Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 02-23-2009, 02:31 AM   #1
aborrego
aborrego's Avatar
Drives: 2002 chevy tracker
Exclamation hood problem
i have a problem with my 1991 RS camaro i thinks it has a 1969 RS hood becuase it dosen't want to close right and i can pick it up more than 55 mph or the hood starts to lift. so how can i fix this with out buying a new hood?
:5thgenvert:
aborrego is offline   Reply With Quote
Old 02-23-2009, 10:20 AM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
um.... dont think that a 69 hood would fit on a 91.
but check the latch on the front as well as the spring on it. have someone pull the hood release cable as well to make sure its not binding.
I piss excellence
and fart awesomeness
Old 02-23-2009, 11:30 AM   #3
Mr Twisty
Mr Twisty's Avatar
^ what he said. Yeah sounds like it's not even latching but hanging on the safety catch. Latch probably needs adjusted.
When you pop the hood, does it actually pop up half an inch or so?
-- Benjamin Franklin
Old 02-24-2009, 12:24 AM   #4
aborrego
aborrego's Avatar
no i have to pull on the hood
:5thgenvert:
Old 02-24-2009, 12:25 AM   #5
aborrego
aborrego's Avatar
its like putting two male connections together
:5thgenvert:
Old 02-24-2009, 05:38 PM   #6
Iroczlover
The Krazzy bytch
Iroczlover's Avatar
Drives: Which car I have 9 vehicles?
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
Open the hood, Give the latch a spray of DW 40 & have someone pulling the latch cord from the inside.
Sounds like the hood is totally out of alingment. is there any gapping around the hood?
Heart breaks everyday when you cant take care of your family because you are unemployed, cant give your family what you want or what they need
I am not a man I have boobies.
Cars are like women, If you treat her rough shes going to complain & you will hear about it. If you treat her right she will purrrrrrrrrrrrr
Current cars owned , 72 Skylark vert,86 fiero GT Sold , 87 Iroc-z (sold), 90 Vette Vert SOLD , 95 Z28, 99 Silverado K1500 Totaled, 2010 CGM Camaro 2ss/rs (had to sell & I hate it ) ,2012 Cruze LT repoed.
Current current list lol 2006 Silverado 2500hd.
Iroczlover is offline   Reply With Quote
Old 02-24-2009, 08:21 PM   #7
Mr Twisty
Mr Twisty's Avatar
What irocz said...also, look at how the hood latches, lower male catch goes into the upper latch, mounted on the underside of the hood. Do they appear to be aligned when the hood is almost down? If so, try raising the lower catch. Loosen the set screw, raise it a couple of turns, and see if the hood catches when you close it. Remember how many turns you rotate it in case it doesn't help, you can set it back where it was.
It's hard to say what the prob is without looking at it in person.
Old 02-24-2009, 10:00 PM   #8
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
use a marker on the screw and the piece it goes into so you can be acurate with how many turns .
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 02-25-2009, 12:24 AM   #9
Xlr8torZ28
aka: The Evil Joker
Xlr8torZ28's Avatar
Drives: 1991 Z28 (murdered out)
Thirdgens are plagued with a bad hood design. It seems on 90% of them, you've got to shimmy the hood when opening.
X2 on the WD40
1991 Z28 305H.O. TPI T56 six speed w/ B&M ripper shifter, ROH Drift-Rs 18x9 w/265/35-18s & 18x10 w/295/35-18s, 4.10s, K&Ns, Holley 52mm, ADS Superchip, Hedman headers & Y-pipe, custom Flowmaster, MSD, SLP posi unit, Koni yellows, Eibach Pros, Lakewood boxed rear control arms, TDS wonderbar, Hotchkis dbl adj panhard bar
Xlr8torZ28 is offline   Reply With Quote
Old 03-09-2009, 09:51 PM   #10
scottmoyer
Drives: 1987 Camaro IROC-Z
Third gens aren't plagued with a bad hood design. The supports are worn and need replacing. That will help with the opening of the hood. If you think you have a 69 hood, then I can only assume that the hood is an aftermarket fiberglass hood. If that's the case, anything can be the issue.
Moderator of History/Restoration Forum on Thirdgen.org
87 IROC 350 ** 19k miles **
scottmoyer is offline   Reply With Quote
1968 Nickey Camaro hood??? 1968 Nickey 1st & 2nd Generation Camaros 6 03-19-2010 01:05 AM
New Hood Idea, need photoshop experts!!! ZZcamaro Camaro Photoshops / Renderings Forum 8 03-01-2009 08:34 PM
ram air style hood? tsg1391 Cosmetics and Lighting Modification Discussions 1 10-23-2008 05:43 PM
Faux hood scoop..... CamaroSpike23 5th Gen Camaro SS LS LT General Discussions 5 10-13-2008 09:42 PM
Problem with my v6 TonytheTiger 4th Generation Camaros 12 08-22-2008 03:34 PM
