JUICEDMOTORSPORTS
Old 01-12-2012, 12:14 AM   #127
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Awesome! Very interested to see some track times when you get it done. Most people don't like taking their verts to the track.
SUX2BU is offline   Reply With Quote
Old 01-12-2012, 06:19 AM   #128
572HP
ACE5 (Atlanta Group)
572HP's Avatar
Drives: "Black Ice"
Thanks man! I will be getting a removable 6-point roll bar fabricated that I'll bolt in before I head to the track. They will weld in some brackets to bolt the bar to. I'll just have to pull back the carpet and bolt it in. I'll have a harness that mounts to the roll bar also. My goal is for the drag strip to keep it over 11.0. Anything under that and I technically need a roll cage, and that isn't going to happen. I am pretty much duplicating one other member's setup for his coupe where he ran a 10.8. I'm working with Ted at Jannetty Racing and he suggested that we go with the torque converter instead of rear gears.
So for now, I'm going to keep the stock bottom-end of the engine. Hopefully it will hold up.
Once I got the vert, which is also an automatic, I fell in love with it.
572HP is offline   Reply With Quote
Old 01-19-2012, 03:12 PM   #129
572HP
572HP's Avatar
Drives: "Black Ice"
Well, haven't posted anything in awhile, so I thought I would update everyone. I have everything installed. A few things required installation more than once. Thanks bigsquirrel for loaning me the flywheel locking tool. That made getting the harmonic balancer bolt out easy.
To put in the flywheel locking tool, I needed to remove the starter. Unfortunately I already installed the headers and the new spark plugs. To remove the starter, the passenger side header had to come out. The plugs had to come out too. Oh well, already knew how to do that...just took a lot of time.
Everything went in pretty easy. I wasn't able to install my new Elite Engineering catch can. The bracket that comes with it is for the passenger side, and it mounts under the tensioner pulley. Unfortunately, whipple supplied me with a whole belt pulley system. The bracket won't work with this pulley system without a different type of mounting bolt. I also have been advised to use two catch cans. One on each side. For FI, it is suggested to put the catch can on the driver side. However, the bracket has nowhere to mount. I need a different bracket. I guess I need to get in touch with Elite to figure this out. For now, I'm not running anything other than a straight tube.
The engine started up just fine. Boy it is a nervous moment as you are turning the key for the first time. Before the supercharger, one day I started the car with the stock exhaust manifolds and stock cats. I was amazed at how quiet it was! After installing everything, and before I hooked up the exhaust, I wanted to test it out. Now all that I had on there was headers and straight pipes. OMG THAT IS LOUD. It didn't sound that good either.
I have been trying to figure out a problem with the data-logger software. For some reason it doesn't want to log anything. Talking with SCT support now. I did test drive the car though. It seemed to be driving just fine, with no knocking. Ted needs me to datalog the car so that he can tell if everything is running good.
After a few test drives with nothing more than half-throttle, I decided to floor it once. I was going about 50 down the highway. I punched it, and the tranny kicked it down a gear or two, AND THE BACK TIRES BROKE LOOSE!!! AT 50mph!!! It felt like so much more power than the callaway. I got off the throttle right away...I want to be sure that the tuning looks good.
Oh...and I love the little bit of whine that the whipple has.
Pics will come soon. However, I'm not proud of the engine compartment yet. Too many wires and ugly hoses. That is my next project.
Old 01-19-2012, 03:16 PM   #130
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
So.... when do we get to see it in person?
Toyaholic is offline   Reply With Quote
Old 01-19-2012, 03:20 PM   #131
572HP
572HP's Avatar
Drives: "Black Ice"
I'm hoping MTI day...but I need to get a family pass if you know what I mean.
Old 01-19-2012, 03:35 PM   #132
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Looking good Joe! Love that lift you have!!!
Can't_C_Me is offline   Reply With Quote
Old 01-19-2012, 03:36 PM   #133
572HP
572HP's Avatar
Drives: "Black Ice"
Thanks. That lift was a very good investment!
Old 01-19-2012, 07:23 PM   #134
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Glad to hear it's running well! I can't imagine the nerve racking moment before turning the key. If I did all that work MYself, I'd expect it to explode into a million pieces and take me with it, lol. I don't know how you did it Joe, but you did! You're doing great work and I wish you well on keeping it up!
hightower is offline   Reply With Quote
Old 01-19-2012, 08:20 PM   #135
572HP
572HP's Avatar
Drives: "Black Ice"
Thanks! I've always had the confidence to do things myself. Unfortunately when I was young, the confidence was not due to experience. I probably broke more things than I fixed. Now my confidence comes from research and past experience. I still make mistakes, but I get them resolved one way or another.
After all day trying to get the damn logging software to work, I'm still at a loss. I'll be back on the phone with them again tomorrow.
Old 01-19-2012, 09:47 PM   #136
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
I can't wait to see this...I gotta start saving up now for the supercharger.....or do I...
hahah kidding of course.
Joe, MTI said they would charge me 100-200 bucks to put my exhaust on at the gathering...do you think that is fair or should I try to do it myself? I figure you'd know the level of difficulty.
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 01-19-2012, 10:08 PM   #137
572HP
572HP's Avatar
Drives: "Black Ice"
I figure $50-$75 an hour is fair. They could do this job in 30 minutes max. You do the math. I would call it fair if they charged you $100, because it would take you a long time. It isn't hard, but if it has been put on a car already, then the tubes where the clamps went will need to be stretched back out. Got a tool for that? See what I mean?
Old 01-20-2012, 09:56 AM   #138
garcmol
garcmol's Avatar
Where did you have the car painted? I tried like hell to get these local hacks here to disassemble my car to get what I wanted to no avail. Settled for stripes and they still screwed that up. Has since been fixed by Gary in Florida. But I'd like to go with my original idea if I could find a decent painter and Atlanta's not a big stretch to get to.
I saw your paint at Pony Wars and it turned out great!
Oh, and any progress on the light mod?
Old 01-20-2012, 10:04 AM   #139
572HP
572HP's Avatar
Drives: "Black Ice"
4RD H8R works for Performance Auto Collision. They do a lot of high-end repair work on porsches and such. They aren't cheap...but obviously you are done looking for cheap. Neal was the real reason why it turned out as good as it did. He kept on them making sure it was as perfect as could be.
I need to get back to the lighting mod, but been a little busy.
Old 01-20-2012, 10:06 AM   #140
Brolik10
BLOWN!!!
Brolik10's Avatar
Drives: 2010 RJT 2SS
i guess i shouldve posted this in this thread... Here goes.. Are you staying with the stock cam or going blower friendly?
Blown! Full Bolt-ons!
Brolik10 is offline   Reply With Quote
Preview of convertible before ordering pony Camaro Convertible Forum 0 08-28-2010 10:49 AM
NCE Camaro convertible drop top first drive! black_camaro_SS 5th Gen Camaro SS LS LT General Discussions 71 08-07-2009 04:58 PM
Official 2010 Camaro convertible concept pics!! Tran Camaro Photos | Spyshots | Video | Media Gallery 107 07-21-2009 12:12 PM
2007 Ford Mustang Shelby GT500 Convertible KILLER74Z28 General Automotive + Other Cars Discussion 10 04-11-2008 05:11 PM
