ADM PERFORMANCE
Old 02-22-2009, 06:21 PM   #1
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
LS3 good to 7k?
Not that I would consider tearing a perfectly good camshaft out of a still warrantied engine... But let's just say someone did. Is the stock bottom end good for another 500rpm? I'm not looking at anything huge, but most cams for the LS3 seem to really start picking up around 5500 and go to 7000. I'm not going to window my block am I? Should I start saving up to invest in a forged crank/rods?
UsedTaHaveA68 is offline   Reply With Quote
Old 02-22-2009, 06:34 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
it'll be fine. the pcm will cut the fuel/timing off/back before you can spin it too high... that is unless you miss a gear downshifting. then you are SOL
I piss excellence
and fart awesomeness
Old 02-22-2009, 10:21 PM   #3
UsedTaHaveA68
Well with a new camshaft I would obviously retune the PCM, but would want to take advantage of the new power up top, so would reset the limit a little higher. Is the stock bottom end able to handle 7000rpm?
Old 02-23-2009, 09:45 AM   #4
CamaroSpike23
Truth Enforcer
yes. theres stock bottom end LS1s and LS2s out there turning 7000+
but why do you want to spin past 7000? maybe im too old for thinkin this, but I like having power across the board, not just for a 2500 rpm span. granted, for peak power numbers you can throw a cam in that will make your dyno look like mount everest, but id rather have useable power thruout the power band
its nice to rev, its nicer to move.
I piss excellence
Old 02-23-2009, 10:24 AM   #5
spd98
Drives: had a goat
Should be but most cams will fall flat on thier face before you ge there. you need valvtrain upgrades. Remember the cam is spinning at 2x the speed of the crank.
spd98 is offline   Reply With Quote
Old 02-23-2009, 10:59 AM   #6
UsedTaHaveA68
I agree about the "better to move." I'm not looking to make 550rwhp N/A with stock cubes. I'm shooting for about 450 with LT headers, high flow cats, catback, CAI, and a mild cam. On the dyno graphs I've seen of the LS3's, MOST mild cams make only slightly more hp/tq than the stock cams until about 5500rpm, where the stock engine starts to turn down, and the aftermarket cams continue the trend upward until around 7000. Maybe one day I'll build a 416 stroker and make 500tq at 2500rpm, but for now I'd like to keep the bottom end stock. So basically I'm just looking to keep similar power levels below 5000rpm and gain the 50-60hp above that for my trips to the strip. That's why I was wanting to know if the stock bottom end can handle the extra revs. It certainly won't spend the majority of its time there.
And I will upgrade the valvetrain with appropriate valvesprings/titanium retainers. I've read the valves on the LS3's are the hollow sodium filled, so those should be good. Thanks for the info guys!
Old 02-23-2009, 11:14 AM   #7
SS 376
SS 376's Avatar
Drives: IBM 1SS
Judging by the numbers the C6 guys are putting out on their LS3s, you should be able to hit your goal. Their experience should be a good benchmark for us. 450 whp is very realistic and, from what I remember, it's not a problem for the LS3 to rev just a little bit more to 7000 RPM.
SS 376 is offline   Reply With Quote
Old 02-23-2009, 11:52 AM   #8
CamaroSpike23
Truth Enforcer
swap in the hot cam and all the bolt-ons and you should be around 450 fwhp easy.
these heads that are on the car tho... they are bad-freaking-ass. you can get the exhaust ported a little bit over stock, but they flow incredibly well compared to previous heads.
I piss excellence
Old 02-23-2009, 12:53 PM   #9
Mr Twisty
Mr Twisty's Avatar
Agree...Look close at the stock torque curve compared to aftermarket sticks. Better top end but sacrifice low end grunt.
-- Benjamin Franklin
Old 02-23-2009, 03:09 PM   #10
UsedTaHaveA68
Most mild cams I've seen (less than 230 duration at .050", .575 lift or less) make about the same, maybe slightly better than, power as the stock curve until around 5000 where they continue to pull. Just go to the GMPP catalog (http://www.gmperformanceparts.com/_r...09_Catalog.pdf) and look at the HOT cam.
Stock tq@2500 ~ 375
HOT cam tq@2500 ~ 400
The stock starts to level off around 5500 and is falling by 6000. Not by much, I understand that, but gains up top are what I'm looking for without giving up power down low. That's why I'm staying with a fairly mild cam, because I don't want to give up all the low end grunt. Mostly I'm looking for bragging rights at the strip/autocross while staying fairly incognito. And if the occasional Challenger or Mustang GT comes along, I'd like it to be less of a driver's race and more of my engine kicking the crap out if theirs.
Old 02-23-2009, 06:09 PM   #11
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
CAI, Longtube headers, Catback and Cam. Just Do It!
Check out Corvette Forum for more info, very common.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 02-26-2009, 12:51 AM   #12
gunslinger
Drives: 1998 Z28 M6
Uhh, just to correct the above post, the cam spins at HALF the crankshaft speed, which is still quite fast considering what is does!
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 02-26-2009, 03:47 PM   #13
o2camaross
o2camaross's Avatar
Drives: 2010 2SS/RS & 04 silvy
i was just about to point that out
the car redlines at 6600 stock, when you put a bigger cam in it, i dont see why it would not make power up to 7k, so i dont see a problem reving it that high.
o2camaross is offline   Reply With Quote
Old 02-26-2009, 04:20 PM   #14
CamaroSpike23
Truth Enforcer
well, its not just making power up to 7k, its also being able to spin the motor that high before the rotation of the motor exceeds its capabilities.
however, I dont see that being much of a problem with the LS3
I piss excellence
Big 3 CEO's (and UAW CEO) answering questions on CNBC (yesterday) TAG UR IT General Automotive + Other Cars Discussion 101 11-21-2008 02:14 PM
Is alternative energy as we know it today a good Idea? Angrybird 12 Off-topic Discussions 15 08-09-2008 03:18 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
Crash tests downgrade small cars KILLER74Z28 General Automotive + Other Cars Discussion 0 12-19-2006 04:31 AM
