autoguy
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 04-16-2011, 04:24 PM   #1
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
subframe bushing question?
hi,
I bought subframe bushings and need some advice. I would like this shop buy my home to install but the mech. states he needs to remove the cradle from body to install and disconnect the driveshaft.
Does anyone have a link on how to install and i thought you can install these bushings by cutting out the old and just lowering the cradle instead of full removal.
Also i remember reading a while back that you shouldn't reuse the rear driveshaft bolts. I think Vinny from the bronx had this problem???
i tried the search and couldn't really find what i needed. Any advice is much appreciated
thxs joey
chopss is offline   Reply With Quote
Old 04-16-2011, 07:39 PM   #2
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
If you feel like taking a ride in to bklyn we can help you out. You do not have to do all that. Yes you have to lower the subframe. Most shops don't know what there doing if they haven't done them before. I personally have the pedders set in my car and we have don't a few. Let me know if there is anything I can do for you
camaro4mybday is offline   Reply With Quote
Old 04-16-2011, 10:11 PM   #3
Jaysin
I Void Warranties
Jaysin's Avatar
Are you talking subframe inserts or full bushings???
The inserts are easy to install without removing the subframe or disconnecting the driveshaft.
I installed full bushings by just lowering the subframe, and I did have the drive shaft disconnected, which allows the subframe to come down a bit lower. I also was doing it on jackstands. That said, if I had it to do again, I would remove the subframe completely. It would just be a lot easier, at least on jackstands.
Kooks Headers, CAI Inc. Intake, Catch Can, Pedders Supercar Coilovers, Sway Bars, All Pedders Bushings, Spohn Trailing Arms and Toe Links...
Jaysin is offline   Reply With Quote
Old 04-17-2011, 06:45 AM   #4
chopss
chopss's Avatar
Jaysin. I have the full bmr pro poly bushings.
Camaro4mybday. Sent you a pm.
Thxs for all your response.
Joe
Old 04-17-2011, 07:59 AM   #5
camaro4mybday
"Camaro Joe"
wow i just read the bmr instructions thats totaly crazy now i know why the other shop wanted to do it they way they wanted to and drop it all down, i bet they wanted to charge you an arm and a leg.but i guess every company is different, glad im a pedders man but we can deffinitly take care of you joe
Old 04-18-2011, 10:44 AM   #6
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
It doesn't matter if you are using Pedders or BMR full cradle bushings, the installation is the same. It can be done by lowering the cradle but is way easier with the cradle removed as Jaysin pointed out. Either way, labor is definitely the largest expense for this mod...
Brett
Internet Tech
BMR SUSPENSION
BMR guy is offline   Reply With Quote
Old 04-27-2011, 04:16 PM   #7
chopss
chopss's Avatar
thank you camaro4mybday for installing the bushings.
I wrote an honest review in the vendor/experiences section
Old 04-27-2011, 07:51 PM   #8
camaro4mybday
"Camaro Joe"
brett you are correct the products of both bmr and pedders are the same type of bushings, i think bmr is a great product and have used bmr in other older projects. deffinitly not knocking the products in any way. but having the tips and tricks passed on to me from the pedders crew on the other side of the world and from pete himself has made the install very simple with out removing the subframe or exhaust with the car on the lift. about 2.5 hours drive on to drive off on the 2 post lift. but which ever product is used as long as the end user is happy we all win
Old 04-27-2011, 07:54 PM   #9
camaro4mybday
"Camaro Joe"
i know you will really love your upgrade!
Old 04-28-2011, 02:12 PM   #10
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I understand. It's sharing the tips and tricks of installation that benefits the community as a whole. 2.5 hours on the lift is very efficient for full bushings and I am sure the community would love to see how that is done. Full bushings generally scare the typical enthusiast away from this mod because of the intense labor it requires...
Brett
Internet Tech
BMR SUSPENSION
Old 04-28-2011, 02:57 PM   #11
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS
Joey Z.
Yes, please share your tips and tricks!!!! Obviously, I can't drive to NY, and I don't trust anyone around here to do it either!!! So, my only option is to do it myself. I do have access to a lift, but I'm still "scared" to try this on my own!!! Anything to make it easier would be greatly appreciated!!!
blazzin1 is online now   Reply With Quote
Old 04-28-2011, 06:18 PM   #12
camaro4mybday
"Camaro Joe"
i will say this the little tricks are on the forum already, posted by justice pete, it involves cutting the bushing center out then scoring the composite body in a few spots, the down fall to this is the spray of hot rubber, but protective gear is a must ill see if i can find a link to it
BMR Subframe Connector Installation How-to BMR guy Suspension / Brakes / Chassis 13 05-06-2011 11:59 PM
stereo question bigted83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-07-2011 04:56 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Im Stuck!! BMR Sub-Frame Connectors or Hotchkis Brace se7en Suspension / Brakes / Chassis 16 04-23-2010 05:16 PM
