Caryle Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Audio / Visual / Electronics/ Gauges / Nav
Old 04-23-2011, 02:31 PM   #15
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Old 04-23-2011, 04:08 PM   #16
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
I would be interested if you still have kits available
KnightRiderSS is offline   Reply With Quote
Old 04-23-2011, 04:32 PM   #17
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Yes, i do let me know.
Old 04-23-2011, 06:07 PM   #18
jdec141c
Drives: 11 Camaro Vert 2SS/RS 6M Hurst
Thanks for your quick response today. Pleasure doing business with you!!! Thanks Darth Emma for pointing me in the right direction.
jdec141c is offline   Reply With Quote
Old 04-23-2011, 07:48 PM   #19
2SSRS@Gen5diy
Thank you.
Old 04-24-2011, 01:02 AM   #20
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I am buying soon but would like to know this first please.
Originally Posted by 2SSRS View Post
For a camera i have two ways to do it with one from a chines manufacter and is a 1/3" color chip, The next one is non chines.
which camera did you use?
Old 04-24-2011, 06:59 AM   #21
monstertodd
monstertodd's Avatar
PM sent,
I'm interested in the kit, please put me down for one. Can you please elaborate a little more on the two different types of cameras? Do the cameras come painted?
Old 04-24-2011, 11:51 AM   #22
2SSRS@Gen5diy
Cameras here are the two cameras.
1: this is the cheaper of the two, It is made in china and is cut down to the new size.
info.
Image sensor: 1/3" colour CMOS
TV system: PAL/NTSC
Effective pixels: 628 x 582
Sensing area: 5.78 x 4.19mm
Sync system: internal
Resolution: 420 TV lines
Minimum illumination: O.5 Lux/F1.2 (0 Lux with IR)
S/N ratio: more than 48dB
Electronic shutter: 1/50 - 1/10,000 seconds
Video output: RCA connector, 1.0vp-p, 75Ω
Current consumption: <=250mA
Power supply: DC 12V
Dimensions: 58 x 25 x 30mm
Weight: 70g
Second camera:
Its OEM here is how it comes thanks STINGS
Info on the camera.
1/4″ Panasonic CCD Color Camera
5 Lux For Illumination & Sharper Image
Color Image w/Automatic White Balance
Electronic Auto Iris
150 Degree Horizontal and 100 degree Vertical Lens with Excellent Depth of Field
Waterproof Case w/Anti-fog Lens
Old 04-24-2011, 01:14 PM   #23
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
I will go with the second camera.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Old 04-24-2011, 01:47 PM   #24
VenomZ302
Live to Win, Dare to Fail
VenomZ302's Avatar
Am I right in assuming that you'd pretty much have to cut a box out of your bumper to use the second one, as opposed to drilling 1-5 holes (depending on whether you use 3M tape, instead) for the second?
Is there a difference in viewing angle or anything important like that between the two? Do they both display the guide lines?
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6!
7/13/09 - Built!
8/11/09 - Delivered!
2G1FT1EW2A9124579
Old 04-24-2011, 02:16 PM   #25
2SSRS@Gen5diy
Yes you will have to cut a box out of the bumper, there close on viewing angle 170 for the first one and 150 for the second one.
Old 04-24-2011, 08:55 PM   #26
KnightRiderSS
Voodoo Medicine Man
I guess I don't understand how the second one is better?
Doesn't the first one have a larger CMOS a lower lux which makes it more sensitive to low light situations? Also has a RCA connector/smaller for an easier installation?
Old 04-24-2011, 09:04 PM   #27
2SSRS@Gen5diy
The second one comes with the water tight connectors on the out side, so you have them at the pint of the camera and then it comes with a grommet to go in to the trunk and a second water tight connectors as apposed to a RCA jack.
Old 04-24-2011, 09:42 PM   #28
KnightRiderSS
Voodoo Medicine Man
Ah, I see...would it be possible to send the aftermarket one with my kit? Thanks!
Worth to pursue? (car scratched my rear view mirror) eggydoo 5th Gen Camaro SS LS LT General Discussions 14 12-04-2010 12:57 PM
