Old 02-22-2009, 06:18 PM   #1
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
ZR1 brakes?
What are the chances that the ZR1's CCM brakes will be able to be swapped onto the Camaro? Does anyone know?
UsedTaHaveA68 is offline   Reply With Quote
Old 02-22-2009, 06:32 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
100% chance.... with the right amount of money.
I piss excellence
and fart awesomeness
Old 02-22-2009, 07:23 PM   #3
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
And that would be a LOT of money, indeed. Thousands per corner I'm told.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 02-22-2009, 07:39 PM   #4
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
I echo the above and wonder why? Yes they could stop the earth's rotation, however are you racing or something?
2010 Chevrolet Camaro SS - was daily driver, now toy
2014 Mercedes Benz E350 4matic Sport - Daily Driver
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1995 Volkswagen Golf Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 02-22-2009, 07:48 PM   #5
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
im sure theyll fit. as long as you got the 15g's to cough up for them.
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 02-22-2009, 09:39 PM   #6
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
to buy the disks and calipers is around 8k from a dealer if you can find a vin for a zr1 to order them.
the problem is you probably dont want to do it. I was one of the first people to start posting about doing that swap, but in all my research you wouldnt want too. With the extra wieght brembo/race dynamics say the car will have major problems with brake modulation. give it a little and it will slow down a little, then give it a little more and it will stop the car completely. the zr1 uses a computer actuated controller for the brake cylinder, and you can't just swap one into the camaro as it wont give enough pressure to make up for the added weight. so you'd have to stomp th brake all the time. so overall your much better off looking at larger bicast disks and calipers from a cts-v
headpunter is offline   Reply With Quote
Old 02-23-2009, 12:43 AM   #7
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
and the cts-v package looks like it's a relatively easy swap from the video of the SEMA cars being built
Old 02-23-2009, 09:41 AM   #8
CamaroSpike23
Truth Enforcer
I piss excellence
Old 02-23-2009, 11:18 AM   #9
Mr Twisty
Mr Twisty's Avatar
14 inch brakes not big enough??? I'll wait and see if I can make the stock stuff fade, if so, might just need a pad change.
-- Benjamin Franklin
Old 02-23-2009, 11:19 AM   #10
headpunter
headpunter's Avatar
Drives: Man
may not be enough for some people.
Old 02-23-2009, 11:53 AM   #11
CamaroSpike23
Truth Enforcer
a lot..... too many people put too much emphasis on the "Go" and not enough on the "whoa"
I piss excellence
Old 02-23-2009, 12:51 PM   #12
UsedTaHaveA68
Stock Diameter should be plenty big enough. 14.4" discs with 4 piston calipers should be big enough your limiting factor will be traction between the tires and road, not ability of the brakes to slow the car. My main concern is weight. Anyone ever picked up a set of 14+" iron discs? I was reading about Aston Martin's latest DBS which uses 15" CCM brakes. They saved 25lbs PER WHEEL over the iron discs. A 100 pound reduction of rotating, unsprung weight does wonders for both handling, braking, and accelleration.
There's no way I could spend 8000 on brakes, so I had planned on shopping around for wrecked ZR-1's being parted out. Guess I'll stick to two piece discs with aluminum hats.
Old 02-23-2009, 12:59 PM   #13
Rogue Leader
From my experience working for an insurance company previously, high end cars that are totaled and parted are usually parted for big bucks. Meaning you probably wouldn't save much on those brakes as shops looking to fix non-totaled cars faster jump all over model specific parts like that. There are much cheaper ways to achieve the same result you're looking for..
Ive seen completely obliterated rolled Lamborghini Murcielagos go for over $100,000.
Old 02-23-2009, 03:15 PM   #14
UsedTaHaveA68
Thanks Rogue, I was unaware of that. I'll probably just get some of Brembo's cross drilled/slotted rotors with aluminum hats like on the GS Camaro. And hopefully talk Riley Technologies into selling me their carbon fiber hood/fenders/trunk lid!
MT: ZR1 vs 599 GTB Comparison DGthe3 General Automotive + Other Cars Discussion 8 12-09-2008 12:16 PM
Interesting ZR1 Read TFord General Automotive + Other Cars Discussion 2 09-09-2008 10:32 AM
2009 ZR1 specs' released by GM radz28 General Automotive + Other Cars Discussion 6 06-17-2008 01:48 PM
Chevrolet Corvette ZR1 (2008) andykhol23 General Automotive + Other Cars Discussion 3 05-22-2008 12:24 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
