HURST
Old 03-29-2011, 03:10 PM   #1
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Airbag removal/diagram
Does anyone have a good diagram of the driver/passenger overhead curtain bags and side airbags? I need to remove them because my 8pt cage is going to interfere.
Ovenmitt is offline   Reply With Quote
Old 03-29-2011, 03:47 PM   #2
mortefer
Drives: 2010 Camaro 1LT, 2006 Ford Mustang
Just a general procedures that i know:
1. disconnect negative batt cable
2. wait a couple of mins, try to start a car (so that remaining electricity goes away)
3. remove side A-pillar trim (i belive it just pops off)
you should see the side airbag, and i think it's just bolt on...
But of you leave it like that you gonna get SRS error. To avoid that - you must install the resistor between contacts. 2-4 kOhm if i'm not mistaken.
mortefer is offline   Reply With Quote
Old 06-20-2011, 10:32 PM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
TTT. Cant figure out how to remove the silver spider clips that hold these bastards to the frame. They're metal and odd looking. Three Per side. Help!
DietCoke is offline   Reply With Quote
Old 06-21-2011, 11:05 PM   #4
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Crickets. Anyone have a GMLan subscription that can print out this section?
Old 06-26-2011, 06:01 PM   #5
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
up
Old 06-26-2011, 06:06 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Are you talking about the little black clips that hold the trim panel in place? When I did my C pillars you just had to slide the clip up a little bit, push on it and then pull it out.
Click to view my build thread
Old 06-26-2011, 07:18 PM   #7
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
No, the metal spider clips that hold the airbag netting to the a-pillar chassis member. They're unlike any clip I've ever seen before. I got them out by prying, but no idea how to remove them without totally mangling them.
Passenger airbag sensor issue? daveagogo1 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 32 01-23-2017 02:29 PM
AIRBAG SERVICING!? Lydon 5th Gen Camaro SS LS LT General Discussions 16 04-29-2011 01:31 PM
Airbag light Juls62 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 07-14-2010 09:29 AM
Anybody else had a service airbag soon pop up?? 1SS/RSCamaro2010 5th Gen Camaro SS LS LT General Discussions 7 04-04-2010 05:28 PM
