B&M Racing
Old 03-27-2011, 02:18 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Pedders bushings.............install.....
Swapping my bushings slowly but surely. I guess I'll end up changing them all soon.
As I get to each one, I'll shoot some vid in case anyone wants to see how I did it. I'll just update here as I go.
But here's a little trick I learned from Pete at Pedders to get the bushings out. I made sure I got the right length bolt and the perfect size catch to be able to do the ones on the spindle/knuckle.
May be helpful.
I have no video editing program so all I could do is use YouTubes options and but them together. I'll try and make it shorter later.
Old 03-27-2011, 02:28 PM   #2
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
i used some 3/8" ready rod, and a few nuts/washers and the holesaw. removed factory bushings intact.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 03-27-2011, 02:33 PM   #3
PQ
Booooosted.
PQ's Avatar
You used a holesaw too?
I got it because it was the perfect size to use while doing it on the spindle. Plus, I didn't have a socket big enough and a socket that big cost more that then holesaw. haha
It just gets tight on the car like that. I had to find something that would fit in the tight spot.
Old 03-27-2011, 02:39 PM   #4
hot ss
hot ss's Avatar
necessity is the mother of invention, isnt it?
Old 03-27-2011, 02:41 PM   #5
PQ
Booooosted.
PQ's Avatar
Old 03-27-2011, 03:24 PM   #6
Rob@WretchedMS
Drives: His Wife Crazy
Great video!
Rob@WretchedMS is offline   Reply With Quote
Old 03-27-2011, 04:37 PM   #7
Mr Twisty
Mr Twisty's Avatar
1 1/2 inch holesaw? Worked pretty good! The fire vid scared me
-- Benjamin Franklin
Old 03-27-2011, 05:32 PM   #8
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Don't play PQ's videos around kids not use to cussing.
Great Video though.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-27-2011, 06:03 PM   #9
C586
Drives: 2011 Camaro LS
Something easier to use and wont ruin the hole saw is iron pipe and some washers. Use a screw on clean out with a hole drilled in it and same idea you had with the holesaw.
C586 is offline   Reply With Quote
Old 03-27-2011, 09:05 PM   #10
PQ
Booooosted.
PQ's Avatar
I actually looked for some pipe but didn't want to cut it and had to buy a length. It was easier and quicker at the time to just buy the 5 dollar hole bit. Down on the spindle it's just really tight. Had to get the exact right sizes. The method is the same.
Old 03-27-2011, 10:34 PM   #11
C586
I agree with you completely. In my area I can get very short sections of pipe with threads on the ends. I used the pipe method when I rebushed my old fiero. Never thought of using the hole saw. It is a really good idea though.
Old 03-27-2011, 11:32 PM   #12
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
I used a pair of bearing buddy's for a trailer and took out the grease fittings and put some washers in side with a snap ring. it fits perfectly over the stock bushings.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 03-27-2011, 11:41 PM   #13
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
between watching you & Chris, i've already planned out so many mods for my car, it ain't funny fixin to start on them soon
Old 03-28-2011, 12:47 PM   #14
PQ
Booooosted.
PQ's Avatar
Which ones you doing on your own?
Let me know when it's time to drop the front axle and steering ....... LMAO
2010 Camaro Full Pedders Justice Install - 1969 Camaro SS Big Block 6 Speed Install Greg@RPMM Suspension / Brakes / Chassis 9 03-02-2011 12:13 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 02:25 PM
