
1. rear view camera
2. rear view mirror with LCD screen (i used one out of an 2011 GM truck)
3. a harness to connect the mirror to your stock connector (you can also wire it up yourself, I was going to do this, but 2SSRS had a great price on a ready to go harness)
This whole process took about a couple hours since this is the first time I have taken apart the interior of a 5th gen. I has very impressed at how well the interior pieces came off and snapped back in.
First thing I did was take off the A pillar covers, these just unsnap at the top and then you just slide the bottom out of the dash. BE CAREFUL, with the drivers side one, it has what looks like a microphone attached on the inside of it. This pops right out of the clip.
Next you will be taking off the top trim on the very top of the windsdield (the part that the convertible top attaches to). This part has a bunch of clips that you just pull on straight up.
Next you will remove the stock mirror. Pull off the little plastic cover that houses the connector. The mirror's mount has a torx screw that locks it in place. Loosen this screw and just pull the mirror up and out. Also disconect the connector. You can go a head and mount the new mirror.
Next you will be pulling off the trim piece that has the sun visors, interior lamp and garage door/vert top buttons. This piece has 4 Torx 15 screws holding it in. these screws are covered by the sun visors and little removable tabs. You remove these tabs with a thin flat head screw driver from the outer most side (I almost broke mine trying to remove them from the inner most side, but luckily they are VERY flexible. I will post the pictures in order from drivers side to passenger). After removing the little covers unscrew the 4 trorx screws and then pull down on the trim piece where it meets the windshield (it will only come loose on the front) after you undo all of these clips you will pull the whole piece back toward the rear of the car. There are a couple connectors on either end I left plugged in so it will hold the trim piece. You can now plug in the new adapter harness and run all the wires along the top trim piece and down the a pillar.
Next up you will take off the side dash panel, kick panel and rocker trim panel on the driver's side. Also pull off the rear trim panel right above the rear sail panel, then the rear sail panel (be sure to unplug the rear speaker that is attached to the sail panel). You can also pull out the rear seat bottom by just pulling up on it and making sure it doesn't get caught on the seat belt receivers.
Now you have to pull off the rear license plate and pretty much all the panels out of the trunk (you have to do this part with the top up). These panels are pretty easy to pull out. BE CAREFULL with the sensor attached to the side molded carpet panel. Now you can look at my picture so you can see where to run the cable through. I used a coat hanger to snake my cable through this little opening.
Now all you have to do is mount whatever camera you have, drill a hole for the wire, run the wires and put all the trim pieces back on.
SUX2BU is offline   Reply With Quote
Old 03-22-2011, 11:30 PM   #2
Hobgoblin42
Hobgoblin42's Avatar
Drives: 2012 2LT 45th Anniversary edition
Send a message via Yahoo to Hobgoblin42
Great post, I could not do this but I am impressed with those that can!
Upstate C5 Buffalo events can be found here!
http://www.camaro5.com/forums/showpo...95&postcount=1
Hobgoblin42 is offline   Reply With Quote
Old 03-22-2011, 11:41 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
A side note: the video quality has some interference. I'm thinking bunching up the excess wire like that and putting it right next to the battery wasn't the best idea. I will fix it tomorrow.
Old 03-23-2011, 12:03 AM   #4
IBM/2SS/RS/LS3
NorCal Camaro➎ Member
IBM/2SS/RS/LS3's Avatar
Drives: Bowties ONLY!!
how much in parts??
IBM/2SS/RS/LS3 is offline   Reply With Quote
Old 03-23-2011, 12:18 AM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by IBM/2SS/RS/LS3 View Post
how much in parts??
I spent about $380, but there are better deals on mirrors out there (I jumped on the first one I saw) so you could get this really close to about $300.
Almost forgot to comment on the actual mod itself! LOL
The mirror is HUGE. It borders on the line of almost too big, but I like it. With the top down it looks like I am looking at my 58" plasma screen out of the back of my car. You can see EVERYTHING. It actually sits up pretty high so the top 3/8 inch or so is useless because it is blocked by the upper console but I like it. I still have to adjust the actual tilt of the camera to see what I like.
Old 03-23-2011, 02:39 AM   #6
panther2469
Nice job
Old 03-23-2011, 11:28 AM   #7
Tiberious
Old '71 Owner
Tiberious's Avatar
Drives: 11 Camaro Vert;97 Malibu;03 Venture
That's a fantastic job, thanks for the great how-to. A rear camera is HIGH on my list of priorities.
With the 2012 having the option for a rear view camera designed for the car itself, I wonder if waiting for a couple of months wouldn't result in a camera designed specifically for the car with the guide lines and all.
I'll be keeping an eye out on this topic to be sure.
Tib
Tiberious is offline   Reply With Quote
Old 03-23-2011, 11:37 AM   #8
SSAINT
SSAINT's Avatar
Drives: "11 2SS/RS VR vert BG/BG SW stripes
Great job!, waaaay beyond my abilities but great idea.
SSAINT is offline   Reply With Quote
Old 03-23-2011, 11:50 AM   #9
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
I agree with Tiberious and am going to wait a little bit, but I am spoiled by this feature in my other vehicles and can't wait to add it.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 03-23-2011, 12:06 PM   #10
heff
Drives: 2011 Camaro pace car
Nice work, It seems a bit easier for me to just turn my head and look like I've been doing for the last 35 years, but hats off to you on the great job!
heff is offline   Reply With Quote
Old 03-23-2011, 12:13 PM   #11
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: 2015 Spice Red Metallic 2LTZ Impala
Nice job on the mod but how long did you have your Camaro when you started this mod? I mean I would at least driven it a awhile and enjoyed driving it before I started disassembling it. But to each his own.
Baldman is offline   Reply With Quote
Old 03-23-2011, 12:34 PM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
4 days. You should see the room full of parts I have waiting to go on. The only thing I am waiting on to start tearing her apart is the 1/4 mile track to be open so I can get my bone stock 1/4 mile times and dyno numbers. If the track was open the night I got it I would have been there that night and had her apart the next morning!
Old 03-23-2011, 01:00 PM   #13
Starminder
Savant
Starminder's Avatar
Drives: 2011 Vert 2SS/RS CGM
I have a mirror from brandmotion (OEM supposedly) being installed today. I didn't have the nerve to try it myself. Not cheap, but apparently meant for the 2010+ camaro. Supposedly mine will be the first vert install.
2011 Vert 2SS/RS Cyber Gray
11/29/2010 - (1100) Order Placed
01/28/2011 - (3800) Order produced
03/01/2011 - (4200) Shipped
03/16/2011 - DELIVERED
View my Garage
Starminder is offline   Reply With Quote
Old 03-23-2011, 02:07 PM   #14
Tiberious
Old '71 Owner
Tiberious's Avatar
If it's intended for the Camaro, will it have guide lines or just the image? I'll take any help I can get keeping from hitting hidden objects....and yes, I look too!
Tib
