HeadlightArmor
Old 02-23-2009, 10:36 PM   #1
BLUEMARO
A Classical Greek
BLUEMARO's Avatar
Drives: DTS, Bonneville and an SS !
EVENT CODE AND ORDER CHANGES
At what event code are changes to the order not allowed any longer? For example if I wanted to change colors at event code 2000, is that doable?
BLUEMARO is offline   Reply With Quote
Old 02-23-2009, 10:39 PM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
I believe the cut-off point is 2000. Perhaps someone else can confirm.
Inspector 17 is offline   Reply With Quote
Old 02-23-2009, 10:41 PM   #3
nol300
Drives: 92 300ZX TT 2007 Silverado
Correct once GM has accepted the order you can no longer change.
nol300 is offline   Reply With Quote
Old 02-23-2009, 10:42 PM   #4
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
So I can't get polka dots anymore at event code 3400 ? Damn.
trm0002 is offline   Reply With Quote
Old 02-23-2009, 11:56 PM   #5
FAF
Member
FAF's Avatar
Drives: 2010 Camaro, 2008 Tundra
can someone please explain why the orders stay at 1100 for ever what doe it take for GM to accept an order is there an error that wont get accepted. seems that orders should go to 2000 a few days after 1100 and then sit there until necesary.
FAF is offline   Reply With Quote
Old 02-24-2009, 12:13 AM   #6
trm0002
trm0002's Avatar
My original order was placed day one on October 13th and was still at 1100 on January 31st when I canceled it and opened a new order at a different dealership (because they were accepting discounts). It wasn't until a couple weeks later that it moved from 1100. In fact, that was about the time that a good handful of orders changed and a lot of those were Oct/Nov orders. I guess what I'm saying is I see no rhyme or reason why it jumps levels or whether I'd be concerned if it stayed at 1100 for a while considering how fast it can move once it does.
Old 02-24-2009, 12:15 AM   #7
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Wait... you ordered a couple weeks ago and your order has moved? And you're getting discounts????? HOW????
UCF w00t is offline   Reply With Quote
Old 02-24-2009, 12:20 AM   #8
trm0002
trm0002's Avatar
You know the answer(s) my friend. I know we've discussed this thread...
http://www.camaro5.com/forums/showthread.php?t=12624
See the first post.
Old 02-24-2009, 12:22 AM   #9
UCF w00t
Geek
UCF w00t's Avatar
ahhh
Old 02-24-2009, 07:31 AM   #10
Inspector 17
I love crepes
Before an order can change from 1100, GM needs to conduct a consensus. The first one of those happened just a few days ago so no orders up until that point changed from 1100. The consensus tells GM and dealers how many cars they are going to produce in the next month. From there, GM adds on any constraints and each dealer is told they can order x number of cars or certain types (say 1LT, 2LS, 0SS, 12SS or whatever). At that point, the dealer decides what they want (or what orders are going to be filled). Then, the status can start changing. Make sense?
Old 02-24-2009, 03:15 PM   #11
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
Surprisingly it does make sense. I'd love to have a 12SS, talk about loaded, but have you seen the price tag on one of those bad boys? Had to settle for the 0.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline   Reply With Quote
Old 02-25-2009, 09:12 AM   #12
fastdoc436
fastdoc436's Avatar
Drives: 2010 2SS/RS,35thLE/SS,30thAE/SS
I thought you could change orders in 2000s. I changed from auto to manual and event code was 2050 (order changed). I hope I didn't mess up the order??
Ed
2002 35thLE #2474, SLP #5430
1997 30th SS Anniversary Edition #805, SLP #2244
2010 2SS/RS M6, black/black, 20's polished, #11399, DT shorties, muffler delete, RotoFab CAI, Hurst ST shifter, 20%tint, Pfadt lowering springs/ sway bars/ rear trailing arms.
fastdoc436 is offline   Reply With Quote
Old 02-25-2009, 10:03 AM   #13
mdky2kss
mdky2kss's Avatar
Drives: 1978 Z28,1986 Iroc,2000 SS
Send a message via AIM to mdky2kss
We have the ability I believe to make changes up to the 3000 event code, but it requires backing the order out of the system. It will push it back a little bit, but requires someone to call the plant manager and have the order pulled. We did it on a Z06 corvette a couple of years ago.
mdky2kss is offline   Reply With Quote
I Received A Different Letter From GM Steve 5th Gen Camaro SS LS LT General Discussions 734 09-25-2009 07:51 PM
Did you get an order # or any refernce for your pre-order? D1BADZ Camaro Price | Ordering | Tracking | Dealers Discussions 21 05-22-2009 06:39 PM
Sample Order Event Code History UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 7 02-11-2009 03:17 PM
