Gen5DIY
Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 04-28-2011, 03:59 PM   #26
elsololobo02
elsololobo02's Avatar
Drives: 2011 Camaro LS Turbo
Well for those that are interested I had the new wastegate and manual boost contoller installed. The new wastegate has a 7lb spring and my controller is set to zero for now. Will do some data logging to send to Trifecta to get some timing issues corrected. After the install my speed shop did some pulls on their dyno. I have attached copies of the graphs. FYI if you plan to go over 5lbs of boost you will need to get new plugs with a low heat range and smaller gap. The additional boost pressure was blowing out the spark with the spark plugs that STS supplied in the kit at 4000 rpm's. My speed shop stated that we could potentially get an additional 20-40 hp with some spark advance. I plan to boost to 8lbs once I get the tuned dialed in.
elsololobo02 is offline   Reply With Quote
Old 04-28-2011, 06:57 PM   #27
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 2012 LFX/2011 EcoBoost F-150
Very nice!
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-Drag Radials-CircleD 4000 Stall-GPI Fuel Enrichment System
586 RWHP & 606 RWTQ @20 psi on 93 Octane (unlocked converter)
1/8 mile -- 7.158 @ 102.10 (20psi)
Build Thread
GretchenGotGrowl is online now   Reply With Quote
Old 04-29-2011, 02:10 AM   #28
Jshadow
31B MP
Jshadow's Avatar
Drives: 2010 1SS CGM Camaro
Send a message via AIM to Jshadow Send a message via Yahoo to Jshadow
Oh snap your in Va Beach?! I wanna check out your car! i live near the Landstown area :p
2010 Cyber Grey Metallic 1SS
Razzi Side Skirts
CAI Inductions Intake
Eibach Springs and Sways
Borla S-type Catback Exhaust
Stainless Power Long Tube Headers
Phantom Grille
Vmax Throttle Body
Jshadow is offline   Reply With Quote
Old 04-29-2011, 11:52 AM   #29
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
Not too shabby!
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 05-12-2011, 01:03 AM   #30
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
These threads are very interesting. I like seeing all the ingenuity that goes into FI. One question though. I've read a few things, and isn't it true that rwhp is typically around 18% less than flywheel horsepower, and if this is true, then these kits are not pushing out more than about 450hp? I keep seeing where the manufacturers of these kits claim 600+, and its just not a reality. I would love to move this direction, but the claims are just not coming thru.
K&N Cai, BSR Ported intake, MBRP catback, BBK long tubes, VMax throttle body, 3.73 SS gears, Zex nitrous 125hp shot, window switch, purge,remote bottle opener, bottle heater, Trifecta tune, Hurst short throw, RX catch can, Intake isolator, Ported Intake manifold
jeff4946 is offline   Reply With Quote
Old 05-12-2011, 03:39 PM   #31
Edge.128
Edge.128's Avatar
Drives: 2010 Camaro LS
i'm not sure anyone has ever claimed 600+????
but you are mostly right they are pushing about 450rwhp. no one has really pushed the boost up super high yet so there is still room once the other issues are figured out.
2010 Summit White Camaro LS / M6
MRT V2.0
Edge.128 is offline   Reply With Quote
Old 05-13-2011, 01:30 AM   #32
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
I think he's looking at the V-8 Kits.
Z Madness is offline   Reply With Quote
Old 05-13-2011, 05:10 AM   #33
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
http://www.phastekperformance.com/20...O-V6SINGLE.htm
This one claims 620hp. And I'm not saying rwhp, because with the boost and numbers that are being logged, I haven't seen anyone hit the 400rwhp mark at all yet. Not trying to get anyone's goat, just not seeing 6k dollars worth of gain in these yet.
Old 05-13-2011, 08:04 AM   #34
GretchenGotGrowl
Yeah, that's the rating for the turbo. For example, each of mine are rated for 624 HP. So, with twins you would think I could easily get close to 900 HP (some loss due to charge restriction), but it will not happen on these cars because we will not produce that much exhaust.
Also, think of the "value" of the gains this way. Go to Chevy's web site and compare the prices of comparably equipped LS/LTs and SSs (don't take the cheapest SS and most expensive LT). The median of those is about $8K. If you get have an automatic car the difference in BHP is 88 HP. I know on my setup I'm getting about 430 BHP on 4.5 psi (118 BHP). The kit based on mine is under $8K. You do lose the powertrain warranty, but you risk that with any mod. The advantage of FI is that further power increases are relatively cheap (up to a limit of course).
Not busting your chops, but saying it is a better mod for the buck than say buying an SS if your intent is to make the most of your car powerwise. I didn't buy the V6 to see if I could make more power than a stock SS, I bought it because I thought the engine was cool and wanted to see what could be done with it (oh and it is an awsome looking car). I've been pleased that they take to FI so well. It will take a while to get all the issues worked out and have these things make real power, but isn't that true everytime someone releases a radically new engine design (I know DI and VVT have been around, but not in cars that people typically think of taking to the track).
Build Thread
Old 05-13-2011, 09:17 AM   #35
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
That's cool that you guys are getting those kind of gains, but unless you are saving a ton of money, why bother? If your intention from the start was to get better HP numbers, wouldn't it be easier (and cheaper) to start with the V8? After spending the cash and cranking up the HP on the V6, your where the V8 starts, or at least in the neighborhood.
If you bought the V6 for other reasons, then decided to mod, more power to you.
This is NOT a dig on the V6, or a V6 vs V8 thing.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 05-13-2011, 09:27 AM   #36
GretchenGotGrowl
I guess that's what I'm saying. For about the same price you get a car that makes more power than the SS. I'm only running 4.5 psi. Bump that up and you have more power at no extra cost. You would have to put dollars into a tune and bolt ons for the SS. Yes, at some point you can't make the power of a larger displacement engine at the same price, but then it just becomes a V6 thing. Besides, I fully expect to see V8 engines adopt these technologies and I'll be very familiar with how to mod them when it happens.
Build Thread
Old 05-13-2011, 12:15 PM   #37
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
No, I'm with you. I just want to see these hit their full potential. Love my v6. Happy with my decision, just wanna see the turbo work like the claims that are made. I see IPSjeff making some progress, but the tuning is slowing him down, just like the rest. Like he is right on schedule.
Old 05-13-2011, 12:20 PM   #38
GretchenGotGrowl
No, I'm with you. I just want to see these hit their full potential. Love my v6. Happy with my decision, just wanna see the turbo work like the claims that are made. I see IPSjeff making some progress, but the tuning is slowing him down, just like the rest. Like he is Brighton schedule.
No doubt they have a lot of potential. Unfortunately we aren't going to have a lot of the big companies jump in and work the issues out for us. We're all going to have to contribute and be patient with the few shops that are doing something.
Build Thread
Old 05-13-2011, 12:23 PM   #39
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
Yessir... you are correct.
Old 05-16-2011, 09:55 PM   #40
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Mine is over 404RWHP right now and getting more so Look at IPS Motorsports....
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 05-22-2011, 08:28 PM   #41
elsololobo02
Well I just got back from a business trip and did some data logging. Sent the info to Vince along with the dyno graphs (A/F, Boost and HP). I will post new graphs once Vince tells me there is no more he can do to modify the tune. The car hauls the mail now (with current tune) and can't wait for the new tune results.
Old 05-22-2011, 08:39 PM   #42
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Sweet nice to see this turbo thing really taking off. It is looking like Vince just keeps getting better tuning these FI cars. I see my future. LOL
OOLIE is offline   Reply With Quote
Old 06-16-2011, 06:05 PM   #43
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
If your still around, I'd like hear about things went
Sent from my DROIDX using Tapatalk
MyWorld is offline   Reply With Quote
Old 06-17-2011, 09:23 PM   #44
D1ABOLIK
Drives: 2010 Camaro
I am dying to get a turbo set up for my V6 but Im concerned about all the headaches I see you guys going through at the moment. Im hoping they get more reliable with these kits in the near future.
D1ABOLIK is offline   Reply With Quote
Old 06-17-2011, 09:39 PM   #45
D1ABOLIK
Drives: 2010 Camaro
Im a bit of a noobie when it comes to turbos, but I was looking at the sts turbo set up, the filter under the rear fender of the car conerns me, how do you keep it from getting wet when it rains? I know its a stupid question but be easy on me lol
Old 06-18-2011, 12:11 PM   #46
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
The air filter does not get wet in the rain.
Old 06-20-2011, 08:30 PM   #47
elsololobo02
The air intake filters are up on top of the wheel wells. They are placed as high as you can physically get them and for additional protection the filters have a extremely fine mesh that goes over the filter element that a very water resistant.
Old 06-21-2011, 12:42 AM   #48
D1ABOLIK
Drives: 2010 Camaro
1 more question, what headers are you guys running with your set ups
Old 06-21-2011, 01:58 AM   #49
Z Madness
Z Madness's Avatar
For STS specifically, most are running stock. You can run any headers as the turbo attaches at the rear of the stock exhaust but the stock cast iron exhaust manifolds are recommended.
For the other kits, you would be looking at shorties in order to get the turbos to fit (assuming mid mount).
Old 06-21-2011, 12:16 PM   #50
D1ABOLIK
Drives: 2010 Camaro
Cool, thanks again
How much is the STS single turbo? HarrisraTx Forced Induction - V6 70 10-21-2010 08:37 PM
Turbo Kits/Reliability OTK_Master Forced Induction - V8 48 06-10-2010 02:53 PM
exhaust with sts turbo Bungalowbandit Forced Induction - V8 2 11-28-2009 11:27 AM
****ETMC, VORTEC SUPERCHARGERS/MAGNACHARGERS/ STS TURBOS YOUR ONE STOP SHOP!******* east TX Muscle cars Forced Induction 1 11-11-2009 08:24 PM
