Gen5DIY
Old 04-06-2011, 06:34 AM   #1
1995z28
1995z28's Avatar
Drives: Red 95 Z28
Advice!!!! SELL OR NO!?!?
I have a 1995 Z28 Red camaro and im really on the verge of selling it! My reasons are because i have now ran into another problem, the cooling system is not working, im guessing its the radiator because its leaking from that area and is not at all cooling my car. another problem im having is its either the shifter or tranny (automatic) because when i got to shift from park its really stiff and sometimes pops and or jerks, also when in park its seems to act like a park reverse mix because it wil try to roll back when i put it in park but wont because its locked with brakes and it revs like it were in a gear.... not a normal neutral or park position rev. The last problem im having isnt horrible but is my air intake i have to replace everything from the elbow down. It has 127,000 miles and i really wanna no if its worth fixing or just get another car. ADVICE PLEASE!! ANYTHING HELPS!! I can give more info if needed.
1995z28 is offline   Reply With Quote
Old 04-06-2011, 06:54 AM   #2
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Go get a 5thgen
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 04-06-2011, 10:11 AM   #3
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Leak sounds like a water pump. Shine a light down by the Opti and check to see if it's damp down there (slightly behind the radiator on the front of the block). If the pump and opti are showing any signs of moisture I'd say put it up for a DP on another 4th gen or an LS/LT 5th gen if you can hack it.
Why: Water pump + Opti = Oy Vey..
Also check this: http://www.2carpros.com/questions/19...ssion-problems
If the torque converter isn't releasing, it will seem as if it isn't coming out of gear. Also, the reverse issue is odd. That can be a broken reverse band. I have also seen situations where the low / reverse clutch pack retainers have broken and the vehicle is always in drive (even when placed in reverse they fight themself).
Basically the trans is going to have to be dropped and torn down.
As for the intake, did the elbow brake/crack somehow?
Where are you at in Michigan anyway?
Zabo is offline   Reply With Quote
Old 04-06-2011, 03:23 PM   #4
1995z28
1995z28's Avatar
Drives: Red 95 Z28
damn.... im really leaning towards selling it now... im located in the detroit metro area. The intake elbow just has a rip where it connects to the throttle body and the intake tubing and filter just needs to be replaced in general. But what would you recommend because I dont have the money to spend on a huge replacement for this car.
Old 04-07-2011, 09:46 AM   #5
Zabo
Gunning for Sixth
Zabo's Avatar
Honestly, I'd take it in and have a reputable transmission shop take a look at the car by 'attempting' to drive it to see first hand what the shift linkage and transmission is actually doing. The water pump may not be much of an issue but labor wise it's a pain.
Again it could also just be a bad seal or something. Depending on the age it could also be a bad impeller which is common on some GM pumps.
Depending on the labor involved and what actually is wrong with the transmission, it may be easier to just repair the trans, and sell it with a good trans but with a bad pump if you're that short on cash. Layering up repairs like that is really gonna 'bone' ya in the wallet.
Old 04-07-2011, 01:41 PM   #6
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
+1 I see bone stock transmissions selling for 800 to 1K all the time on LS1tech. It does sound like you water pump. I agree with Zabo with the opti+water= If you've gotta be in a camaro, a trade in for an 00-02 LS1 4th gen shouldn't be too hard to come by with decent mileage and good price.
TFord is offline   Reply With Quote
Old 04-09-2011, 01:04 PM   #7
1995z28
1995z28's Avatar
Drives: Red 95 Z28
thanks for all the advice guys its a hard choice weather or not to get rid of my baby.. =/
Old 04-11-2011, 12:44 AM   #8
Stl_Camaro
Stl_Camaro's Avatar
Drives: 12 Dodge Avenger, 02 Trans Am WS6
The only advice I have is dont sell it! you'll regret it. I regret selling mine every day. I want another one soooo bad, but dont have the funds at the moment.
Stl_Camaro is offline   Reply With Quote
Old 04-11-2011, 12:51 AM   #9
Sevn86
Sevn86's Avatar
Same here! Selling my 2010 Camaro is the worst decision Ive made so far in life.
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 04-11-2011, 12:57 AM   #10
Blueovalman
Blueovalman's Avatar
Drives: Ford Mustang
If your 1995 Z28 has high mileage or you are questioning repairing
it or not I would trade it in at a dealership for a 00-02 LS1 4th gen or sell your 1995 Z28 private owner (to someone that is willing to repair it)
and then fined a 00-02 LS1 4th gen. for sale.
I know my friend had a leaking water pump and it made his opti spark
fail from all the moisture leaking from his water pump on his 1994 Z28.
It was such a pain in the romp to fix my friend ended up taking it
to the Chevrolet dealership service department to get fixed.
Transmission repair or replacement can get pretty costly.
Good luck.
www.ebaymotors.com
www.autotrader.com
www.cars.com
www.carmax.com
www.desertautogroup.com
Blueovalman is offline   Reply With Quote
cooling, drivetrain, problems, z28
ok, need some advice on how to talk to this dealer.... haleyd 5th Gen Camaro SS LS LT General Discussions 137 03-18-2010 10:22 AM
I need some advice on the color selection here. 13F20 5th Gen Camaro SS LS LT General Discussions 33 02-14-2010 04:31 AM
HELP,... Where Is The Best Online Place or Places To Sell Your Vehicle At? RCPW General Automotive + Other Cars Discussion 10 12-17-2009 03:04 PM
Iacocca rips auto industry, warns: Don't sell Chrysler KILLER74Z28 General Automotive + Other Cars Discussion 6 04-13-2007 11:38 PM
