04-17-2011, 05:40 PM | #1 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Benefits of Higher RPM
Sup guys,
So I talked to Vince, about changing the redline limit. Our Camaros currently redline at 7k? I asked if there would be any benefits to raising the RPM. Let me know what you guys think, I already have an answer from Vince. But what do you guys think? Would it benefit? For forced induction and N/A. =D
04-17-2011, 06:32 PM | #2 | |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
04-17-2011, 06:37 PM | #3 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I don't think I want to run the engine over 7 grand lol.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
04-17-2011, 06:40 PM | #4 |
Track > 1/4 Mile
Actually dosn't it redline at 6,700 or something like that? But it looks like 7,000.
04-17-2011, 06:53 PM | #5 |
Yeah, it says 7000 on the tach but its really 6700.
04-17-2011, 06:55 PM | #6 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
As other have said... don't raise the rev limit... looks like peak is just above 6,500..
I'm guessing go above the stock redline and bad things are going to start happening.. |
04-17-2011, 07:45 PM | #7 |
I have no life
I'll show you guys what Vince wrote me.
"The stock V6 has a redline of 7000 RPM. Sometimes better performance can be had by revving the engine past peak power depending on how much the RPMs fall when you shift to the next gear (especially if the RPMs drop significantly due to a wide gear spread) but the 6sp auto keeps the RPMs pretty tight." So, basically we won't get much benefit from it. The A6 at least. But the reason I brought this up is because my brother owns a Honda Prelude, and he tells me most Honda guys tune their rev limiter to a higher, usually 200-300 more RPM than their current redline. They say it makes all the difference in a drag race. I personally, dont know, and I knew the power starts to drop after our peak... so the only way it would make sense is the RPM drop between shifts like Vince has stated above. Anyway just wanted to see what you guys think.
04-17-2011, 08:06 PM | #8 |
Ok... to really see the detail you need to click on the picture to see it enlarged:
On the 1-2 shift the car shifts at just above 6,500 RPM and the RPMs drop down to just under 4,500. On the 2-3 shift the cars shifts at about 6,700 and the RPMs drop down to 4,750... So IMHO no reason to run the RPMs up to avoid the RPMs dropping to low on the shift... |
04-17-2011, 08:19 PM | #9 |
And since our cars engine makes most of the power in that range, there's still no need to raise the red line.
04-17-2011, 08:26 PM | #10 |
I have no life
thanks for the pic Scrming =D Yeah looks pretty good lol.
04-18-2011, 12:24 PM | #11 |
Drives: 2010 Camaro LS Join Date: Sep 2009
i think it was the 3rd gen camaros or one of the older versions anyway that you had to either run up against the rev limiter at the 1/4 mile or shift for the last few feet. so i'm sure a lot of people run into this problem and instead of changing gears or whatever to make up that difference they raise the rev limiter a bit so they can stay in gear a bit longer instead of shifting. that is what I have heard anyway. to me that doesn't really get you any further ahead but to each their own.... as others have said for our car it shouldn't really get you anything.
2010 Summit White Camaro LS / M6 MRT V2.0 |
04-18-2011, 12:52 PM | #12 | |
Drives: 2010 Black Camaro 2LT/RS Auto Join Date: Apr 2010
BackInBlack
Performance:Vararam cold air intake |
04-18-2011, 01:26 PM | #13 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Could they make us sound like an Indy car??
Thread Tools | |
Similar Threads | ||||
The 2011+ Mustang Thread | GatorBlue371 | General Automotive + Other Cars Discussion | 11874 | 08-23-2011 12:30 PM |
Ultimate Bolt-On Project or Racers Wet Dream? | JusticePete | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 04-27-2010 04:01 PM |
GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
1 3/4's vs 1 7/8's Headers | brAnd7onX | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 01-11-2010 05:43 PM |
ZL1 Camaro | 94blackcamaroz28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 57 | 07-10-2008 11:09 PM |
