BORLA
Old 02-17-2009, 01:13 AM   #1
2KZ28_For_Now
SS Shotgun Ride?!??! :-)
2KZ28_For_Now's Avatar
Drives: 2000 Z28
Seeking Tech Help: Axle "clunk?"
Hey folks,
I was told by a fellow Camaro5 friend a few months ago that my current problem (along with the power window motors/wiring) was common.
I will preface this by saying my car is an automatic (I know, I know) -- and is stock, except for a K&N filter.
Here's the scenario: I recently kicked the car into passing gear and throttle shifted it into the next gear with tons of torque. I heard and felt the axle "clunk" and dig hard right after the shift, but it held steady, so I backed off and took it easy after getting to a safe distance from the other cars around me.
Ever since then, any time I take off from a start, or shift to next gear with any sort of power, the rear end "clunks" and I feel a slight hop or jump on the right rear wheel.
The clunk sounds and feels as if it is only coming from the right.
Someone told me that this is probably not actually a problem with the rear diff (gears, axle), but probably just a case of the supporting brackets that hold the rear end and suspension to the chassis coming loose.
Am I right? Has anyone heard of this before?
Take it easy on me, as I haven't looked into the tech details yet.
Just looking for some friendly advice.
Thanks!
LT LS RS SS LS3 **LSA-Z28 (Skip the body kit)**
2KZ28_For_Now is offline   Reply With Quote
Old 02-17-2009, 11:21 PM   #2
2KZ28_For_Now
Drives: 2000 Z28
Originally Posted by Sandman View Post
Sounds like a bracket if it's only during high RPM shifts...
Thanks.
Old 02-18-2009, 02:04 AM   #3
MrCool
MrCool's Avatar
Drives: '95 Z28
Uh oh...a clunk is never good.
It might be something slipping in the axle, but then again...
MrCool is offline   Reply With Quote
Old 02-20-2009, 02:41 AM   #4
2KZ28_For_Now
Drives: 2000 Z28
Thanks for the reply. I'm guessing this isn't as common of a problem as I've been led to believe.
At least I got two replies. Thats a new record for one of my posts.
Sigh. Why do I even bother anymore.
Mods - please close this thread.
Thanks.
Old 02-20-2009, 08:04 AM   #5
Mr Twisty
Mr Twisty's Avatar
No response because it's hard to answer "Why does my car go chugga weeeee brap when I go stop turn"
Get the car off the ground and look close at all mounting points for the axle and suspension and frame rails. Look for signs of pieces moving when they shouldn't. Twist the driveshaft, spin the tires, listen for noises.
Old 02-20-2009, 05:05 PM   #6
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
It could be a multitude of things. You should check: Transmission mount, Control arms, torque arm mount at the back of the transmission, sway bar bushings and endlinks, U-joints, Panhard rod (centrally locates the rear end is at the back of the rear and goes from side to side).
If all that is ok then pull the diff cover and look for metal chunks.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 02-20-2009, 05:23 PM   #7
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
I was definitely going to suggest tranny mounts, but I know 4th gens have some sort of control arm back there that is prone to working loose....I've only owned 3rd gens.
What I want to know is what you mean by shifting into a passing gear?
MerF is offline   Reply With Quote
Old 02-20-2009, 05:36 PM   #8
Super83Z
Super83Z's Avatar
3rd and 4th gens share an Identical rear suspension. Everything interchanges. The only difference is the rear-end on the 4th is 2 inches wider.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 02-20-2009, 08:30 PM   #9
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
check your transmission mount. replace it with a polyurethane one. and dont just look at it. put a jack under the transmission tailshaft and lift it up. or just replace it for good measure. also check the lower control arms and their bushings as well as the panhard bar.
tho one question... what do you mean by "passing gear"?
I piss excellence
and fart awesomeness
Old 02-21-2009, 12:20 AM   #10
Super83Z
Super83Z's Avatar
Originally Posted by PoleCat2SSRS2010 View Post
torque boxes .
Camaro's don't have torque boxes
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 02-21-2009, 08:38 AM   #11
MerF
Go Rays!
MerF's Avatar
AWD Camaro, yo.
Camaro's axle to be produced in GM's Mexican assembly plant. Bruno 5th Gen Camaro SS LS LT General Discussions 31 10-27-2010 12:43 PM
OFFICIAL 2010 Camaro Specifications (full tech specs PDF inside) Tran Guides, Manuals, Bulletins, Documentation Archive 394 06-11-2010 07:16 PM
KC Area Dealers: The_Blur Seeking Employment The_Blur USA - Rockies / Midwest 15 01-20-2009 02:23 PM
Matteo From ITALY (seeking pricing and options) matteocapitani Camaro Price | Ordering | Tracking | Dealers Discussions 10 04-03-2008 06:04 AM
Announcing GM Tech Center Fbody Show TAG UR IT Off-topic Discussions 9 08-01-2007 02:20 PM
