| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
JANNETTY RACING UPDATED CUSTOM TUNE INSTRUCTIONS
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you Purchase an SCT X3 Hand Held Tuner from me you get 1, 93 OR, 1, 91 Octane Tune For Free for your simple bolt on mods, exclusions apply for cams, superchargers and nitrous. PLEASE SPECIFY OCTANE WHEN REQUESTING CUSTOM TUNE, DEFAULT IS 93 OCT. Additional Tunes with minor changes are available for 50.00 each, i.e. Second tune for a different Octane. Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file, here is how, plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, do so, and hit select. Your tuner came with a disc with Free Software called SCT Device Updater software, install this in your home or laptop computer Before you connect the device to your computer. Then After you install and OPEN SCT Device updater software, you can connect your X3 to your computer, Drivers should install automatically, then Get Stock File, Click Browse, Find your Desktop and Click Save. Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, List of performance modifications, and Octane you want to run your car on, i.e 93 or 91. PLEASE RE: READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION. Then I will send you back a custom tune file for your mods. Save the file to your desktop, it will be, YOUR NAME JRE TUNE.cef Again open SCT Device Updater, Then, connect your X3 tuner, select Load Custom Tune File, Browse to your tune file, exit when finished. Connect to your car, Select Program Vehicle, scroll left to Custom Tunes, Select JRE tune and follow the on screen prompts. I have developed Dyno Proven tunes for all of the Product I sell, So Unless I instruct you to do so Datalogging will NOT be necessary. If I instruct you to Datalog your car, The best way I found is to use a laptop on the seat, First Open the LiveLink Software then connect the X3 to your laptop, then connect the X3 to the OBDII Port of the car, With the Car RUNNING, Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below. Even thought they may not be named exactly as I listed them, I want you to select the following, but try not to select anything Not listed or doubles of any of the items listed. You may have to test several PIDs to see which ones work best or work at all on your car. Once you find a list that works well Save Livelink Configuration file for future use. Engine RPM - RPM ECT engine coolant temp – ecteng clt tmp TPS throttle position or pedal position – acc pdl pos 1s IAT intake air temp or Air intake temp – intk Airtmp MAF Mass Air flow Hz – Maffre 125 TIMING spark cylinder 1 – ign Tim Adv4#1cyl KNOCK RETARD – knk ret Short Term Fuel Trim bank 1 – stf tri b1 Short Term Fuel Trim bank 2 – stf tri b2 Long Term Fuel Trim bank 1 – ltf tri b1 Long Term Fuel Trim bank 2 – ltf tri b2 Pleas ONLY Select the PIDs Listed, Extra PIDs Slow Down Datalogging and give me useless information. Names can vary from computer to computer but you get the Idea. Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM. Then repeat at about 1/2 throttle to 5500 RPM Speeding is not recommended or necessary 1st and 2nd gear are fine if you do not have the room. Stop, and Save Datalog As, to your desktop. Email me the log file along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications. PLEASE RE: READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION. If you have other questions about SCT this is the entire FAQ section http://www.sctflash.com/support/inde...goryid=3&nav=0 REMEMBER WHEN YOU PURCHASE YOUR PARTS FROM ME CUSTOM TUNES FOR THOSE PARTS ARE FREE. Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts Last edited by JANNETTYRACING; 07-08-2011 at 07:33 AM. |
NCCOA Ch 1
Drives: 2010 Camaro 2SS/RS - Z4Z # 44 Join Date: Feb 2011
Thank you Ted. Looking forward to receiving the SCT and TB in the mail and then uploading your tune shortly afterwards. I appreciate your outstanding customer service which, for the record, is what brought me on board as a new customer.
#3 | |
Thanks. Ted.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
NEcamaro5
Dose this work for the v6 also
Airaid,jba,mrtv2,tryfecta,gm bodykit,havock spoiler,razzy splitter,pfad 1.25 drop,blacked out headlights,markers,tail lights,blacked out all bowties,painted engine cover and underhood lighting,Custome underhood bowtie,t rex grill,tinted windows,black side gills,disk brake covers,barton shortthrow,abl (all the way across),footwell lighting,blacked out dash trim and console,zl1 nose soon |
No, Sorry No V6 support at this time.
#6 |
![]() Drives: 2011 Camaro Join Date: Apr 2010
So, this tune will cover both engine and A6 tranny?
#7 |
![]() ![]() ![]() Drives: Nothing Fun. Join Date: Aug 2009
Correct both the Engine and Trans..
Nick @ Jannetty Racing Enterprises Inc.Performance Parts Store
2012 Camaro ZL1 Performance Parts 2012 Boss 302 Performance Parts Join us on Facebook! |
#8 | |
Man I'm really wanting you tune my vehicle..just worried about the warrenty.
![]() Quote:
#9 |
NCCOA Ch 1
I called my dealership and a tune does NOT void any warranty, or portions thereof, unless the tune or MODS can be shown to have been the direct cause of a failure. Ex. Last week they had a 2010 in that had a SC installed by an aftermarket, non-GM affiliated shop. The crank pulley was whobbling (bad). It was replaced under warranty even though the car had been modified and tuned without any questions.. Association must be shown between what you have modified and what broke or is giving you problems before a warranty is voided, and only then, partially.
Lots of post on this topic. My 2010 Pace only has 1,500 miles. The SCT that you get from Ted, stores your stock tune so that you can replace it should the dealer need to update your ECM via flash. Then, you just reload your Jannettty tune! No issue!!
#10 |
![]() ![]() ![]() Drives: Nothing "On the site for my Dad" Join Date: Oct 2009
Ted, My Dad wants to get the tune checked for his car b/c of how the plugs where after he gets the TB on,and I have a question? I put the livelink on my Laptop and I seen in a different thread there was a file that has the Banks u want. Where would I load that in livelink? Thank you.
#11 | |
#12 | |
I went there and says Ford Programmer? http://sctflash.com/tsupdates.php?PN...0&GUD=1&GSER=1 Found it. |
#13 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
So if I get one of these tuners...With my Ported TB,BBK intake,Flowmaster AT cat back should i see some good gains ...Like how much will I notice it in the set of my pants..
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
#14 | |
#15 |
You will LOVE it I Promise, Different Driving Experience for sure.
#16 |
Do I open this file http://www.jannettyracing.com/2010%20CAMARO.cf3 under "Open Livelink Configuration" ?
#17 |
So-Cal Race team!!
Can you send me a PM with all the cost for this up grade...Thanks
#18 |
Want to make sure I have it right! He is still waiting for TB, #1 on the list.
#19 |
Book marked for when I am ready
![]() Talk to you soon. Regards, Allen English |
#20 |
Thanks Ted! at Jennettyracing.com.
Sent my factory tune to and got intant service. He emailed me his custom tune, loaded the tuner with ease, Just follow Ted's instructions.. Installed tune in my car and wow! The car runs PERFECT with his tune and my mods. Can't wait to go to your shop this summer for the cam install. Camaro5, Best believe this guy is for real! Thanks Ted.
#21 |
So Cal Camaro5 Race Team
Drives: '10 SS/RS, '06 HHR, '70 El Camino Join Date: Sep 2009
Well worth it Don, Teds the one that did mine, car is night and day. Very pleased with it and his customer service is top notch
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels |
#22 |
Are you dyno #'s before or after Ted's Tune?
#23 |
before
#24 |
![]() Drives: 2011 Camaro 2SS Join Date: Dec 2010
HELP!!!! I downloaded my stock file to the SCT. I have installed the SCT Device Updater on my PC. I open the updater and connect the SCT/X3 into the USB port. When I do this my computer reads "USB Device Not Recognized". Any sugestions? I have tried it in all of the USB Ports with the same results.
#25 |
Lifestyle = Deathstyle
Connect the SCT first...then open the software. I have W7 and that worked for me.
| Thread Tools | |
| American Racing Headers for 2010 Camaro yields +32rwhp w/o tune, +50rwhp with tune | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 224 | 01-28-2013 08:38 AM |
| Jannetty Racing tune | Big Daddy Kane | Tuning / Diagnostics -- engine and transmission | 5 | 12-11-2010 07:07 AM |
| MBRP Catback, AIRAID CAI, and Custom Tune | sixty9fordkiller | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 03-21-2010 11:22 PM |
| Tom Henry Racing Announces a Special Edition 2010 Camaro! | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 72 | 04-30-2009 12:57 PM |
| LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
