Caryle Racing
Old 04-18-2011, 02:29 PM   #1
JKEP44
Drives: 2011 Camaro SS
L99/A6 Differential gear change
Im looking at changing my ring and pinion out to get more punch off the line. I dont take my car to the track and mostly stay in town so no need for it to be able to go 140mph for long periods. That being said I have done some searching around on here and found quite a few people that have done gear swaps with the LS3/M6 combo but not many who have done them with the automatic. I would think that the 3.73 set up would be good but the 4.10 or 4.11 seems like it might be a little better. Is there anybody out there who has done one and liked the combo that they got?
JKEP44 is offline   Reply With Quote
Old 04-18-2011, 03:22 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
I was looking into a gear swap for a while but have decided to wait because of things I've heard on the 4.10 breaking and being a little too low for daily driving use.
I have a LS3 so going from a 3.45 - 3.73 isn't a whole lot and is hard for me to justify the $1200 cost.
Now, with an L99 you'll go from a 3.27 to 3.73 which you'll definately feel that. The 3.73 is supposed to be a solid gear and is what they are putting in the ZL1.
From the research I've done the best gear for the L99 seems to be a 3.73. Alot of that has to do with the gearing in the transmission as well. It's different than the gearing in M6. The 4.10 on an A6 is supposed to be really low. Probably too low for daily driving use.
If I had an A6 I would pull the trigger on the gears.....but that's me and my car is a daily driver as well. Being that I have an M6 I'm going to wait a little while and hope to find a used 3.73 some day.
Build Journal
Old 04-18-2011, 04:59 PM   #3
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
I have the AAM 3.70's in my A6 and love it. Either them or the Richmond 3:73's would be a good choice. AAM supplies the stock 3:27's in your A6.
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 04-18-2011, 05:03 PM   #4
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
i have the aam 3.70 in my m6 car, my buddy has my 3.45 in his a6 car and said he can feel a difference.
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 04-18-2011, 05:22 PM   #5
caverman
caverman's Avatar
About how much are ya'll paying to have the gears swapped. I've basically seen about $1100 for the swap with another $100 for some rearend bushings.
I'm not sure that's worth the difference for an M6.....A6, absolutley I would do it.
Build Journal
Old 04-18-2011, 05:28 PM   #6
sspaul
sspaul's Avatar
i think the rebuild kit is like $250.00 or so, aam 3.70 gear from lingenfelter are $700.00 i believe, i paid some one $175.00 to install gears (i took center chunk out and brought to him) so you should be right around $1100.00 for everything. or you can find a m6 guy that is looking to do it and trade him your rearend for his plus give him a little cash (only if you would want to jump up to the 3.45)
my youtube
my facebook
750/641 rwhp/rwtq
Old 04-18-2011, 05:42 PM   #7
JTC/C5
JTC/C5's Avatar
Drives: 2010 2SS L99
Hugh difference, I have 3.73 richmond gears, car was amazing!! now when u add the 3200 stall torque converter LOOK OUT! car is a beast.. Completely different launch!..you will eat up tires along with most people that pull up next to you... def worth it, but def do the TQ
To Be Continued
JTC/C5 is offline   Reply With Quote
Old 04-18-2011, 05:55 PM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
When equipped the the automatic transmission (A6) the SS comes with a 3.27 rear end and cruises at 1795 RPM at 70 MPH. By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 15% or 61.5 rear wheel lb.-ft. of torque and cruise at 2050 RPM at 70 MPH. By upgrading the A6 to the 4.11s you will realize an equivalent torque gain of approximately 27% or 110.7 rear wheel lb.-ft. of torque and cruise at 2250 RPM at 70 MPH. The A6 transmission is geared more aggressively than the M6 SS so we have found that 3.73 is the ideal gear for most A6 equipped SS applications.
Originally Posted by Sick SS View Post
I have 3.73s and love them!! It give you that "push you in your seat felling".
Originally Posted by cybercoaster View Post
Got 3.73's in mine over the weekend - wow. I did notice the increase in RPM as well. It's pretty expensive but talk about the butt in your seat. The head rest is now a head stop.
Originally Posted by camaro1 View Post
3.73's are great in the auto, you can really feel it pull through the gears faster, and hwy cruise rpm is only about 250rpm higher
Old 04-18-2011, 08:14 PM   #9
tarheel34
Go Heels!!!
tarheel34's Avatar
Drives: 2010 Camaro 2SS/RS
I wish I could find someone around my way that would actually install a 3.73 in my A6. No one wants to touch the thing. They act like I'm asking them to work on a spaceship!
Team L99
2010 Summit White 2SS/RS L99: TSP 1 7/8 LTs - Off-Road Pipes | Tuned By BLUECAT | CAI Cold Air Intake | ADM Race Scoop | SLP UD Pulley | VMAX Throttle Body | Magnaflow X-Pipe | Muffler Delete | SLP 160* T-Stat | MSD Wires
tarheel34 is offline   Reply With Quote
Old 04-18-2011, 08:48 PM   #10
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
call livernois motorsports they will pick your car up...they did my stuff and the transport wasnt that expensive
bmbbl be is offline   Reply With Quote
Old 04-18-2011, 09:52 PM   #11
JKEP44
What type rear end is this anyway? I haven't even crawled under the car to look.
Old 04-18-2011, 10:11 PM   #12
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I have said before that the buddy gear swap thing works out great. Find a M6 guy that wants gears. Put the M6 3.45 rear center section in the A6 car. Put the new gears in the A6 center section and install in the M6 car. Share the cost - everyone wins!
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 04-19-2011, 12:06 AM   #13
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I had a new complete JRE diff installed in my L99 and I can say it made a very noticable difference. You would also be wise to get a custom tune on your car that turns off the torque management system which also give your car alot more attitude.
My rear end has the billet caps, posi upgrade and I also replaced the Diff bushings. I also replaced the trailing arms with a set of Pfadt arms and replaced the bushing as well. Dramatically stiffened up the rear end. For day to day driving I am still undecided about the posi upgrade because its TIGHT on the slow speed tight corners in parking lots and such. On the high way and normal use, no real issue.
There is slightly more gear noise at speeds from around 43 to 48 mph but nothing below this, nothing above this. This may simply be from the more solid bushings as well instead of the gears themselves.
All in all, very happy, a bit tighter then I would have liked but getting used to it but the launch kick in the rear is noticably more potent. Since I am getting the car ready for a supercharger installation, I will take a bit of tight corner popping for solid two wheel launches.
In the L99, you will see and feel a noticable difference with the 3.73 gear upgrades. Is it worth the cost. I put $2350 into the JRE rear and would do it again.
Kirby
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 04-19-2011, 03:11 PM   #14
sspaul
sspaul's Avatar
thats the way i did it, couldn't have been happier
my youtube
my facebook
750/641 rwhp/rwtq
What song are you listening to right now Muscle Master Off-topic Discussions 6400 02-19-2018 08:20 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
not enough v6 with gear upgrade bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 58 03-08-2011 10:03 PM
2010 Camaro LS3 - Rear End Gear Change DNA V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 08-11-2010 10:01 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
