04-22-2011, 01:38 AM | #1 |
The Milkman
Shorties vs. Long tubes
After spending hours trolling,... Im done. While there are many threads around about headers, I cant find one that compares shorties to long tubes in a direct sense.
So, lets hear about the pros and cons of both. Gain comparisions, CELs, installation, ect. My own Qs are about which gives more gains and is it true that with shorties there is no concern of CELs while with long tubes you will definitly see them? If there is a thread out there already that makes these "apples to apples" comparisions, then I guess I missed it.
YESTERDAYS ANSWERS HAVE NOTHING TO DO WITH TODAYS QUESTIONS
04-22-2011, 02:37 AM | #2 |
Drives: 1LT Join Date: Feb 2010
Simply put: shorties= less power, NO cel. LT=more power, CEL guaranteed.
-21" GM wheels -3.73 gears -Injen PowerFlow CAI
-OBX LT headers -Doug Thorley Catback exhaust -Magnaflow High Flow cats -Trifecta Tune -VMAX Ported TB -Maces 25mm Insulator -Ported Intake manifolds (soon) |
04-22-2011, 05:16 AM | #3 |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
from personal experience...LT's = CEL and a nice gain also opened the exhaust up even more for a bad ass sounding V6.
really depends on what you want. are you going for maximum gains by keeping it NA or do you just want to pep it up a bit? a comparison of both is really done from looking at the claims made by the manufacturers with real numbers, shorties are almost always half the HP of LT's. BUT there are a handful of guys on here who started with shorties that can give you a real world comparison and hopefully some dyno numbers along with butt dyno affects. either way you'll be happy. good luck
04-22-2011, 06:57 AM | #4 |
Drives: 2010 iom camaro 2lt Join Date: Mar 2010
so with shorties you can put on without doing a tune?
04-22-2011, 07:09 AM | #5 |
I've had BBK T 304 Stainless shorties on my car for over a year. Running through the stock 4 - 600 cell catted mid pipes there is a seat of the pants increase from 3,000 rpm and up. Even more so when coupled with a good CAI. The BBK shorties running through the JBA high flow 200 cell catted mid pipes I had installed at one time there was a seat of the pants increase from idle to 3,000 rpm and an even bigger increase from 3,000 rpm to 6,500. No CEL and I do not have a tune. No doubt long tubes with high flow cats will give a greater PEAK gain than shorties with high flow catted mid pipes, but the long tubes will guarantee a CEL and the need for a tune to eliminate it. If your future includes a cam, supercharger or other major power adding work, the long tubes are the way to go. If you want to retain the stock tune, CAI, high flow catted mid pipes and shorties is about as far as you can go.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
04-22-2011, 07:28 AM | #6 | |
04-22-2011, 03:45 PM | #7 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Sorry to say there is no guarantee of no CEL with shorties. I chose shorties to avoid them but made the poor choice of going with JBA (didn't do my homeswork).
They are an inferior design made with poor materials. After following their instrutions to the letter, I still got leaks (both sides) at the "stacker flange" attachment point. They expect a clamp to maintain an air tight seal between the header and the rest of tha exhaust system. Funny how their shorty header for the V8 has a traditional bolt-together clamp. So I got a CEL. I was able to seal the leak temporarily with some stuff called "Acousti/seal exhaust system sealinng compound" part #35959 made by Tenneco, but then I had some service done and they had to drop the exhaust. Bye-bye seal, back to square 1! |
04-22-2011, 03:56 PM | #8 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
i would say shorties are mainly for looks,but you won't need a tune.
04-22-2011, 04:07 PM | #9 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
Tune isn't a requirement for longtubes. If the CEL bothers you a lot, you can get it. I drove mine around for months without a tune and there are others on here that have also run without a tune. I finally went with the tune when I got a nitrous kit.
The tune did make it run slightly smoother(or maybe it was me wanting to feel it) but it didn't give it much more power. I have the manual, so there was no "tranny tune" for me.
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
04-22-2011, 04:10 PM | #10 |
Drives: 2010 Camaro Join Date: Feb 2010
Long tube headers are the way to go for maximum power. Check out the American Racing Headers for the V6. I had a first hand look at this system while at CamaroFest II in Phoenix and they are awesome. Go with the headers, high flow cats and the x-pipe center section. This system will need tuning to get the maximum benefit from the headers.
If you decide to go with a set of shorties I would still recommend a tune to get the full benefit of the header, even if you do not get a check engine light. |
04-22-2011, 04:10 PM | #11 | |
KMK
Drives: Slow V6 Camaro Join Date: Jan 2010
Yeah, had same problem with my JBA shorties, I removed them and returned the stock headers back, not worth the headache and the CEL |
04-22-2011, 04:39 PM | #12 |
2SS
Drives: 2016 2SS, Red Garnet Tint Join Date: Nov 2008
Also if you live in CA, shorties are your only option.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi) 1987 Camaro RS (California Special) - For Sale Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes) Ordered: 2-12-2016 TPW: 3-7-2016 Built: 3-7-2016 VIN 1G1FH78G0157626 Delivered: 4-26-2016 |
04-22-2011, 06:16 PM | #13 |
The Milkman
Some great info guys. Thanx.
04-22-2011, 06:26 PM | #14 |
Florida C5
Drives: 2010 Camaro 2SS Vortech L99 IOM Join Date: Jul 2009
Not true.........you just have to move in 5 years.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
Thread Tools | |
Similar Threads | ||||
2010 SS Long Tubes, Catback, CAI--Like New, AWESOME PACKAGE PRICE! | Torchdvette | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 15 | 11-16-2010 07:07 PM |
sound of v6 with the bbk long tubes | nyycamarogirl | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 1 | 09-09-2010 05:56 PM |
L99 Nickey edition Long Tubes, Cats X-PIPE, Magnaflows, Halltech, tune | NicKey | V8 Bolt-Ons & Tunes | 2 | 06-06-2010 10:35 AM |
Doug Thorley Long Tubes | Herron Performance | V8 Bolt-Ons & Tunes | 9 | 12-12-2009 11:31 AM |
L99 Tune/Dyno - ARH Long Tubes, Roto-Fab, Borla | Tanner | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 21 | 10-07-2009 07:31 PM |
