Emblempros
Old 05-12-2011, 08:04 AM   #57
mxfan127
mxfan127's Avatar
Drives: 2011 S/C CAMARO
its a 2011 ls and i dont mind if i have a long wire but i will be doing the dash and door abl soon id like to tap all from the correct wires
mxfan127 is offline   Reply With Quote
Old 05-12-2011, 08:14 AM   #58
St33lsinger
Emerald Coast Camaros
St33lsinger's Avatar
Drives: 2010 1 RS/SS
Originally Posted by rydahog View Post
got my plate from ebay,he took $44,, also led''s coming in blue..
cant wait..take pics after install..
lol he's not anymore.
Still 50 bucks anit bad.
Had: 69' RS, 78' Z28, 98' SS Have: 2010 1RS/SS
St33lsinger is offline   Reply With Quote
Old 05-13-2011, 10:52 AM   #59
rydahog
rydahog's Avatar
Drives: camaro ss
PIECE OF CAKE
ok got the cup holder led's in,,,easy job,,
before and after picts..what almost threw me was the lights were not on when i closed my door.. until i put a rag on the window sensor,,and created darkness,,dum sometimes,,
looks good...wating on plate..maybe today,,and will update with plate
later ryd,,
rydahog is offline   Reply With Quote
Old 05-13-2011, 05:38 PM   #60
rydahog
rydahog's Avatar
Drives: camaro ss
led and cup holder
done deal,,led's and cup holder, light does not leak to sides, if you move led up under plate,,,great install..
taking picts in dark is tough, but in real life, it looks good!! more than happy..and easyyyyyyyyyyyyyyyy!!
and my red stitching i did shows up pretty good...)
Old 05-13-2011, 11:03 PM   #61
PCOLASHAN
Drives: 2SS
Awesome, glad to see I could help!! Very easy mod and looks GREAT IMO!!!!
PCOLASHAN is offline   Reply With Quote
Old 05-16-2011, 12:26 PM   #62
St33lsinger
Looks awesome dude!
Old 05-19-2011, 09:38 AM   #63
kozzmo49
Drives: 2010 camaro ss rs
can someone post pics of how they connected the wires?
kozzmo49 is offline   Reply With Quote
Old 05-19-2011, 09:59 AM   #64
St33lsinger
Is it posiable to connect into the rear 12V connection in the center counsole box?
Old 05-19-2011, 10:52 AM   #65
rydahog
rydahog's Avatar
Drives: camaro ss
12 v?
i found this is a good location at the traction control, when i open my door, the led comes on in cup holder, if its light outside, it goes out, if dark stays on, and i can dim it also if i think the interior is to bright, when i shut off car, after a couple seconds light goes out with all interior lights.
good for my purposes..but i see what you want to do, that is fine also, just not able to use dimmer i think with that set up..later ryd,,
Old 05-19-2011, 11:05 AM   #66
St33lsinger
That sounds good.
Did you have to pull the shifter plate and all or can you get to it from the side? And what wires did you jump into?
I have a 1SS and non ABL if that makes any difference.
Old 05-19-2011, 09:23 PM   #67
rydahog
rydahog's Avatar
Drives: camaro ss
first posts..
That sounds good.
Steel take a look at the first couple of posts. it should be good for your 1ss but i am not sure about the ABl ?? you dont have to pull the shifter plate, the traction control pops up and then from there you take the clip that controls traction control and un-clip it,..(easy) and splice into the yellow and black wires..with the new red and black led wires...super easy process..if you follow directions in this thread..let us know how you do...maybe a pict of two..later ryd,.
Old 06-02-2011, 06:29 AM   #68
kikolosh
Drives: Camaro 2010 V6
i am interested on installing it. I have bought the blue led and the chrome part for the console cup. as i understood, i fix it, i send the wiring to the down part to the gauges and i pop it to the purple wire or the black/yellow wires ?
kikolosh is offline   Reply With Quote
Old 06-02-2011, 07:24 AM   #69
PCOLASHAN
Drives: 2SS
Black and yellow, see post 1.
Old 06-02-2011, 08:18 AM   #70
kikolosh
thanks. Is it easy to install in the yellow wires ? How i can do it ? peeling the yellow and puting the led wiring together the yellow ? thanks
Installed full dash and doors ABL, foot lighting with custom cup holder switch plate! CamaroC-17 Camaro Photos | Spyshots | Video | Media Gallery 23 02-06-2013 10:45 PM
DIY add light to inside door handle overhaulengines Camaro DIY & HOW-TO instructions & discussions 32 07-21-2011 10:58 PM
DIY custom ABL BlueSteele Camaro DIY & HOW-TO instructions & discussions 5 02-07-2011 02:05 AM
ABL lighting and Footwell Light Install? JProberts USA - Mid-Atlantic 3 02-25-2010 11:17 PM
