Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Camaro Fest VIII Discussions > 2011 Camaro5 Fest (II)
Old 04-05-2011, 02:27 PM   #1
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
OEM brakes ok for HPDE?
Im going to change my brake fluid and upgrade to BSS brake lines for the HPDE at the Fest but will the OEM brake pads be sufficent?
dont really feel like dropping a few hundred on 4 new brakes pads since the stockers only have like 6500 miles on them.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 04-05-2011, 02:32 PM   #2
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
You will be fine.....I used to HPDE in a 2007 TSX and the brakes went for almost another year after 2 weekend sessions. And I think when I had about the same amount of miles on those brakes.
I wouldn't worry too much, the brakes will hold up fine, maybe you will shorten the lifespan by half a month to a month. But don't worry about spending money on them right away to replace them.
Blade is offline   Reply With Quote
Old 04-05-2011, 03:05 PM   #3
JM10
Se habla español
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I have exactly the same mileage and bought the Hawk HPS brake pads along with Super Blue fluid.
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 04-05-2011, 03:10 PM   #4
Dirtdog
Dirtdog's Avatar
Im not so much concerned about the lifespan as much as overheating the OEM pads and have them fail on me.
Old 04-05-2011, 07:38 PM   #5
Rickerbucks
HP addict
Drives: 2 SS RS,
I ran around a track for half a day in my 2004 CTS ? (Same brakes) with absolutelky no problema at all. Dead stock. These stock brakes are V ERY good.
Yellow, Davenport 700, Pfadt coilovers and sway bar, Seibon CF hood, CF roof, custom CF trunk, Savini CF wheels, custom interior....you know what?....too much to list.
http://www.camaro5.com/forums/showthread.php?t=74691
Follow my 2013 One Lap Of America Blog here: https://www.facebook.com/#!/ShaunAnd...page_new_likes
2014 Jeep SRT 8 - stock
2010 Challenger SRT 8 - stock
2007 Charger SRT8 Super Bee - not stock at all.
Rickerbucks is offline   Reply With Quote
Old 04-05-2011, 09:42 PM   #6
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Not all that familiar with firebird but I understand its a short track just over a mile lone. Sessions are only 15 min ea and 3 of them. Track temps could be around 120. Unless you are a real bad driver you should be fine. Normally I run 20 min sessions and am pushing significantly more HP and hitting 145 on the backstretches at high plains raceway in Colorado. I have done 3 full track days (10 20 min sessions each) and still running on stock pads. Brake fluid upgrade is vital as you will boil it before you experience much fade. However, track temps will have an effect on these brakes so I would check your rotor temps after the first run so you dont overheat them. try and stay under 700 degrees. After your run do not just go park. Cruise around the parking lot not using your brakes to get some air thru them to cool them down before stopping. If you park with hot brakes you will superheat the section of the rotor under your pads and could warp them pretty easy.
Have fun...its a blast.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 04-05-2011, 10:09 PM   #7
Dirtdog
Dirtdog's Avatar
Excellent, that's for the replies everybody...see you guys at the track!
Old 04-05-2011, 10:24 PM   #8
600hp-lpe
Drives: 2010
Yes, the stock brake pads hold up pretty good. They won't melt into oblivion..
Upgrade the fluid and change the lines to SS and you will be fine.
600hp-lpe is offline   Reply With Quote
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
brakes losing power assist? 1977and2010 Suspension / Brakes / Chassis 6 02-28-2010 06:31 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
