Old 04-15-2011, 10:58 AM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Someone please make this DIY!
If someone more qualified than me would make this DIY, I would be so thankful!
Would someone be willing to make a DIY about how to make a switch in the cabin?
Will lots of layman terms with the wiring...
To clarify, I am trying to make a switch for my halos in the headlights. I just have no idea where to begin!
I saw the threads with running wire from under the hood to inside the cabin, but I don't know what to do to make the wires into a switch.
Thanks,
Roshan
Old 04-15-2011, 05:48 PM   #2
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
I can try and put something together Monday if nobody beats me to it by then.
Darth Martel is offline   Reply With Quote
Old 04-16-2011, 08:16 PM   #3
Rob191288
Rob191288's Avatar
Drives: 2010 Camaro LS
its really easy all you need to do is put the negative wire onto a ground, take your postive wire and its going to plug directly into the switch, then your going to have a negative on your switch as well, and your gonna have one more wire come from your switch which is going to plug directly into a 12V or battery terminal.
Rob191288 is offline   Reply With Quote
Old 04-16-2011, 08:38 PM   #4
Rob191288
Rob191288's Avatar
Here is a basic layout of how it should look. There is another way you can do it where you use a relay but you shouldn't need a relay with halos.
Old 04-18-2011, 01:01 PM   #5
ihaveacamaro
I like teeth.
Drives: #198
Please do!
Thanks! This simplifies the whole thing greatly! Btw, could you explain the power for the switch. Can I just use a fuse tap?
Old 04-18-2011, 01:09 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by ihaveacamaro View Post
Please do!
Yes, you can just tap into any of the 12v constant fuses
Click to view my build thread
Old 04-25-2011, 11:59 AM   #7
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yes i just tapped into a fuse for some footwell lighting i installed. I installed it with a toggle switch.
Old 04-25-2011, 12:09 PM   #8
The Stig
The Stig's Avatar
Here you go
http://www.camaro5.com/forums/showthread.php?t=131838
Old 04-25-2011, 05:13 PM   #9
ihaveacamaro
I like teeth.
Drives: #198
all I have to say is
Old 04-25-2011, 05:31 PM   #10
The Stig
The Stig's Avatar
Glad I could help
What song are you listening to right now Muscle Master Off-topic Discussions 6400 02-19-2018 08:20 PM
DIY - Adding YOUR car to YOUR Tom Tom Sir Nuke Camaro DIY & HOW-TO instructions & discussions 126 01-17-2018 01:25 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
