BeckyD @ James Martin Chevy
Old 02-19-2009, 12:27 AM   #1
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Oil Capacity LS3
Was kinda awed that the LS3 has an 8.6 quart oil capacity.
That is all..
Just didn't know if anyone else realized oil changes would cost $20 more.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 02-19-2009, 10:14 AM   #2
vsgls1
vsgls1's Avatar
Drives: 07 GMC Sierra
Send a message via AIM to vsgls1
Yup, gotta pay to play.
Keith 2SS/RS MN6 in CGM. Delivered 6/22/09. Blown 7/29/09. Sold 12/6/10.
07 GMC Sierra
vsgls1 is offline   Reply With Quote
Old 02-19-2009, 10:26 AM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
If you are going to use synthetic alot more than that. About 80 to 100.
Scott@Bjorn3D is offline   Reply With Quote
Old 02-19-2009, 10:30 AM   #4
CamaroSSforme
Got my two
CamaroSSforme's Avatar
Drives: 2010 Camaro SS/RS - RJT/Black
Send a message via Yahoo to CamaroSSforme
I heard the LS3 doesn't need oil changes...You just change out engines every 250,000 miles.
CamaroSSforme is offline   Reply With Quote
Old 02-19-2009, 10:41 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
LOL ....
Crowley is offline   Reply With Quote
Old 02-19-2009, 11:20 AM   #6
JJ#48Racing
Drives: 1998 Camaro SS
You'd almost assume it has a dry sump system with that capacity. I think it's that large because of the oil cooler. No complaints here though, I don't mind paying more for an oil change if it means I get more of it protecting my engine.
JJ#48Racing is offline   Reply With Quote
Old 02-19-2009, 11:54 AM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
$80? What brand of oil you using? I can get it done for $40-$50 depending on if I need to buy an oil filter.
Personally I'm not worried about the cost. Synthetic gets more mileage per quart then dino and with such a large capacity, you should be able to get 12-15k between oil changes easy.
Old 02-19-2009, 12:21 PM   #8
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
If you look at the pics it looks like the HUGE oil pan is the cause.
Average cost of good synthetic 6.00
x
9.00 quarts
= 54.00
an equally capable filter 10.00
$64.00 to do it yourself, add a little more for a shops time. And if your going to go 15k miles between changes your gonna need that $10-$15 oil filter.
Robert91RS is offline   Reply With Quote
Old 02-19-2009, 12:35 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
x
9.00 quarts
= 54.00
Or consider changing that filter a couple times during that interval. I've seen (somewhere) that synthetic oil doesn't really break-down, per se, but it just get contaminated by combustion blow-by and such. I personally don't care - I'll still be changing oil every 3-5K miles.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-19-2009, 12:38 PM   #10
camarolt76
2SS/RS Black/CGM Stripes
camarolt76's Avatar
Drives: 88 Iroc, 76 Camaro, 2010 2SS/RS
I did not realize the LS3 has an oil capacity of 8.6 quarts; however I am sure the Camaro will have an oil life monitering system which will tell you when the oil need to be changed. My wife's 2005 Monte Carlo has such a moniter
camarolt76 is offline   Reply With Quote
Old 02-19-2009, 12:45 PM   #11
blindingillusion
blindingillusion's Avatar
Drives: 2008 Chevrolet Cobalt 2LT
This is horrible of me, but I run synthetic in my cobalt and I only change the oil when the car tells me to. I changed it every 3-5K at first, but with my new job I decided to let it go one time (which I am currently still doing) and see how long the car recommends between changes.
I must say though, when it comes to my 'maro then I will be changing the oil more frequently, and with better quality then I have before. I hear royal purple is good, and good things about mobil1.
Ordered:
2010 Black 2SS/RS
-CGM Ralley Stripes
-Hurst Short Throw Shifter
-20" Polished Aluminum Wheels
Has Owned:
2008 Cobalt
1996 Monte Carlo
1988 Sierra
1979 LeSabre
blindingillusion is offline   Reply With Quote
Old 02-19-2009, 01:15 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
x
9.00 quarts
= 54.00
Most brands now a days offer 5 quart jugs for cheaper then what 5 individual quarts cost. The last time this topic came up I priced checked some prices. At Walmart you could buy 1 quart of synthetic of $6 or a 5 quart jug for $22.
Old 02-19-2009, 03:44 PM   #13
Banshee
Banshee's Avatar
Cost of 6 quarts of Pennzoil Platinum @ $6.49 quart $39..
Add 3 more quarts to make up the 5.5 qt. capacity of LS1 to LS3 @ 8.6 quarts.. 3 x $6.49 plus 6% tax equals $20.67
An additional $20 per oil change.
Old 02-19-2009, 04:20 PM   #14
pondo
Drives: '06 Corvette Convertible
I used to work for an engine oil additive company working on proprietary additive packages for leading oil companies. The weakest link is your oil filter and soot when running synthetic oil. Synthetic oils may be a LITTLE better at suspending solids but still marginally better than dino oil which means sludge will still build up in your engine. Increase the oil capacity will dilute the sludge meaning you can go a little longer before reaching the same detrimental effects...
Oil change intervals very depending on your climate, area of use, and driving habits. I've seen engines run for 25,000 miles nonstop 24/7 in the testing bay with synthetic oil and have vertually identical viscosity and lubricating parameters; however, the cylinder walls were still scratched. On analysis, the oil had very high amounts of aluminum and suspended carbon deposits.
I change the oil in my cars with mobile 1 10w30 full syn every 5,000 miles. I drive my cars like I stole them.
I will change the oil in my Camaro after break-in though. From there on, every 5k should do the trick.
I have personally ran all the tests listed in this PDF... http://www.amsoil.com/lit/g1971.pdf
Amsoil is listed #1 in all the tests...my personal results varied a bit but mobile 1 and amsoil were neck and neck!
“Scientists dream about doing great things. Engineers do them.” -James A Michener
On order:
2010 Camaro 2SS/RS Inferno Metallic Orange
Inferno Orange Trim Package
6 Speed
pondo is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Synthetic? shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 09-18-2008 02:31 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
