Erik@Torq
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 04-03-2011, 10:08 AM   #1
gtc352
Gtc352
gtc352's Avatar
Drives: 2010 2SS Camaro 2010 GMC Sierra
MSD BAP Wiring Question
I'm putting in a MSD (pn 2351) in my 10 Camaro. I've searched a few threads and it seems there are different ways of doing it. Does it splice into the fuse block in the trunk (r/w wire 4th down on the right) or does it splice into the FPCM (located on the passenger side rear seat wall I believe). Any help from those who have one would be appreciated!
gtc352 is offline   Reply With Quote
Old 04-03-2011, 10:19 AM   #2
oachalon
Drives: 2010 Camaro 1SS
GTC, i am part way through my installation, but it can be spliced in at both locations. Its the same wire, your just splicing at a different spot. Splicing in by the fusebox is less work as you do not have to remove much plastic trim. Splicing in near the FPCM removes some of that small awg wire going to the fusebox, and MAY possibly give you the most current possible going to your fuel pump.
Also if you splice in by the FPCM and mount your MSD under the backseat, the vacuum line run will be shorter than going all the way to the trunk.
I chose to go with the trunk.
oachalon is offline   Reply With Quote
Old 04-03-2011, 10:33 AM   #3
gtc352
Gtc352
gtc352's Avatar
That's the direction I was going! Thanks for the help!
NON-RS TO RS WIRING DIAGRAM w/RUNNING LIGHTS Bone Cosmetics and Lighting Modification Discussions 7 12-11-2010 07:10 AM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Modifications general question Eric's Blue Cosmetics and Lighting Modification Discussions 1 06-03-2010 12:24 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
